Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Concorde - join the campaign
Old July 8th 06, 10:35 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
Clive
Default Concorde - join the campaign
On Sat, 08 Jul 2006 22:16:49 +0100, wrote:
On 3 Jun 2006 12:54:17 -0700, wrote:
Hi all,
The campaign to get Concorde flying again has attracted 2,000
signatures this week!
Please add your support at
www.save-concorde.com.
Concorde grew old and killed many humans and so was pensioned off so
has not to kill again which it surly would have done .
It was a beautiful aircraft but you wouldn't catch me flying in it now
where it still in service I value my life to much for that .
The Concorde crash has been proven to be debris on the runway and human
error (groundcrew).
Had the debris not been on the runway and the gear been assembled
correctly then the accident would not have happened.
From your post then we should all stop flying 747's. How many people has
the 747 killed?
Clive
Old July 8th 06, 11:26 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
John A. Weeks III
In article op.tcd3kpvzj9nxpm@clive,
error (groundcrew).
This is a chicken and egg problem. The Concorde was unusually
susceptible to the problem that happened. Had it been designed
differently, the accident may not have happened. In fact, there
was a previous similar accident (that did not result in a crash),
and at that time, the airlines decided not to fix the problem.
That is the sad part--they had prior warning, which they ignored.
That is also true of both Space Shuttle accidents.
-john-
John A. Weeks III 952-432-2708
Newave Communications
http://www.johnweeks.com
Old July 9th 06, 04:48 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
FatKat
Hi all,
error (groundcrew).
the 747 killed?
What is the incidence of fatal or serious incidents in other aircraft
traced to circumstances similar to that of the Concorde? I doubt that
it's as much as Concorde, given how much higher use that type has
provided compared to Concorde in roughly the same period of time. Of
course we have lost 747's, but mostly in incidents of spectacular human
accident/incident (Tenarife, Lockerbie). There is ofcourse FT800 (if
you accept/buy the official story), but the demonstrable safety record
of the 747 still seems spotless in comparison.
Old July 9th 06, 05:09 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
Clive
Hi all,
error (groundcrew).
has
the 747 killed?
Partially correct - I'll agree that the number of hours flown by 747's far
outnumbers those by Concorde.
But, The concorde crash was caused by something outside the control of the
concorde crew i.e. debris from another aircraft (also the same for the
Lockerbie 747), So had it not been for that it's record would have been
100%.
However, a lot of aircraft accidents have been caused by design errors -
Concorde never suffered any of those - or at least design error that
caused fatalities.
It would be interesting to know, but I suspect that the number of hours
flown by Concorde (before it was given a permit to fly) was more than any
other aircraft.
Clive
Old July 9th 06, 05:16 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
FatKat
Hi all,
error (groundcrew).
has
the 747 killed?
100%.
Actually, the Lockerbie incident was caused by deliberate conduct by
terrorism, whereas the Concorde accident appears to involve debris that
could be found on any runway in the world. Also, the fact that the
Concorde accident occurred "outside" the control of the crew is at best
irrelevant and at worst aggravating - we're talking about design flaws,
the plane being unfit when it leaves the factory despite the expertise
of the aircrew.
caused fatalities.
Except for the one in 2000. How many errors of similar or otherwise
comparable circumstances befell 747, keeping in mind how much greater
use was provided by one against the other?
other aircraft.
And you would suspect that based on what?
Old July 9th 06, 07:28 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
Clive
Hi all,
so
now
human
error (groundcrew).
has
the 747 killed?
human
far
100%.
of the aircrew.
caused fatalities.
any
other aircraft.
747 - 1500hrs test (Source Boeings own site)
Concorde....
Both European airlines operated demonstrations and test flights from 1974
onwards. The testing of Concorde set records which are still not
surpassed; it undertook 5,335 flight hours in the prototype,
preproduction, and first production aircraft alone. A total of 2,000 test
hours were supersonic. This equates to approximately four times as many as
for similarly sized subsonic commercial aircraft.
Clive
Old July 9th 06, 08:19 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
FatKat
Hi all,
so
now
human
error (groundcrew).
has
the 747 killed?
human
far
100%.
of the aircrew.
caused fatalities.
any
other aircraft.
Concorde....
Clive
And the ratio of hours of revenue flight for the two are what then?
And when you combine the two, the ratio of revenue flight hours to
test-flight time is what?
Old July 9th 06, 08:25 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
John A. Weeks III
In article op.tcfi56vzj9nxpm@clive,
100%.
That is a totally unrealistic line of thought. There will be FOD on
the ramp or runway as some point in an airplane's operating life.
Had that small piece of metal not been on the runway the day that
the Concorde crashed, it would have been on some other runway some
other day. An airplane that is designed to crash, burn, and kill
over 100 people when it its a small piece of FOD is an aircraft that
is both flawed and an accident waiting to happen. The only curious
thing is why it took so long. In fact, a previous time that a
Concorde hit debris and punctured the fuel tanks, the aircraft managed
to survive without crashing. That is probably the true wonderment.
-john-
Old July 9th 06, 08:33 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
Alistair Gunn
In rec.aviation.military John A. Weeks III twisted the electrons to say:
The only curious thing is why it took so long.
As you said later on in your post ...
In fact, a previous time that a Concorde hit debris and punctured the
fuel tanks, the aircraft managed to survive without crashing.
.... so that would be two cases in more than a few years of take-offs /
landings. Which would tend to suggest that the reason "it took so long"
was because it wasn't a very likely event.
I could also point the Boeing 737 rudder defect?
These opinions might not even be mine ...
Let alone connected with my employer ...
Old July 9th 06, 08:49 PM posted to rec.aviation.military,rec.aviation.misc,uk.rec.aviation,uk.transport.air,rec.aviation.products
Mike Lindsay
John A. Weeks III writes
100%.
-john-
SMALL piece of FOD? Or a big chunk? Whatever, it shouldn't have been
there.
Mike Lindsay
Concorde - join the campaign Clive General Aviation 30 July 23rd 06 12:15 AM
Concorde - join the campaign LWG Naval Aviation 0 June 9th 06 09:06 PM
Concorde - join the campaign Derek Copeland Soaring 0 June 6th 06 05:59 PM
Concorde - join the campaign Jim Carter Owning 0 June 6th 06 03:28 AM
Concorde - join the campaign Jim Naval Aviation 2 June 3rd 06 10:27 PM
