Pease 2 Departure at KPSM
Old July 15th 04, 11:59 AM
Ron Rosenfeld
Default Pease 2 Departure at KPSM
What is the reason for the Obstacle (Jepp) or Note (NACO) for Rwy 34 about
crossing the threshold at or above 10' AGL.
Is it for certain heavily loaded military a/c?
Under what sort of circumstances would it come into play?
Or is there something else I'm missing here?
Old July 15th 04, 04:49 PM
Ron Rosenfeld
On Thu, 15 Jul 2004 06:59:37 -0400, Ron Rosenfeld
Oops that should be "departure end"
Old July 16th 04, 02:38 AM
J Haggerty
When the DP is created, the specialist has to initially assume aircraft
will cross DER at 0' and build the procedure with no crossing
restriction, even though 35' is standard for civil aircraft.
If they run into obstacles when building the procedure with a 0' DER
crossing elevation, they can place a crossing restriction at the DER of
as much as 35', thus alleviating the amount of penetration of the
obstacle clearance slope (OCS) as they can, which can sometimes result
in either no more penetration, or at least a lower climb gradient
needing to be published.
If they do this, then they need to put a comment on the DP file showing
how much of that 35' they used.
Although the crossing restriction used in building the procedure is
added to the FAA forms that support the procedure, they're not usually
published; but how to treat the restriction has been going back and
forth a few times, so it may have slipped through during a period of
time they were being published. On the other hand, it could be there
because the military asked for it to be there, since they don't
automatically apply a 35' DER restriction like civil pilots are supposed
to. In that case, they need to know that the crossing restriction is
there so they can limit their takeoff weight to meet the restriction.
It used to be scary watching the old "A" model C-135's taking off on a
refueling rendezvous, they used every bit of the runway to get airborne
sometimes.
Bridgeport, CT also has the DER restrictions published.
JPH
Old July 16th 04, 02:52 AM
Ron Rosenfeld
On Thu, 15 Jul 2004 20:38:24 -0500, J Haggerty
sometimes.
Thank you for that information. Verrry interesting.
I looked at BDR. That's where I learned instruments, back in the '70's.
If that DER was there then, it was not pointed out to me in my instrument
training.
I find it interesting that the published DER restriction is 35' for one of
the runways. That seems redundant since that's what we use, anyway.
Interesting Departure Procedu MRB Trixy Two Richard Kaplan Instrument Flight Rules 26 February 18th 04 11:42 PM
Comm1 IFR and Departure Clearance Training FOR SALE Curtis Instrument Flight Rules 0 November 13th 03 08:26 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
