Many moons ago, (early to mid-eighties), I was reading quite a bit of
material about the "new" composite airplane revolution and how different life was going to be with the ability to make planes from the fantastic substance. The main concern from the "experts" in many of these articles was that they didn't know how the composite materials would hold up over time. It seems that many folks thought that after years of sun exposure and/or heat/freeze cycles, the materials might become brittle or degrade in strength. Now, obviously, I realize that there aren't many Long-EZ's falling out of the sky and that many of the new methods are more advanced than the first tries, but I was wondering how 25+ years has faired on these planes? Was this fear just a crazy thought or was there some validity to the concern that has reared its ugly head now that we've had some time to look back? jf |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:AvWdnQSRlpgvFUPZnZ2dnUVZ_sWdnZ2d@wideopenwest .com... "Jeff" jfranks1971 minus wrote in message ... Many moons ago, (early to mid-eighties), I was reading quite a bit of material about the "new" composite airplane revolution and how different life was going to be with the ability to make planes from the fantastic substance. The main concern from the "experts" in many of these articles was that they didn't know how the composite materials would hold up over time. It seems that many folks thought that after years of sun exposure and/or heat/freeze cycles, the materials might become brittle or degrade in strength. Now, obviously, I realize that there aren't many Long-EZ's falling out of the sky and that many of the new methods are more advanced than the first tries, but I was wondering how 25+ years has faired on these planes? Was this fear just a crazy thought or was there some validity to the concern that has reared its ugly head now that we've had some time to look back? You can get $20,000 for a glass glider built in the '70's. Does that answer your question? http://www.wingsandwheels.com/wantads1.htm -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Yes, it now appears that composite gliders will outlast metal ones. The gelcoat will degrade but the underlying structure seems to last forever. |
![]() Yes, it now appears that composite gliders will outlast metal ones. The gelcoat will degrade but the underlying structure seems to last forever. be careful, guys; you have to distinguish: one thing is the gelcoat. it protects the fiberglass (or carbon) structure underneath from UV light which harms the epoxy resin. regular gelcoat is not resistant to UV light forever; cracks in the gelcoat work their way into the laminate. a while ago, i had to repair the outer layer of glass of a fiberglass wing just because of that. the problem appears especially when the gelcoat (or filler, when using automotive paint) is very thick, making the surface or paint layer too stiff to follow the fiberglass' strains, which results in cracks. another thing is the structure itself. as mentioned above, it's strength can be affected e.g. by UV light and it has to be protected against. if this protection is maintained, and the structure had been designed and calculated in a correct way, fatigue is not really an issue, and the material's strength remains. aluminum is much worse... uli |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:AvWdnQSRlpgvFUPZnZ2dnUVZ_sWdnZ2d@wideopenwest .com... You can get $20,000 for a glass glider built in the '70's. Does that answer your question? Honestly, no. If you go to a gliderport, you won't see many gliders tied out in full sunlight as is common with airplanes. Usually they are disassembled and stashed away in covered trailers specifically to protect their expensive finish from the degrading effects of the sun. That said, if you find an old G109 motorglider tied out at an airport, (it looks like an airplane with long wings) you are possibly looking at a composite aircraft that has actually survived decades in full sunlight, and done so quite well. Vaughn |
"Vaughn Simon" wrote in message
... "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:AvWdnQSRlpgvFUPZnZ2dnUVZ_sWdnZ2d@wideopenwest .com... You can get $20,000 for a glass glider built in the '70's. Does that answer your question? Honestly, no. If you go to a gliderport, you won't see many gliders tied out in full sunlight as is common with airplanes. Usually they are disassembled and stashed away in covered trailers specifically to protect their expensive finish from the degrading effects of the sun. That said, if you find an old G109 motorglider tied out at an airport, (it looks like an airplane with long wings) you are possibly looking at a composite aircraft that has actually survived decades in full sunlight, and done so quite well. Vaughn So much for the quick and easy smart ass version of the answer... On the other hand, if you go down to your local boat yard, you should not have any trouble finding fiberglass stuctures that have been outside in the sun and weather since the 1960's and are holding up just fine. Some of them will look like doo-doo because, well, gel coat just doesn't hold up over years of exposure without regular buffing and waxing. Having owned 30 year old fiberglass boats, I have: A) Learned to hate fiberglass (it itches). B) Learned that the basic laminate holds up just fine. C) Learned that wood cores, secondary joints and gel coat is where you find problems. They can be repaired, but refer back to lesson A). Going back to the original post in this thread: The main concern from the "experts" in many of these articles was that they didn't know how the composite materials would hold up over time. It seems that many folks thought that after years of sun exposure and/or heat/freeze cycles, the materials might become brittle or degrade in strength. I would argue that composite structures, like just about any other, seem to be holding up OK, but they have their advantages and their disadvantages. Gel coat sucks, but even paint needs to be re-done every once and a while, eh? Keep it out of the sun, and the finish lasts a lot longer in either case. Fatigue is an issue with both composit and aluminium strucures, Corrosion is a problem with aluminuim, secondary bonds can be a problem with composites. If you keep up with the maintaince you are a lot better off than if you let it go and try to "restore" a P.O.S. (Airplanes or boats, no matter what the primary structual material is.) Personally, I like wood. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
... Honestly, no. If you go to a gliderport, you won't see many gliders tied out in full sunlight as is common with airplanes. Usually they are disassembled and stashed away in covered trailers specifically to protect their expensive finish from the degrading effects of the sun. That said, if you find an old G109 motorglider tied out at an airport, (it looks like an airplane with long wings) you are possibly looking at a composite aircraft that has actually survived decades in full sunlight, and done so quite well. Vaughn I think you are missing the simple stuff....... If you go to an Airport, you won't see many composite airplanes tied out in the open. They are almost universally hangared, which I might add is a better climate than a trailer in the sun, on the line at Minden, Cal City or any of the other great soaring spots. I believe 30 year old sailplanes in trailers are directly comparable to hangared composite aircraft, and the use of a hangar is BETTER for the airframe than a trailer in regards to control of temperatures inside the box. Early composite sailplanes remain airworthy despite the use of rolling ovens, a risk composite airplanes are not subjected too. Scott. |
Newbie holding questions | JohnK | Instrument Flight Rules | 106 | January 14th 06 09:44 AM |
Holding pattern reporting | Yossarian | Instrument Flight Rules | 14 | July 4th 05 10:57 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
Defining Composites (long) | B Lacovara | Soaring | 1 | September 13th 03 08:04 PM |
