The adding of ethanol to gasoline has made the auto-gas STC unusable
for many aircraft owners, nationwide. So far, we're okay (in Iowa, which is pretty funny) and are able to purchase untainted mogas -- but the long-range situation seems untenable. We, as a nation, are inexorably being forced toward the addition of alcohol into ALL gasoline, so it seems... On the Cherokee 235 user's group, there is a guy who's been successfully using ethanol-gas in his aircraft. It's ruined his fiberglass tip tanks, but he apparently expected this to happen. Otherwise, the engine is running fine, or so he reports. (Personally, I think he's crazy, ruining tip tanks that run close to $4K *apiece*, but that's just me...) His experience has led to a more interesting (to me) discussion about the possibility of REMOVING ethanol from gasoline. Several ideas have been postulated (evaporation; heating; adding water), but none of them sound particularly safe or easy. Any chemists out there? Anyone know a way to remove the ethanol from mogas, so that we may safely use it in our aircraft? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message ups.com... The adding of ethanol to gasoline has made the auto-gas STC unusable for many aircraft owners, nationwide. So far, we're okay (in Iowa, which is pretty funny) and are able to purchase untainted mogas -- but the long-range situation seems untenable. We, as a nation, are inexorably being forced toward the addition of alcohol into ALL gasoline, so it seems... On the Cherokee 235 user's group, there is a guy who's been successfully using ethanol-gas in his aircraft. It's ruined his fiberglass tip tanks, but he apparently expected this to happen. Otherwise, the engine is running fine, or so he reports. (Personally, I think he's crazy, ruining tip tanks that run close to $4K *apiece*, but that's just me...) His experience has led to a more interesting (to me) discussion about the possibility of REMOVING ethanol from gasoline. Several ideas have been postulated (evaporation; heating; adding water), but none of them sound particularly safe or easy. Any chemists out there? Anyone know a way to remove the ethanol from mogas, so that we may safely use it in our aircraft? -- This was discussed a while back. While I'm not a chemist I would think that what came out of the removal process would have a completely unknown octane rating that would probably be lower than what went in. I also think "successfully using ethanol-gas" and "ruined his fiberglass tip tanks" really shouldn't be used in the same paragraph. |
mogas, so that we may safely use it in our aircraft? This was discussed a while back. While I'm not a chemist I would think that what came out of the removal process would have a completely unknown octane rating that would probably be lower than what went in. Really? Dang, I thought I had kept up here. I remember reading about TESTING for ethanol, but never removing it... Sorry about that. I also think "successfully using ethanol-gas" and "ruined his fiberglass tip tanks" really shouldn't be used in the same paragraph. Few planes have fiberglass tip tanks -- so I think his experience is a fairly valid test for many aircraft owners. It seems to be "running" just fine in his low-compression Lycoming O-540, which is exactly what you might expect from an old 1940's-era tractor engine. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
\ Few planes have fiberglass tip tanks -- so I think his experience is a fairly valid test for many aircraft owners. It seems to be "running" just fine in his low-compression Lycoming O-540, which is exactly what you might expect from an old 1940's-era tractor engine. Ethanol based fuels aren't entirely friendly to aluminum either, which is one of the reasons the STC forbids it. |
ECON 101
AvGas is available at X price MoGas is available at 3/4X price Cost to re-refine MoGas Y (why is a good choice of letter) Cost to repair damaged engine (each) $20,000. Cost to repair damaged fuel tanks, plumbing, pumps and seals, unknown. Cost of FAA violation of regulations, certificate suspension, a lot Cost of uninsured aircraft when your insurance is cancelled, priceless. -- James H. Macklin ATP,CFI,A&P "Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message ... | | "Jay Honeck" wrote in message | ups.com... | The adding of ethanol to gasoline has made the auto-gas STC unusable | for many aircraft owners, nationwide. So far, we're okay (in Iowa, | which is pretty funny) and are able to purchase untainted mogas -- but | the long-range situation seems untenable. We, as a nation, are | inexorably being forced toward the addition of alcohol into ALL | gasoline, so it seems... | | On the Cherokee 235 user's group, there is a guy who's been | successfully using ethanol-gas in his aircraft. It's ruined his | fiberglass tip tanks, but he apparently expected this to happen. | Otherwise, the engine is running fine, or so he reports. (Personally, | I think he's crazy, ruining tip tanks that run close to $4K *apiece*, | but that's just me...) | | His experience has led to a more interesting (to me) discussion about | the possibility of REMOVING ethanol from gasoline. Several ideas have | been postulated (evaporation; heating; adding water), but none of them | sound particularly safe or easy. | | Any chemists out there? Anyone know a way to remove the ethanol from | mogas, so that we may safely use it in our aircraft? | -- | | | This was discussed a while back. While I'm not a chemist I would think that | what came out of the removal process would have a completely unknown octane | rating that would probably be lower than what went in. | | I also think "successfully using ethanol-gas" and "ruined his fiberglass tip | tanks" really shouldn't be used in the same paragraph. | | |
