returned to flight (a little long)
Old May 30th 04, 06:51 PM
Matt Whiting
Default returned to flight (a little long)
I posted here a few months ago about returning to flying after a 4 year
layoff. I finally got in the air two days ago. I joined a flying club
that operates an Arrow 180, so I can also get some retract experience as
all of my prior time is in FG airplanes. I flew 2.4 hours for the first
flight mainly going through a Wings program since I needed a BFR anyway,
might as well kill two birds with one stone. Spent an hour on maneuvers
and an hour on T&L. Finished up with some hood work and then shot an
ILS approach. I was pretty amazed at how fast things came back. I
think the biggest problem I had was transitioning to the Arrow.
I owned a Skylane for 6 years and have about 400 hours of 182 time. The
Arrow is fairly different from the Skylane. Very heavy on the rudders
as compared to the 182, slightly heavier in pitch and roll. Much less
performance, especially take-off and climb. Similar cruise speed. The
panel layout is completely different and that was taking the most
getting used to. Also, the avionics are almost all different as well.
The retract gear took surpising little time to get used to, but the
Piper automatic gear is a pain in the butt. It takes about 100 MPH
before you can retract it on TO, unless you lift the override lever.
I was rather pleased with my flying skills after 4 years of rust. The
manevuers went well and the instructor just had me run through one
demonstration of each, no need for repetition. My basic hood skills
seemed fine and even my scan came back within minutes. I felt very
comfortable and the Arrow is at least as stable as the 182, maybe even
more stable.
The only part that didn't go as well as I'd have liked was the approach.
Then again, I wasn't at all prepared for that as we'd really planned
only the Wings/BFR stuff for this first flight. However, I think the
instructor got bored and decided to try an approach. He handed me his
Jepp chart for the ILS 24 at ELM and took the airplane to give me a few
minutes to study it. I've always used NOS charts so finding stuff on
the Jepp was a challenge. However, after buying current NOS charts, I
see that they have completely redesigned the plates since I last flew.
I like them much better, but they are different so that will take some
time. I was behind the airplane and flew through the localizer before
getting it captured. Tracking it was rough, but I did stay within two
dots. The glideslope went well, but that was likely accidental. I
identified all of the navaids, but failed to switch the marker beacons
on the audio panel and then was perplexed when they didn't go off.
However, I did get the plane down to DH in good enough shape to make a
decent landing. I was about 50' off the centerline at the 250' DH and
just a little high, but in real conditions it would have been a workable
approach.
Looks like the hardest part to get back on track is the habits such as
the 5Ts, studying an unfamiliar approach in the airplane, getting the
avionics set up properly and, of course, relearning the regulations.
The basic flying seems to be fine, including flying by reference to the
instruments. Even with the fairly turbulent air Friday evening, my
basic instrument flying was decent and my visual approaches and landings
weren't bad considering I was also making a model transition in the
process. I think if I was in my Skylane, even the visual approaches and
landings would have been much better. The Arrow doesn't glide nearly as
well as the 182 so I did come in too low on the first two approaches and
I was low on the power fail simulation. That 3-blade prop makes a good
speed brake when you throttle back.
If anyone else here is toying with the idea of getting back in the sky
after a long hiatus, I'd encourage you to go for it. I was really
expecting it to be a significant challenge, but it wasn't all that bad.
The IFR skills will take some more work, but the basic hood flying
skills will likely come back almost imediately. It is the "system"
skills that seem weakest, at least for me. Also, I've never flown a GPS
approach so that will take a little practice. The good news is that the
Arrow no longer has an ADF, so I don't have to worry about brushing up
that particular skill!
Matt
Old May 30th 04, 08:02 PM
Roy Smith
Hmmm. Something's not right here. The auto-extension is supposed to be
triggered by a combination of airspeed and manifold pressure (or it it
airspeed and mechanical position of the throttle control?). With full
throttle for takeoff, the gear should go up when you move the selector
lever, regardless of airspeed.
The Arrow doesn't glide nearly as well as the 182 so I did come in
too low on the first two approaches and I was low on the power fail
simulation. That 3-blade prop makes a good speed brake when you
throttle back.
I've found it's best to carry a little power right into the flare. How
much is "a little"? I'm not sure; at that point I'm not looking at the
MP gauge, I'm doing it by ear. Probably something like 12 inches? Just
enough that you can hear the engine rev up a bit above idle.
In an engine-out approach, you want to pull the prop lever all the way
back (this is true of any CS prop). This puts the blades in the highest
pitch so they present least resistance to the air. If you leave the
prop in the normal cruise position and pull the throttle, the plane
sinks like a brick. When you pull the prop lever back, you'll instantly
feel the plane leap forward.
Old May 30th 04, 09:17 PM
Teacherjh
If you leave the
Tried that in our Dakota. DIdn't feel much difference at all.
Jose
(for Email, make the obvious changes in my address)
Old June 1st 04, 01:40 PM
Dave Butler
Teacherjh wrote:
If you leave the
In the Mooney it's like cutting loose an anchor. "leap forward" is a good
description of the feeling.
Dave
Remove SHIRT to reply directly.
Old May 30th 04, 09:35 PM
Barry
The auto-extend uses the difference between ram and static pressures from the
sensor above the left wing. At full power, the prop wash contributes to the
ram pressure, to allow gear retraction at lower speeds. Our club has an Arrow
and we found it hard to keep the auto-extend adjusted correctly. Once we had
the opposite of the situation described by Matt - at idle power, the gear
wouldn't auto-extend until a very low speed that you'd normally encounter only
well into the landing flare. We finally decided to comply with the Piper
Service Bulletin that eliminates the auto-extend. The Service Bulletin also
includes a pullable circuit breaker for the gear motor, which allows more
realistic training on gear failures and manual gear extension.
Barry
Old May 31st 04, 02:11 PM
Matt Whiting
Yes, that was my impression from making my first read through the flight
manual, but that isn't how the airplane currently works. I've sent a
note to Piper to see if I can still buy a flight manual for a '67 so
that I can have one to study at my leisure. I flew again last night it
the gear definitely doesn't come up on take-off until you reach close to
100 MPH, unless you reach down for the override lever.
It may well be that the system isn't working properly and has lost the
MP or TP input. I'm not yet fully familiar with the Arrow's systems,
but am working on it.
throttle back.
Yes, I'd forgot about that.
Matt
Old May 31st 04, 03:14 PM
Roy Smith
triggered by a combination of airspeed and manifold pressure (or is it
Hence my statement that something's not right :-) I think the something
that's not right is that the system in the airplane is out of adjustment.
I've sent a note to Piper to see if I can still buy a flight manual
for a '67 so that I can have one to study at my leisure.
Piper may or may not be able to supply you with one, and if they do
it'll probably be at an outrageous price. Two good suppliers I've found
for POH reprints a
Essco, Inc.
378 S. Van Buren Ave.
Barberton Ohio 44203
877-318-1555 (toll free)
330-644-7724
330-644-0886 (fax)
http://www.esscoaircraft.com
SureCheck Aviation
546 S. Pacific St, Suite C101
San Marcos, CA 92069
888-340-8055
760-891-0500
http://surecheck.net
Old May 31st 04, 09:57 PM
Matt Whiting
for POH reprints a
Essco, Inc.
330-644-7724
330-644-0886 (fax)
SureCheck Aviation
888-340-8055
760-891-0500
Thanks, Roy.
Matt
Flight test update - long nauga Home Built 0 June 18th 04 03:21 AM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
