climb performance Jet vs Prop
Old July 4th 06, 01:45 PM posted to rec.aviation.piloting
xerj
Default climb performance Jet vs Prop
Do I have the following right?:-
Jet:-
Vx IAS stays the same as altitude gets higher.
Vy IAS reduces as altitude gets higher.
Both angle and rate of climb lessen as altitude increases.
Prop:-
Vx IAS increases as altitude gets higher.
If the above is right, is there a rule of thumb for how much the various
speeds change, or is it really aircraft+powerplant reliant?
TIA
Old July 4th 06, 06:03 PM posted to rec.aviation.piloting
Peter Duniho
"xerj" wrote in message
Jet:-
Prop:-
I'm not convinced that it is right.
Vx occurs at the airspeed where excess thrust is maximized, while Vy occurs
at the airspeed where excess power is maximized. Off the top of my head, I
don't see any reason to believe that for a jet, that it's a given that
maximum excess thrust would occur at a constant airspeed with respect to
altitude.
It's true that many jet installations are derated, so that the engine can
continue to produce sea-level power and thrust up to a certain altitude.
But then, the same is true for many turbocharged piston-engined propeller
airplanes. And some jet installations aren't derated and so power and
thrust falls off with altitude just as would happen for a normally-aspirated
piston-engined airplane.
Beyond the difference in combustion air compression, a jet is really not
that different from a propeller, with respect to producing thrust. Fan/prop
blades both pull air in and push it out...the jet just happens to have a
shroud around it. The similarity is especially great with respect to
high-bypass turbofan engines, where thrust from combustion is a very small
proportion of total thrust.
I admit that I haven't studied the facts surrounding your question closely.
But I think that even with a pure jet, thrust is not actually constant with
altitude (except in the case of derating, of course). At first glance, I
don't see any reason to believe that Vx and Vy behave significantly
differently depending on the basic engine technology (ignoring the question
of altitude-compensating technology like turbochargers, of course).
Pete
Old July 4th 06, 07:37 PM posted to rec.aviation.piloting
karl gruber[_1_]
I agree with Peter, and haven't ever seen a difference just because of
engine type.
One minor nit.......jet engines are typically FLAT rated, not derated,
although that also happens. Flat rated means that a big engine with lots of
horsepower is limited to some lower horsepower at sea level. That engine can
then continue to extract that same horsepower as it climbs to an altitude to
where it typically temps out.
Here is a discussion of falt and derating.
http://www.pprune.org/forums/showthread.php?t=222816
Karl
"curator" N185KG
Jet:-
Prop:-
occurs at the airspeed where excess power is maximized. Off the top of my
head, I don't see any reason to believe that for a jet, that it's a given
that maximum excess thrust would occur at a constant airspeed with respect
to altitude.
normally-aspirated piston-engined airplane.
Fan/prop blades both pull air in and push it out...the jet just happens to
have a shroud around it. The similarity is especially great with respect
to high-bypass turbofan engines, where thrust from combustion is a very
small proportion of total thrust.
closely. But I think that even with a pure jet, thrust is not actually
constant with altitude (except in the case of derating, of course). At
first glance, I don't see any reason to believe that Vx and Vy behave
significantly differently depending on the basic engine technology
(ignoring the question of altitude-compensating technology like
Pete
Old July 4th 06, 10:49 PM posted to rec.aviation.piloting
xerj
to altitude.
The ***TAS*** would definitely increase, but the drag/thrust curve moves to
the right rather than to the right and up like the power required curve. As
far as I can tell, and I'm basing it (probably WAY too much) on the
interactive program found at this page
http://www.professionalpilot.ca/aero.../climb_jet.htm, the
***IAS*** remains almost constant for a jet.
Confusing stuff.
Old July 4th 06, 10:54 PM posted to rec.aviation.piloting
Peter Duniho
We were talking about IAS. I didn't change that.
but the drag/thrust curve moves to the right rather than to the right and
up like the power required curve. As far as I can tell, and I'm basing it
(probably WAY too much) on the interactive program found at this page
the ***IAS*** remains almost constant for a jet.
Got an example that doesn't require the installation of an ActiveX control?
I have, against my better judgment, already succumbed to Java and Flash, but
I draw the line at adding Shockwave to the mix.
Also note that "remains almost constant" isn't the same as "stays the same".
Confusing stuff.
It's only confusing to those who haven't studied it enough to have an
intuitive sense of how things work.
Of course, that describes most of us (including myself). But still, it
seems to me that in aerodynamics particularly, most analysis winds up being
based on some fairly simple principles. The trick is knowing how to apply
them.
Pete
Old July 5th 06, 01:30 PM posted to rec.aviation.piloting
xerj
No, I don't have an example without the need for shockwave.
I'll trawl around and see if I can can up with something.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
