Has anyone experienced a problem with the GXM30 receiver/antenna? My 396
will stop receiving weather data (but audio is okay) after the antenna heats up, especially when it is exposed to the heat of the sun. I called Garmin and was told that there was a production problem with antennas in the Oct/Nov 2005 timeframe, where thermal expansion would cause intermittent contact inside the GXM30 and data services would stop, but audio was unaffected. Garmin is willing to fix my receiver for free under warranty, but they are quoting a 7-10 working day turnaround. Not sure if this is something that I could fix with a soldering iron or not, as I don't know exactly what the problem is or what is required to fix it. JKG |
You don't happen to know where one can find the manufacture date for a
given unit, do you? --Dan Jonathan Goodish wrote: Has anyone experienced a problem with the GXM30 receiver/antenna? My 396 will stop receiving weather data (but audio is okay) after the antenna heats up, especially when it is exposed to the heat of the sun. I called Garmin and was told that there was a production problem with antennas in the Oct/Nov 2005 timeframe, where thermal expansion would cause intermittent contact inside the GXM30 and data services would stop, but audio was unaffected. Garmin is willing to fix my receiver for free under warranty, but they are quoting a 7-10 working day turnaround. Not sure if this is something that I could fix with a soldering iron or not, as I don't know exactly what the problem is or what is required to fix it. JKG |
In article . com,
"Dan" wrote: You don't happen to know where one can find the manufacture date for a given unit, do you? No, but if you're worried about yours being affected, my suggestion would be to fire it up on your car dash in the mid-afternoon sun, and let it run for about an hour. If you receive weather for a couple cycles and then it stops updating after a while, your unit is likely affected. I had an unrelated issue back in October and, at that time, Garmin told me that they had made some minor modifications to the design of the GXM30 since the initial production run. I suppose they could have continued to make minor modifications since that time, so it's entirely possible that those units affected by heat-related issue are rather limited in the market. The Garmin rep with whom I spoke last week seemed to feel that the heat-related failure wasn't widespread. I still see the larger potential problem with the GXM30 as the right-angle USB plug. It just seems that the plug is eventually going to either break off, or break something in the GPS unit itself. It's under stress after it's plugged in, and it's placed under even more stress when you disconnect it, even if you're careful. JKG |
There must be some reason why they did it this way... I suppose one
could purchase a USB adaptor cable... Jonathan Goodish wrote: In article . com, "Dan" wrote: You don't happen to know where one can find the manufacture date for a given unit, do you? No, but if you're worried about yours being affected, my suggestion would be to fire it up on your car dash in the mid-afternoon sun, and let it run for about an hour. If you receive weather for a couple cycles and then it stops updating after a while, your unit is likely affected. I had an unrelated issue back in October and, at that time, Garmin told me that they had made some minor modifications to the design of the GXM30 since the initial production run. I suppose they could have continued to make minor modifications since that time, so it's entirely possible that those units affected by heat-related issue are rather limited in the market. The Garmin rep with whom I spoke last week seemed to feel that the heat-related failure wasn't widespread. I still see the larger potential problem with the GXM30 as the right-angle USB plug. It just seems that the plug is eventually going to either break off, or break something in the GPS unit itself. It's under stress after it's plugged in, and it's placed under even more stress when you disconnect it, even if you're careful. JKG |
![]() "Jonathan Goodish" wrote: Has anyone experienced a problem with the GXM30 receiver/antenna? My 396 will stop receiving weather data (but audio is okay) after the antenna heats up, especially when it is exposed to the heat of the sun. Mine does not, but I have it shaded under one of those soft, plastic "slap-on" sun shields that AOPA used to give away. Garmin should have had a recall for this problem: the've known about it a long time. -- Dan C172RG at BFM |
10 day turn around and for free sounds like a good deal. I sure wouldn't
mess with something the company will fix for FREE. Once you mess with it then probably won't get the FREE repair offer. -- Have a good day and stay out of the trees! See ya on Sport Aircraft group http://groups.yahoo.com/group/Sport_Aircraft/ "Jonathan Goodish" wrote in message ... Has anyone experienced a problem with the GXM30 receiver/antenna? My 396 will stop receiving weather data (but audio is okay) after the antenna heats up, especially when it is exposed to the heat of the sun. I called Garmin and was told that there was a production problem with antennas in the Oct/Nov 2005 timeframe, where thermal expansion would cause intermittent contact inside the GXM30 and data services would stop, but audio was unaffected. Garmin is willing to fix my receiver for free under warranty, but they are quoting a 7-10 working day turnaround. Not sure if this is something that I could fix with a soldering iron or not, as I don't know exactly what the problem is or what is required to fix it. JKG |
