I am building a BushCaddy which is very much like a Cub in appearance.
I have been searching for good quality Fuel Sight Gauges that get mounted in the cabin through the wing root. have been unable to locate anything so far. Does anybody have a source or lead? Thanks. Don... |
DonMorrisey wrote:
I am building a BushCaddy which is very much like a Cub in appearance. I have been searching for good quality Fuel Sight Gauges that get mounted in the cabin through the wing root. have been unable to locate anything so far. Does anybody have a source or lead? Thanks. Don... http://home.comcast.net/~nostromo56/ Vance Atkinson Sight Gauges.. common in Cozy/Long/Vari Eze type aircraft.. OR you can use 90 degree barbed fittings arranged vertically and use clear tubing between the two fittings in order to visualize fuel levels. OR.. http://www.aircraftspruce.com/catalo...fuel_gauge.php for a mechanical float style gauge as I've seen mounted in taildragger cessnas.. There have been some recent reports of problems with the Vance gauges in the homebuilding community that relates to the orfices "plugging" or sealing up... which while not PROVEN to be related to alcohol in fuel, is suspicious for such. The guys with the Vance Atkinson gauges in their planes swear by them, otherwise. Dave |
![]() DonMorrisey wrote: I am building a BushCaddy which is very much like a Cub in appearance. I have been searching for good quality Fuel Sight Gauges that get mounted in the cabin through the wing root. have been unable to locate anything so far. Does anybody have a source or lead? Thanks. Don... You can buy FAA/PMA sight gauges from Dakota Cub but they are super pricey. Same for Univair. I was able to buy the sight gauges that are used in the Smith Cubs. Excellent quality and less than half the price of others. They were listed on Koz Aero's website but I see they are no longer there. Go to www.supercub.org and do a search on "sight gauges" for more suggestions. |
My Savannah kit came with a preformed nylon tube used for this purpose.
I like it because it is simple and effective, and only has two joints; the points of attachment to the tank. The bends were heat formed, I guess. I don't know what grade of nylon is used, but it is sort of miky white, but gas is easy to see in it. Nylon is used in lots of fuel system parts in automobiles, so this seems like a good choise. tom DonMorrisey wrote: I am building a BushCaddy which is very much like a Cub in appearance. I have been searching for good quality Fuel Sight Gauges that get mounted in the cabin through the wing root. have been unable to locate anything so far. Does anybody have a source or lead? Thanks. Don... |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Q for Jim Weir or others: solid state fuel level probes? | Charlie England | Home Built | 11 | March 12th 04 12:35 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
