Testing MoGas
Old July 18th 06, 01:41 PM posted to rec.aviation.piloting
Jay Honeck
Default Testing MoGas
For those of us who use car gas, the advent of ethanol has been a real
pain. Although we don't test every tank full, we have used the
"water/gas/shake" test to verify that there is no ethanol present. I
find this method to be rather imprecise and quite a pain, since you
have to have water around to perform the test. (Not easy, in an
unheated hangar, in winter.)
As ethanol spreads like a cancer, we're becoming more certain that we
SHOULD be testing at each fill, now, even though the pumps here in Iowa
are clearly labeled. Well, a guy on a Cherokee 235 mail group has come
up with the following method to test for water AND alcohol at the same
time -- tell me what you think of this:
1. Put fuel in cup.
2. Add 1/4 of an alka-seltzer to fuel
3. If no fizz, no water OR alcohol is present.
I really like this method, as it's portable and doesn't require the use
of water. I plan on testing it on our next tank-full of car gas.
I'm no chemist, so I've got to ask: Does this method pass muster,
scientifically?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old July 18th 06, 03:47 PM posted to rec.aviation.piloting
Tri-Pacer[_1_]
.. Well, a guy on a Cherokee 235 mail group has come
1. Put fuel in cup.
Sportys sold a kit which consisted of a chemical that when added to the fuel
turned color if alcohol was present. I bought a number of kits some time
back and test each and every load. Very easy to do. I tested some gas while
in California that I knew had alcohol. Sure enough the fuel with the reagent
added, turned a deep purple letting me know the kit does work as advertised.
Unfortunately I don't see it advertised anymore.
Paul
N1431A
Old July 18th 06, 03:56 PM posted to rec.aviation.piloting
Jay Honeck wrote:
[snip]
1. Put fuel in cup.
[snip]
Jay,
Sorry if this is obvious, but...
Get some ethanol enhanced gas from a labeled pump and try it. If it
reacts to known alcohol and dosen't to know good gas, then it ought to
be OK.
John Stevens
(muttering: What do they teach in those schools...)
Old July 19th 06, 04:17 AM posted to rec.aviation.piloting
Viperdoc[_1_]
Jay:
In a previous life I was a chemistry major, and in fact went to graduate
school and worked as an chemist before moving on.
Your premise regarding the alka seltzer doesn't make much sense chemically.
In fact, the addition of the ethanol may increase the solubility of water in
the mix, since it is more polar than the normal hydrocarbons contained in
gasoline. However, it's been a long time, but if I find some Alka Seltzer we
can try it in my lab.
JN
Old July 19th 06, 04:37 AM posted to rec.aviation.piloting
Jose[_1_]
The difference between theory and practice is that in theory there is no
difference.
In practice, there is.
Jose
The monkey turns the crank and thinks he's making the music.
MoGas Tips, Tricks, Concerns, How To Al Gilson Owning 129 May 17th 06 08:20 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Testing Stick Ribs Bob Hoover Home Built 3 October 3rd 04 02:30 AM