In article ESwug.1844$Gv.386@fed1read09, "Gilan"
wrote: 10 day turn around and for free sounds like a good deal. I sure wouldn't mess with something the company will fix for FREE. Once you mess with it then probably won't get the FREE repair offer. Well the "free" fix is part of their 1 year warranty, though it isn't really free, as I have to ship it to them. Since the warranty is almost up on my unit, there would be little risk in opening the case and voiding the warranty. According to the manual, the maximum operating temperature of the GXM30 is 185F, though it doesn't say what happens after that. I suppose that it is possible that the unit could exceed that temperature after sitting in the sun on the dash of the car for 20-30 minutes, but I suspect that it is unlikely in my case. I'll have to send the unit back and see what I receive in return, and if the "repaired" unit tolerates the heat any better. JKG |
I would still rather have a "known good & tested" fix instead of a
homebrew job that may or may not solve the problem. Next time it happens, solder away! $20 is easier to spend now than $2500 in a few months after the fix craps out and renders the unit much less functional/useless. Just my $.02 worth, Chris Jonathan Goodish wrote: In article ESwug.1844$Gv.386@fed1read09, "Gilan" wrote: 10 day turn around and for free sounds like a good deal. I sure wouldn't mess with something the company will fix for FREE. Once you mess with it then probably won't get the FREE repair offer. Well the "free" fix is part of their 1 year warranty, though it isn't really free, as I have to ship it to them. Since the warranty is almost up on my unit, there would be little risk in opening the case and voiding the warranty. According to the manual, the maximum operating temperature of the GXM30 is 185F, though it doesn't say what happens after that. I suppose that it is possible that the unit could exceed that temperature after sitting in the sun on the dash of the car for 20-30 minutes, but I suspect that it is unlikely in my case. I'll have to send the unit back and see what I receive in return, and if the "repaired" unit tolerates the heat any better. JKG |
Can't solder if I can't identify the problem. For all I know, it could
be a bad component that they have since eliminated from production, and they could end up replacing the guts of my GXM30. I sent it to them today, and they promised to turn it around quickly, so we'll see ... JKG In article ews.net, "Chris G." wrote: I would still rather have a "known good & tested" fix instead of a homebrew job that may or may not solve the problem. Next time it happens, solder away! $20 is easier to spend now than $2500 in a few months after the fix craps out and renders the unit much less functional/useless. Just my $.02 worth, Chris Jonathan Goodish wrote: In article ESwug.1844$Gv.386@fed1read09, "Gilan" wrote: 10 day turn around and for free sounds like a good deal. I sure wouldn't mess with something the company will fix for FREE. Once you mess with it then probably won't get the FREE repair offer. Well the "free" fix is part of their 1 year warranty, though it isn't really free, as I have to ship it to them. Since the warranty is almost up on my unit, there would be little risk in opening the case and voiding the warranty. According to the manual, the maximum operating temperature of the GXM30 is 185F, though it doesn't say what happens after that. I suppose that it is possible that the unit could exceed that temperature after sitting in the sun on the dash of the car for 20-30 minutes, but I suspect that it is unlikely in my case. I'll have to send the unit back and see what I receive in return, and if the "repaired" unit tolerates the heat any better. JKG |
Good luck! I hope it works out well for you! :-)
Chris Jonathan Goodish wrote: Can't solder if I can't identify the problem. For all I know, it could be a bad component that they have since eliminated from production, and they could end up replacing the guts of my GXM30. I sent it to them today, and they promised to turn it around quickly, so we'll see ... JKG In article ews.net, "Chris G." wrote: I would still rather have a "known good & tested" fix instead of a homebrew job that may or may not solve the problem. Next time it happens, solder away! $20 is easier to spend now than $2500 in a few months after the fix craps out and renders the unit much less functional/useless. Just my $.02 worth, Chris Jonathan Goodish wrote: In article ESwug.1844$Gv.386@fed1read09, "Gilan" wrote: 10 day turn around and for free sounds like a good deal. I sure wouldn't mess with something the company will fix for FREE. Once you mess with it then probably won't get the FREE repair offer. Well the "free" fix is part of their 1 year warranty, though it isn't really free, as I have to ship it to them. Since the warranty is almost up on my unit, there would be little risk in opening the case and voiding the warranty. According to the manual, the maximum operating temperature of the GXM30 is 185F, though it doesn't say what happens after that. I suppose that it is possible that the unit could exceed that temperature after sitting in the sun on the dash of the car for 20-30 minutes, but I suspect that it is unlikely in my case. I'll have to send the unit back and see what I receive in return, and if the "repaired" unit tolerates the heat any better. JKG |
Garmin 430 Reception | Jon Kraus | Piloting | 16 | November 7th 04 03:17 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin Specials ADV | Michael Coates | Home Built | 0 | March 18th 04 12:24 AM |
Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 09:04 PM |
