I have a 1987 Ventus C that I purchased in 1995. Love
the plane but it wants to roll to the right at high speeds (90kts or greater). Actually I guess it always wants to roll to the right but I start to notice how much left aileron pressure I have to apply to counter the roll at the higher speeds, especially above 100kts, for any period of time (long final glide). It makes my arm tired. At speeds below 80kts I don't notice it. I have tried various riggings with the flaps/ailerons but other than slight improvements I don't seem to be making any progress and have just 'lived with it' over the years. I'm afraid that the problem might be 'built-in' to the airframe with one wing having a different angle of incidence than the other. I sent an email to Schempp-Hirth about this and never got a reply. Anyone have any ideas? Jimmy Hamilton Reno, NV JLH |
It's unlikely to be built in unless there has been
damage and a poor repair. Are you using 17.6 extensions, these have a spring to set a 'neutral position' is it still present on both wings and is the neutral position the same. Have you set up the flaps for equal displacement, eg, does the same deflection happen from both full left and right stick, normal check here in UK for CofA. If you set the flaps to equal positions is the stick still in the centre. Its quite a complicated setup and could well have gone adrift over the years or you might be seeing damage or impending problems. If you have actually started to notice it then it must be fairly dramatic by now. Do a control movements check to see if anything is out and work back from there. John PS reading between the lines, I presume that it is only evident at neg flap positions, 86 being the change over to -1. If so ten you need to check control movements at all flap settings |
You may want to make three accurate templates pattern
A stable material like 1/2" thick Birch ply or 5/8 Flooring plywood will be OK. Make one template for the 2 ft station away from the root one at the first taper break and the third near the tip. use the top surface of the template as a reference to measure your angle deviation. your measuring device should be accurate to within 1/4 degree over 2 ft. make sure to position the templates in the same relative position on the other wing when measuring it. Always point the measuring device in the same relative direction. You need to print out the airfoil with the correct chord dimension for each station. The Ventus has a different tip airfoil, you must find out what airfoil it is. You can see a sample picture on my web page under personal http://www.wingdolly.reach.net/personal.html All this assumes you checked your aileron and flap settings. Even if the aileron is set right, if the flap is off by 11/2 degree you will have that effect. Regard Udo |
James:
I had the same problem with my old ASW-20 a couple of years ago and it nearly drove me crazy until I found the cause. In my case, a short section of my mylar flap gap tape had come slightly unglued, effectively giving a slight aileron effect that was really noticeable at high speeds. It was almost impossible to see and even when I found the unglued tape I was skeptical that it could be the cause as it looked so insignificant. However, when I resealed it, the problem went away completely. This may not be your problem, but I'd check first as it's an easy fix. regards Mike James Hamilton wrote: I have a 1987 Ventus C that I purchased in 1995. Love the plane but it wants to roll to the right at high speeds (90kts or greater). Actually I guess it always wants to roll to the right but I start to notice how much left aileron pressure I have to apply to counter the roll at the higher speeds, especially above 100kts, for any period of time (long final glide). It makes my arm tired. At speeds below 80kts I don't notice it. I have tried various riggings with the flaps/ailerons but other than slight improvements I don't seem to be making any progress and have just 'lived with it' over the years. I'm afraid that the problem might be 'built-in' to the airframe with one wing having a different angle of incidence than the other. I sent an email to Schempp-Hirth about this and never got a reply. Anyone have any ideas? Jimmy Hamilton Reno, NV JLH |
I would check the tape first, too. It's difficult to believe the impact
a small piece of loose tape can have...or the difficulty of finding it. Many years ago at the U.S. 15M Nationals (why do these things always happen at contests?), my LS-3 began to pitch down abruptly when thermaling. Just enough to get my attention. It didn't appear to stall, but the nose dropped enough to make me wonder. After a while, I noticed this only happened when I was carrying water ballast. Day after day, as I talked to experts, I'd take off with water, find myself feeling uncomfortable in gaggles, and finally dump ballast to fly the task. The problem didn't always show up immediately--sometimes it was 15 to 30 minutes before this started--but it was always there eventually. Finally I discovered that a 4" wide section of cloth tape on the top side of the elevator hinge joint was not stuck down firmly. Apparently, at flying speeds the front 1/4" of the tape would eventually work loose and flip up intermittantly. On the ground it looked normal (and the vast majority of it was). The only reason I found it was running my fingernail along the front edge of the tape. The sticky part had dust on it, indicating it had been in the airflow for a while. The fix was easy: I simply applied the usual white plastic wing gap tape to the front edge of the cloth tape to hold it down until I could replace it, with immediate results. Chip Bearden ASW 24 "JB" |
I have corrected this problem on unflapped gliders before. On one glider in
