Hello,
since I was robbed of my ipaq 3970 running winpilot, i am looking for an alternative. 2nd hand ipaq's can be found but are relatively expensive compared with modern alternatives .(which have wifi , GPS etc..) I have been looking at the asus 636 and the mio P550 . Both have build in GPS , which can be usefull when the electrics of the glider die. The have no serial port however . Only HP still features serial ports to connect to , for example , your LX5000. The serial port can be usefull to download the flight log , connect to LX5000 for winpilot pro etc. However , serial ports are dissapearing slowly. The battery of the asus seems to be very good , however , an external 12V will propably be needed. Any experience around concerning -stability -GPS antenna reception -screen brightness ? Any alternatives ? Thanks Marc DG400 |
no PDA is perfect for all use
buy a second hand IPAQ 3850 or 3950 on eBay for your glider and the latest fancy mobile for yourself JW "marc_dg400" wrote in message ups.com... Hello, since I was robbed of my ipaq 3970 running winpilot, i am looking for an alternative. 2nd hand ipaq's can be found but are relatively expensive compared with modern alternatives .(which have wifi , GPS etc..) I have been looking at the asus 636 and the mio P550 . Both have build in GPS , which can be usefull when the electrics of the glider die. The have no serial port however . Only HP still features serial ports to connect to , for example , your LX5000. The serial port can be usefull to download the flight log , connect to LX5000 for winpilot pro etc. However , serial ports are dissapearing slowly. The battery of the asus seems to be very good , however , an external 12V will propably be needed. Any experience around concerning -stability -GPS antenna reception -screen brightness ? Any alternatives ? Thanks Marc DG400 |
The anchor is for use after you are through with the hooker
COLIN LAMB wrote: The anchor is for use after you are through with the hooker It's also useful to keep your boat from drifting in front of a barge while you are busy "interviewing" the hooker... 66 |
| LX20 + Ipaq wiring | Bruce | Soaring | 2 | February 4th 06 11:40 PM |
| Ipaq and Sunglasses | Ray Lovinggood | Soaring | 2 | June 27th 05 09:25 PM |
| Commercial - iPAQ Cradle Changes | Paul Remde | Soaring | 0 | April 9th 04 04:29 PM |
| iPaq wiring, cradles and mounts for gliders - Ideas?? | Jim Kelly | Soaring | 12 | December 5th 03 12:45 AM |
| iPAQ h2210/h2215 Review | Paul Remde | Soaring | 0 | September 3rd 03 04:45 AM |
