Captain Fraidy-Cat Has a Question
Old July 11th 06, 03:32 AM posted to rec.aviation.soaring
Blue Crew
Default Captain Fraidy-Cat Has a Question
An actual conversation that quite recently took place ten thousand feet
over the California desert between Captain Fraidy-Cat (CFC) and a
rather happy-go-lucky glider CFI (CFIG):
CFC: NO!! PLEASE! I'M SCARED!!!
CFIG: What are you scared of?
CFC: I DON'T KNOW!!
CFIG: Then you can't be scared. You have to at least be scared of
something. Keep your turn going.
CFC: I'M SCARED THAT SHE'S GONNA INVERT!!
CFIG: She won't. Keep your turn going.
CFC: WHEN I MAKE A TURN, THE STICK IS ALL THE WAY AGAINST MY LEG AND
IT WON'T GO ANY FURTHER!!
....but what the exhausted, flabbergasted Captain Fraidy-Cat failed to
clarify for the CFIG was that he was referring to the OPPOSITE leg,
i.e., when he was in a right turn, say, he had the stick all the way to
the LEFT, pressing on his left leg, and she still seems to be on the
verge of rolling (banking) even further to the RIGHT. And THAT is what
he was scared of.
So now we're all back on the ground in the city, all rested up and
thinking more clearly, and the question is posed to you courageous
gentlemen on this news group: Could the glider continue rolling with
hard opposite aileron? Would opposite rudder (left in the above
example) help? Type is: Schweitzer SGS 2-33.
P.S. If that thing had a decent piece of yarn for a yaw string instead
of that worn-out, raggedy, one-inch stub, this conversation might not
have taken place as such. CFC had to fly her by feel, something
usually reserved for more experienced glider pilots.
Old July 11th 06, 03:56 AM posted to rec.aviation.soaring
You had to correct for that much adverse yaw in a 2-33?!?!?
Hope it was a 20 knotter
~tuno
Old July 11th 06, 04:00 AM posted to rec.aviation.soaring
Bill Daniels
It's common knowledge that the 2-33 uses the students legs as aileron
control stops, hince the howls of pain from the front cockpit whenever the
instructor demonstrates a maneuver. (The student can get even by 'clearing
the controls' without warning the instructor to move vital body parts clear
of the rear stick.)
If the students legs are anything larger than skinny, those control stops
(legs) will prevent using adequate 'top' aileron to overcome overbanking
generating understandable fear of 'inverting'.
Solutions: A. Get skinnier students or B. Get a better training glilder.
Seriously, ask if the student is holding constant rudder into the turn.
Bill Daniels
"Blue Crew" wrote in message
CFC: I DON'T KNOW!!
he was scared of.
Old July 11th 06, 04:05 AM posted to rec.aviation.soaring
BTIZ
Left Rudder for a right turn would have helped roll wings level, not
continue the turn to the right.
What happened to the pre takeoff ground check, Controls free and clear..
that means you can move the control (left right forward and back, all the
way around) all the way to the mechanical stop. Not to the leg or in some
cases, aft stick to the belly impact.
If the leg is in the way, then the CFC is to big to be flying the 2-33
because he cannot deflect the controls to the mechanical stop. I'm betting
that if he could have removed his left leg for the right turn, then the
controls would work as advertised.
For those not familiar with long winged gliders and steep banked turns, "top
stick" or opposite aileron is required to counter the over banking tendency.
Yaw strings are nice, but as a CFIG I can't see it most of the time anyway
from the back seat. Unless I really try to look around the front seat
pilot/student. I "sense" an out of trim condition, then look around the
front seater at the yaw string to confirm before I say something.
Take the pre-solo student out without a yaw string.
BT
CFC: I DON'T KNOW!!
he was scared of.
Old July 11th 06, 08:31 AM posted to rec.aviation.soaring
quietman
Pretty funny.
I only fly a 2-33 once in a while and always have a moment or two at
first where I wonder..."is the stick still connected?!!!"
A good technique in a turn is to STAND on the rudder in the direction
you desire, LIFT the opposite leg up high and PUSH the stick to the
fabric under that leg...perfect!
quietman
www.roenation.com
Old July 11th 06, 02:02 PM posted to rec.aviation.soaring
Bill Daniels
"quietman" wrote in message
ps.com...
Pretty funny.
quietman
www.roenation.com
Try this. While on the ground, install the student in the front seat of a
2-33, ask him to open the spoilers 50% and then try to use left aileron.
You will find the students left leg is pinned between the spoiler handle and
the stick limiting stick travel to about 2". Now, imagine trying to handle
a left crosswind gust just before touchdown.
bildan
Old July 12th 06, 02:45 AM posted to rec.aviation.soaring
BTIZ
and the stick limiting stick travel to about 2". Now, imagine trying to
handle a left crosswind gust just before touchdown.
bildan
Perfect evaluation, I guess the controls are really not clear are they.
BT
Old July 11th 06, 02:29 PM posted to rec.aviation.soaring
Papa3
BT
Got a lot of time in 2-33's?? This is a common problem affecting
anyone other than the anorexic or pre-pubescent teen students.
Solution typically involves having the student remove opposite foot
from rudder pedal enabling leg to be pulled back to where the thinner
shin-bone doesn't get in the way (quite as much).
Erik Mann (P3)
Old July 12th 06, 02:50 AM posted to rec.aviation.soaring
BTIZ
Yes I do have a lot of time in 2-33s. And if the student cannot keep both
feet on the pedals and deploy spoilers as mentioned by Bill Daniels.. AND
MOVE FULL LEFT STICK TO THE MECHANICAL STOP... we don't fly the 2-33. We
move on to the Grob 103. And if the student is over 210#, we don't fly
period. My weight plus a 210# student will put us over gross.
Even in the 2-33, anyone large enough to have a stick actuation problem in
the 2-33 is going to require an anorexic instructor in the back seat to
remain below Max GW.
I am not anorexic or a pre-pubescent teen. I am over 50, 200 lbs and 5-10+.
I can fly front seat in the 2-33 with no control issues.
Papa3, I do hope you are not flying a 30+yr old glider over Max GW.
BT
"Papa3" wrote in message
betting
BT
Erik Mann (P3)
Old July 11th 06, 09:33 AM posted to rec.aviation.soaring
Z Goudie
At 07:36 11 July 2006, Quietman wrote:
Pretty funny.
moment or two at
first where I wonder...'is the stick still connected?!!!'
in the direction
the stick to the
Jings, crivvens and help ma boab, do these things actually
have Certificates of Airworthiness???
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
From the Jim Campbell, Captain Zoom archives (all of 6 years ago) Mick Home Built 49 February 3rd 06 03:27 PM
A Sea Story (OT and long) Mike Kanze Naval Aviation 4 March 14th 05 03:51 AM
