I am considering upgrading the starter in my 182P Skylane with the new
Sky-Tec flyweight starter. It looks like it will spin the prop faster -w- less power. Does anyone have experience with the Sky-Tec flyweight starter in an O-470 engine? Guy Byars |
Do not get the lightweight starters without also replacing the starter
adapter with the model that works with these type starters. Call Niagara Airparts and they will explain it all. Guy Byars wrote: I am considering upgrading the starter in my 182P Skylane with the new Sky-Tec flyweight starter. It looks like it will spin the prop faster -w- less power. Does anyone have experience with the Sky-Tec flyweight starter in an O-470 engine? Guy Byars |
I'm not sure I understand, the flyweight starter from Sky-Tec is a bolt on
replacement for the original. What adapter are you talking about? "Newps" wrote in message . .. Do not get the lightweight starters without also replacing the starter adapter with the model that works with these type starters. Call Niagara Airparts and they will explain it all. Guy Byars wrote: I am considering upgrading the starter in my 182P Skylane with the new Sky-Tec flyweight starter. It looks like it will spin the prop faster -w- less power. Does anyone have experience with the Sky-Tec flyweight starter in an O-470 engine? Guy Byars |
The starter bolts to the starter adapter. When you turn the key the
starter spins the adapter which in turn spins the engine. The new starter operates a little differently from the original. The difference is in how it engages and disengages. Lightweight starter and standard starter adapter do not work for very long. You're right they bolt right up but they don't play well for long. Guy Byars wrote: I'm not sure I understand, the flyweight starter from Sky-Tec is a bolt on replacement for the original. What adapter are you talking about? "Newps" wrote in message . .. Do not get the lightweight starters without also replacing the starter adapter with the model that works with these type starters. Call Niagara Airparts and they will explain it all. Guy Byars wrote: I am considering upgrading the starter in my 182P Skylane with the new Sky-Tec flyweight starter. It looks like it will spin the prop faster -w- less power. Does anyone have experience with the Sky-Tec flyweight starter in an O-470 engine? Guy Byars |
![]() Newps wrote: The starter bolts to the starter adapter. When you turn the key the starter spins the adapter which in turn spins the engine. The new starter operates a little differently from the original. The difference is in how it engages and disengages. Lightweight starter and standard starter adapter do not work for very long. You're right they bolt right up but they don't play well for long. Guy Byars wrote: I'm not sure I understand, the flyweight starter from Sky-Tec is a bolt on replacement for the original. What adapter are you talking about? "Newps" wrote in message . .. Do not get the lightweight starters without also replacing the starter adapter with the model that works with these type starters. Call Niagara Airparts and they will explain it all. On the O-470 the starter is always engaged, and a coil spring clutch acts as a one-way drive . What would the new drive adapter have that's different? We put a Lamar starter on an O-470, and it was so gutless that we ended up buying another old Prestolite to replace it. Those permanent magnets are only so powerful. I think the Skytecs or Magnaflites might be better; we use Magnaflites on three 172s and they work OK. Dan |
![]() wrote in message ups.com... On the O-470 the starter is always engaged, and a coil spring clutch acts as a one-way drive . What would the new drive adapter have that's different? We put a Lamar starter on an O-470, and it was so gutless that we ended up buying another old Prestolite to replace it. Those permanent magnets are only so powerful. I think the Skytecs or Magnaflites might be better; we use Magnaflites on three 172s and they work OK. Dan The starter adapter is always engaged; the starter only turns when energized, which in turn causes the coil spring clutch to clamp onto the starter adapter shaft and turn the engine. I think the problem comes from the lightweight starter (planetary drive gear) not stopping quickly after being de-energized which causes the spring to stay clamped and causes wear. Allen |
There are two types of Continental starter adapters for O-470 engines. 1)
What Niagra calls the "classic" version, needs a starter that is able to turn freely when not energized, since the adapter must "unwind" a bit after the engine starts. Such a starter adapter has been reported to have problems with the older Sky-Tec starter for Cont. O-470's, C12ST1. The newer Sky-Tec starter for Continentals, C12ST3 is supposed to solve this problem, as this starter's output shaft can be turned by hand, in either direction, when not energized. 2) The newer Continental starter adapter is described in Cont. Service Bulletin M92-10. It "may" have been happy with the older Sky-Tec starter (I don't know) and I don't know if Sky-Tec still sells the ST1, since it now has the ST3. Continental's Service Information Letter SIL02-4 describes a newer starter that sounds like it works like the Sky-Tec ST1. I wouldn't want to use such a starter with the "classic" starter adapter - a lot of which adapters are still in service. How does one know which kind of starter adapter they have? The SB M92-10 says the newer adapter may exhibit varying degrees of resistance to propellor rotation in the direction opposite to normal engine cranking rotation. I don't think the "classic" adapter exhibits such resistance. wrote in message ups.com... Newps wrote: The starter bolts to the starter adapter. When you turn the key the starter spins the adapter which in turn spins the engine. The new starter operates a little differently from the original. The difference is in how it engages and disengages. Lightweight starter and standard starter adapter do not work for very long. You're right they bolt right up but they don't play well for long. Guy Byars wrote: I'm not sure I understand, the flyweight starter from Sky-Tec is a bolt on replacement for the original. What adapter are you talking about? "Newps" wrote in message . .. Do not get the lightweight starters without also replacing the starter adapter with the model that works with these type starters. Call Niagara Airparts and they will explain it all. On the O-470 the starter is always engaged, and a coil spring clutch acts as a one-way drive . What would the new drive adapter have that's different? We put a Lamar starter on an O-470, and it was so gutless that we ended up buying another old Prestolite to replace it. Those permanent magnets are only so powerful. I think the Skytecs or Magnaflites might be better; we use Magnaflites on three 172s and they work OK. Dan |
More Skytec starter woes | [email protected] | Owning | 4 | December 1st 05 08:24 PM |
Recoil starters on small 2-stroke engines | [email protected] | Home Built | 17 | February 26th 05 01:35 PM |
SkyTec Starter sticking? | [email protected] | Owning | 10 | November 10th 04 10:00 PM |
Engine starters in the J41 | Matthias Lieberecht | General Aviation | 0 | July 16th 03 09:32 PM |
