Fear
Old July 23rd 06, 08:57 PM posted to rec.aviation.piloting
minoad
Default Fear
I originally wrote this for a psychology group, therefore I have
written it for that crowd. However, I may have more luck with a
response in this group.
I noticed a strange thing today about myself. I am at least a
relativly intellegent and capable adult. Since a young age I have had
an interest in flying. I have finally gotten job that affords me the
income to pursue this interest. Because of this, last week I signed up
at a local flight school.
In the last week I have spent in excess of 20 hours on the simulators
and have completed more than half of my total required ground school.
Because of this I have a good understanding of the theory behind
aeronautics along with the do's and dont's.
The strange thing that I noticed is this. While on my first flight
today I expiereinced significant 'Fear' while in a climb of almost 50
degrees. This was my mistake as I had tried to trim before using the
yoke and had trimmed the wrong direction. My instructor smiled at me
and simply asked me to fix it.
I knew all was well. The readings were all fine. I had plenty of
altitude. I also had an instructor next to me with more than 8,000
hours flying expierience. Based on all this I knew I was fine.
I am curious why I was feeling fear givin all the above factors. Does
this mean I am simply not cut out for flying? Is thier a way to
short-circut this mecanism? Will this disappear with time? And most
importantly, why was my brain unable to overide my fear? I am
concerned that this may indicate a problem with me personally.
My only expierience with Psychology is through the course work that was
required in school. Any ideas would truly be appreciated and I thank
you in advance.
Micah A. Norman
Old July 23rd 06, 09:31 PM posted to rec.aviation.piloting
Bob Martin
Default Fear
A fifty degree climb? What are you flying?!
Seriously, though, the more you're exposed to it, you will gradually get
used to it and be able to go into more and more unusual situations. It
may take a while; you probably won't be able to get the license in forty
hours. But keep trying; as long as you still want to, you can
eventually work it out.
Old July 23rd 06, 09:52 PM posted to rec.aviation.piloting
Jim Macklin
Default Fear
I am very comfortable in an airplane at 35,000 feet or
higher. But I can't climb a ladder above the roof line, I
can't sit or stand in the picture window of a hotel room on
the 30th floor unless I move a couch in between me and the
window. Don't ask me to ride a Ferris wheel or roller
coaster.
Motorcycles are fine as long as I'm driving.
Always fly the yoke and trim the pressure to zero. Flying
with only the trim is an emergency procedure and must be
done very carefully. You were up dual and your instructor
saw you make the mistake. Learning from your own mistakes
is effective. But you didn't "feel in control" so you were
afraid. Intellectually you knew you'd be OK because the
instructor would save himself and you were along for the
ride. But YOU also knew you needed his help. Books and
simulators are not a substitute for real airplanes and real
stalls.
Have your instructor give you unusual attitude training,
including that same 50 degree nose high trim stall. Proof
to yourself that you can recover on your own and you'll
conquer the fear.
James H. Macklin
ATP,CFI,A&P
"minoad" wrote in message
have
with a
least a
age I have had
affords me the
week I signed up
simulators
ground school.
behind
first flight
of almost 50
before using the
smiled at me
plenty of
than 8,000
fine.
factors. Does
way to
time? And most
I am
personally.
work that was
and I thank
| you in advance.
| Micah A. Norman
Old July 24th 06, 02:14 AM posted to rec.aviation.piloting
zatatime
Default Fear
On Sun, 23 Jul 2006 15:52:50 -0500, "Jim Macklin"
factors. Does
You can know everything there is to know about something. Experience
is the real teacher, especially in a hands on hobby like flying. As
good as they are, simulators don't do much for helping get used to the
sense of flying.
Give it a few hours. I think you'll get used to it.
z
Old July 24th 06, 03:22 AM posted to rec.aviation.piloting
minoad
Default Fear
I thanks you all for the response. I will admit though that 50 degrees
may be a bit of an exageration... although it seemed more like 90
degrees at the time.
Old July 24th 06, 04:33 AM posted to rec.aviation.piloting
Jim Macklin
Default Fear
When you snip, but leave my name, you really should leave
something I wrote, Jim Macklin wrote nothing on the page
below.
James H. Macklin
ATP,CFI,A&P
"zatatime" wrote in message
| factors. Does
Experience
flying. As
used to the
| sense of flying.
| z
Old July 25th 06, 01:08 AM posted to rec.aviation.piloting
zatatime
Default Fear
On Sun, 23 Jul 2006 22:33:13 -0500, "Jim Macklin"
below.
This only happen because you top posted. Bottom posting would prevent
this from happening.
z
Old July 25th 06, 12:56 AM posted to rec.aviation.piloting
Jim Macklin
Default Fear
Then snip my name, I don't intend to change to bottom
feeding, er, posting.
| below.
would prevent
| z
Old July 24th 06, 08:25 AM posted to rec.aviation.piloting
Larry Dighera
Default Fear
On Sun, 23 Jul 2006 21:14:49 -0400, zatatime wrote in
When I see someone refer to GA flying as a hobby, it always makes me
cringe. To me, it means that the flight training of the pilot who
wrote it failed to truly ready the airman for assuming the command
role in flight as set forth in the federal regulations.
While there is usually great emphasis on learning the technical arcana
of flying, navigating, and metrology, it would appear that the
training failed to cause the airman to fully appreciate the
responsibility a Pilot In Command assumes for the lives of those over
whom he flies and his passengers.
If the flight student's mental outlook isn't fundamentally changed as
a result of his flight training, he probably doesn't really appreciate
the depth of that responsibility. And imagine how the layman feels
when he thinks hobby-pilots are noisily traversing the "sovereign"
airspace overhead, rather than a federally certified airman who
solemnly accepts his true command responsibility for the right to
exorcize the authority granted him by his airmans certificate.
If we refer to it as recreational flying, rather than a hobby, perhaps
the lay readers of this international forum will see that we airmen
take our responsibilities more seriously than mere hobbyists.
Old July 25th 06, 01:17 AM posted to rec.aviation.piloting
zatatime
Default Fear
On Mon, 24 Jul 2006 07:25:23 GMT, Larry Dighera
I understand your belief on how the word would be interpreted by
"lay-people."
My outlook on it though is one of a Very serious nature. I call it my
hobby because I don't get paid for it (even when people want to pay
me). I take flying as seriously as anyone I've met and fully
comprehend (and sometimes preach) the position of responsibility to
those of us who fly. I actually take my "hobby" more seriously than
my day job. From what I've seen in this forum over the past couple
years, it seems as though most are in line with my approach to flying
so within the forum I don't really see a need for distinction. When
talking to people outside aviation, work, friends, random occurrences,
etc... I don't think I actually use the word hobby, but I'll have to
pay more attention to really know if I do or not.
z
Soldiers Fear the Needle - The Pentagon still fights for its anthrax vaccine Roman Bystrianyk Naval Aviation 0 March 23rd 05 11:58 PM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
Fear of Flying Frequent Flyer Piloting 0 October 15th 04 05:30 AM
Bush prematurely left his Texas National Guard unit because nerves, fear and a possible drinking problem? Larry Dighera Piloting 10 October 4th 04 01:29 PM
Living In Fear Abroad - Welcome to Bush & Blair's More Dangerous World Matt Wiser Military Aviation 1 March 18th 04 06:41 PM
