12 to 24v up-converter
Old August 9th 06, 11:36 PM posted to rec.aviation.homebuilt
ccwillwerth
Default 12 to 24v up-converter
I am trying to build the Jim Weir/Kitplanes June-06 "Quick and Dirty 12 - 24
Up-Converter."
1. Can D101 and Q101share the same heat sink electrically or must they be
isolated?
2. I can not locate a "resistor form." Can R101 be wound around a dowel
or other object and installed like a coil with an air core?
Thanks, Charlie Willwerth
Old August 10th 06, 01:17 AM posted to rec.aviation.homebuilt
RST Engineering
"ccwillwerth" wrote in message
24 Up-Converter."
Um, that would be the JULY 06 issue.
be isolated?
Q101 has its collector tied to the case but D101 has its cathode tied to the
case. Sorry, you have to have two heat sinks.
dowel or other object and installed like a coil with an air core?
Oh, golly, just get yourself a relatively high value 1/4 or 1/2 watt carbon
resistor (say, anything greater than 100 ohms or so) and wind the wire on
it. #30 wire will NOT stay put with air core. Sorry, I just assume (bad,
bad word) folks know the trick of winding wire on resistors just for the
form factor. Solder the wire to the resistor leads right where they come
out of the resistor body and then solder the resistor leads into the
circuit.
Old August 10th 06, 03:11 AM posted to rec.aviation.homebuilt
ccwillwerth
Thanks Jim, Neat trick about the "resistor form" i learned something new!
Charlie
"RST Engineering" wrote in message
24 Up-Converter."
be isolated?
the case. Sorry, you have to have two heat sinks.
carbon resistor (say, anything greater than 100 ohms or so) and wind the
wire on it. #30 wire will NOT stay put with air core. Sorry, I just
assume (bad, bad word) folks know the trick of winding wire on resistors
just for the form factor. Solder the wire to the resistor leads right
where they come out of the resistor body and then solder the resistor
leads into the circuit.
KLN to Garmin 396 Converter Mike Granby Owning 7 February 5th 06 01:48 PM
FA: 12V to 24V DC voltage converter Karl Geng, N1DL Home Built 2 April 21st 05 08:48 PM
AC to DC Converter for APU Newps Owning 8 November 30th 04 03:41 PM
24/12 volt DC converter Victor J. Osborne, Jr. Products 1 February 18th 04 02:11 PM
Radio Shack 140W DC-to-AC Power Converter - Simple Plug-in MKB Owning 4 August 4th 03 04:08 PM