particular one aileron had a bit more undercamber than the other due some damage. The temporary fix was to add a small trim tab on the trailing edge of the aileron. It worked! The aileron was subsequently fixed due to another repair. It always came down to a twist, bend or some damage of the aileron. The reasoning is; If the aileron rigging was wrong and with the stick central and the left was down further than the right. Then when flying if the stick was held central then a roll would result. If it was flown hands off then the ailerons would balance at a nuetral posiotn and it would fly level. Hence if the pilot is having to apply side stick loads whilst in flight it can not be due to incorrect lenght of pushrods and rigging and must be due to twists or some such. This of course does not hold if there are centralising springs or dampers that are set up. However if the stick loads increase with speed as described then it is centainly not due to springs or dampers. Of course flaps being set differently on each side would give rise to the same sort of characteristics as a twist or bend. Also I would have to agree to check the mylar seals and such like they do have dramatice effects if they are loose. "James Hamilton" wrote in message ... I have a 1987 Ventus C that I purchased in 1995. Love the plane but it wants to roll to the right at high speeds (90kts or greater). Actually I guess it always wants to roll to the right but I start to notice how much left aileron pressure I have to apply to counter the roll at the higher speeds, especially above 100kts, for any period of time (long final glide). It makes my arm tired. At speeds below 80kts I don't notice it. I have tried various riggings with the flaps/ailerons but other than slight improvements I don't seem to be making any progress and have just 'lived with it' over the years. I'm afraid that the problem might be 'built-in' to the airframe with one wing having a different angle of incidence than the other. I sent an email to Schempp-Hirth about this and never got a reply. Anyone have any ideas? Jimmy Hamilton Reno, NV JLH |
John Orton wrote:
I have corrected this problem on unflapped gliders before. On one glider in particular one aileron had a bit more undercamber than the other due some damage. The temporary fix was to add a small trim tab on the trailing edge of the aileron. It worked! The aileron was subsequently fixed due to another repair. It always came down to a twist, bend or some damage of the aileron. The reasoning is; If the aileron rigging was wrong and with the stick central and the left was down further than the right. Then when flying if the stick was held central then a roll would result. If it was flown hands off then the ailerons would balance at a nuetral posiotn and it would fly level. Hence if the pilot is having to apply side stick loads whilst in flight it can not be due to incorrect lenght of pushrods and rigging and must be due to twists or some such. This of course does not hold if there are centralising springs or dampers that are set up. However if the stick loads increase with speed as described then it is centainly not due to springs or dampers. Of course flaps being set differently on each side would give rise to the same sort of characteristics as a twist or bend. Also I would have to agree to check the mylar seals and such like they do have dramatice effects if they are loose. "James Hamilton" wrote in message ... I have a 1987 Ventus C that I purchased in 1995. Love the plane but it wants to roll to the right at high speeds (90kts or greater). Actually I guess it always wants to roll to the right but I start to notice how much left aileron pressure I have to apply to counter the roll at the higher speeds, especially above 100kts, for any period of time (long final glide). It makes my arm tired. At speeds below 80kts I don't notice it. I have tried various riggings with the flaps/ailerons but other than slight improvements I don't seem to be making any progress and have just 'lived with it' over the years. I'm afraid that the problem might be 'built-in' to the airframe with one wing having a different angle of incidence than the other. I sent an email to Schempp-Hirth about this and never got a reply. Anyone have any ideas? Jimmy Hamilton Reno, NV JLH As John commented any aerofoil discrepancy will result in progressively different forces. If there is any damage history on the wings or reprofiling history, this would be a place to look. Assuming this is not the case - Just a thought, but have you looked at the wings when you are applying the force. The Schempp-Hirth airbrake caps are spring loaded, over time the springs weaken and you may have assymetric protrusion. Similarly they lock down from the outside in - if the over centre is not symmetrical you could have the same effect. Not sure how this is set on the Ventus, on the Cirrus it is by rotating tie rod ends in the fuselage, so it would be easy to have different tension left to right. At high speed these would introduce significant forces with the slightest differences. |
At 06:12 07 July 2006, Bumper wrote:
'John Orton' wrote in message ... I have corrected this problem on unflapped gliders before. On one glider in particular one aileron had a bit more undercamber than the other due some damage. The temporary fix was to add a small trim tab on the trailing edge of the aileron. It worked! It's easy to experiment by adding a wedge shaped strip to the underside of the aileron trailing edge, affixing it with double sided tape. This will act like a downward bent trim tab. bumper .... as well as altering the mass balance, risking flutter and invalidating the C of A and, therefore, insurance ... in most countries but not in the USA, of course, where aerodynamics work differently under the 'experimental' category. |
Ventus C 17.6 | John Shelton | Soaring | 0 | January 17th 05 05:48 PM |
2003 Ventus 2C for sale | Thomas Knauff | Soaring | 21 | July 20th 04 07:10 PM |
TURBULATOR TAPE ON VENTUS B | Ventus B | Soaring | 5 | February 18th 04 08:27 PM |
Ventus & Ventus 2 | John W | Soaring | 3 | December 7th 03 03:55 AM |
Ventus C vs B | tango4 | Soaring | 6 | September 10th 03 03:29 AM |
