oil change durations
Old July 21st 06, 10:03 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default oil change durations
Having always changed the aeroshell 100 sae50 change in my c85 every 25
hours, I'm considering extending the aeroshell duration to maybe 35 hours.
My flights are in Florida and usually around an hour (or sometimes two) and
am currently burning/losing up to 1/2 quart per hour when filled to 3-1/4
quart line on the dipstick.
Of course I'm thinking about oil cost and feel like adding that oil each
flight hour does help it's cleanliness and service life.
Comments (be gentle G)?
Thanks, Dick
Old July 21st 06, 11:12 PM posted to rec.aviation.homebuilt
Morgans[_3_]
"Dick" wrote in message
news:rqawg.1329$K94.452@trnddc01...
and
Not as much as you would think, according to studies I have read.
The problem of "changing oil by adding lots more" is that the PH is screwed
up in what is left, and if you don't get rid of the oil that is too acid,
all it does is instantly change the oil you put in. Not to mention the bits
of metal and carbon, and other crap left in there.
If you think the engine is about shot, perhaps you go ahead and do it. Who
knows, though. You may do the last little bit of damage to the crank or cam
or a jug, to take it out of reparable tolerance. That would suck.
Jim in NC
Old July 22nd 06, 03:43 PM posted to rec.aviation.homebuilt
Stealth Pilot
On Fri, 21 Jul 2006 17:12:41 -0400, "Morgans"
and
Dick 3 1/2 quarts on the dipstick seems sus to me but I dont know what
the dipstick range is on the c85. on my O-200 I have ended a long
flight with that oil level and the engine rattled away quite
alarmingly. I fly with the oil up at 6 quarts and the engine is much
quieter(one of those quarts is in the oil radiator).
Short flights that dont boil off the moisture are supposedly the
killer. long flights will keep the oil free of water.
I've flown the oil for an entire year (75 hours) and it still came out
decidedly new looking. Australia mandates oil changes every 6 months.
....but then they mandate lots of other things that seem as silly.
If you want a long life out of your engine it needs to run like a
taxi. ie all day every day.
Stealth Pilot
Old July 21st 06, 10:15 PM posted to rec.aviation.homebuilt
Bill Daniels
At that oil burn rate, you are replacing the oil every 6 hous or so. I
wonder why oil changes are needed at all. Why not just change the filter?
(grin)
Seriously, I kept good records on my last airplane which included an
spectrographic analysis every oil change. Analysis of the results
consistently showed a sharp upturn in the contaminant levels at 50 hours oil
change intervals. This was atributed to the 'wearing out' of the anti-wear
additive package in new oil after 50 hours of use.
Bill Daniels
and am currently burning/losing up to 1/2 quart per hour when filled to
3-1/4 quart line on the dipstick.
Thanks, Dick
Old July 22nd 06, 06:23 PM posted to rec.aviation.homebuilt
R.W. Behan
Hey, Dick,
I'm a newbie/wannabe to this airplane biz, but I have a lot of experience
operating and maintaining a full-displacement, diesel powered tugboat.
My view: oil is cheaper than engines. My engine manufacturer, Cummins
Diesel, recommends changing oil at 500 hour intervals, in continuous-duty
(i.e., truck) applications. I change every 200, because we run the boat
only intermittently, and the capacity is three GALLONS. I can buy the oil
at Costco at a pretty good price, and don't object to the expense.
I suggest--urge--you to economize some other way.
Blue skies to you,
Dick Behan
Thanks, Dick
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
WARNING -- AOPA credit card holders. The credit card company is trying to change the rules in mid-game. Read the statement sent to you by MBNA. Chuck Owning 7 May 5th 05 09:01 PM
How do you explain why the A/S increases on thermal entry? Fred Soaring 43 April 24th 05 03:33 PM