![]() "Jim Macklin" wrote in message news:q0oCg.14$SZ3.7@dukeread04... ECON 101 AvGas is available at X price MoGas is available at 3/4X price Cost to re-refine MoGas Y (why is a good choice of letter) Cost to repair damaged engine (each) $20,000. Cost to repair damaged fuel tanks, plumbing, pumps and seals, unknown. Cost of FAA violation of regulations, certificate suspension, a lot Cost of uninsured aircraft when your insurance is cancelled, priceless. -- James H. Macklin ATP,CFI,A&P There is also the issue of performance. As I understand it, alcohol doesn't produce as much horsepower per volume as does avgas. If I use a mogas that has alcohol in it, I don't have the "Get up and GO" that I used to have. On that hot day at high altitude, over an obstacle, which takeoff performance chart do I use? Al G |
It's is like the guy who spent $25,000 on tools to build
furniture for his house, to save 25% on the furniture. During WWII the Army published flight manuals for fighters (and bombers) for different grades of fuel, 80/87, 91-96, 100/130 and 115/145 being refined. But some battlefields did not have supplies of all grades. So you might have a 54 In Hg. MAP with 115/145 and only 40 inches with 100/130. But what octane do you get from home refined mogas? -- James H. Macklin ATP,CFI,A&P "Al" wrote in message ... | | "Jim Macklin" wrote in message | news:q0oCg.14$SZ3.7@dukeread04... | ECON 101 | | AvGas is available at X price | MoGas is available at 3/4X price | Cost to re-refine MoGas Y (why is a good choice of letter) | Cost to repair damaged engine (each) $20,000. | | Cost to repair damaged fuel tanks, plumbing, pumps and | seals, unknown. | | Cost of FAA violation of regulations, certificate | suspension, a lot | Cost of uninsured aircraft when your insurance is cancelled, | priceless. | | -- | James H. Macklin | ATP,CFI,A&P | | There is also the issue of performance. As I understand it, alcohol | doesn't produce as much horsepower per volume as does avgas. If I use a | mogas that has alcohol in it, I don't have the "Get up and GO" that I used | to have. On that hot day at high altitude, over an obstacle, which takeoff | performance chart do I use? | | Al G | | |
![]() Jim Macklin wrote: It's is like the guy who spent $25,000 on tools to build furniture for his house, to save 25% on the furniture. During WWII the Army published flight manuals for fighters (and bombers) for different grades of fuel, 80/87, 91-96, 100/130 and 115/145 being refined. But some battlefields did not have supplies of all grades. So you might have a 54 In Hg. MAP with 115/145 and only 40 inches with 100/130. But what octane do you get from home refined mogas? Not all grades could be used in all engines. 80/87 was not under any circumstances allowed in many of the bigger engines. And use of 115/145, as was done after WWII (the Navy even ran its jets on the stuff up through the middle of the Korean War, limiting range and coating the tailpipes with a lethal (to ground handlers) gray gunk!) was tough on the Lycomings and Continentals and the gas engines in ramp equipment. |
"Al" wrote: There is also the issue of performance. As I understand it, alcohol doesn't produce as much horsepower per volume as does avgas. If I use a mogas that has alcohol in it, I don't have the "Get up and GO" that I used to have. On that hot day at high altitude, over an obstacle, which takeoff performance chart do I use? Today's Wall Street Journal has an chart of pickup trucks and cars and gas milage with gasoline and E85. Gas E85 Gas E85 Annual E85 Costs+ City City Hwy HWy Cost /Savings- Chevy Silverado 1500 AWD 15 11 19 14 $2813 -$10 Chevy Impala 21 16 31 23 $1877 +$40 Chevy Tahoe 1500 AWD 14 11 18 14 $2813 +$223 Ford Crown Victoria 17 12 25 18 $2250 +$353 Ford F150 FFV AWD 14 10 18 13 $3002 +$311 based on 45% highway/55% city, 15,000 mpy |
On Wed, 09 Aug 2006 18:00:55 GMT, john smith wrote:
Chevy Silverado 1500 AWD 15 11 19 14 $2813 -$10 That's the one that got me. Why does the Silverado do better on E85 than on gasoline? (Since the final figure is "cost", a minus figure is a savings.) -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com In Search of Lost Time: www.readingproust.com |
Ethanol & capacitance fuel-level sensors | Adam Aulick | Home Built | 4 | May 20th 06 03:28 PM |
The effects of Ethanol on... | ventus2 | Home Built | 35 | May 8th 06 05:45 AM |
MoGas users: Ethanol replacing MTBE | John | Piloting | 167 | May 5th 06 08:31 PM |
Ethanol Mandate for Iowa? | Jay Honeck | Piloting | 155 | October 4th 05 03:17 PM |
Ethanol Powered Airplane Certified In Brazil | Victor | Owning | 4 | March 30th 05 09:10 PM |
