![]() Introduction - Powerplant Choices RV aircraft are designed to use Lycoming aircraft engines. The RV-4 and RV-6/6A use 150/160 hp 0-320 or 180 hp 0-360 engines. The RV-7/7A and RV-8/8A can accommodate O-320, O-360 or angle valve IO-360 (200 hp) engines. The RV-9/9A is suitable for Lycoming engines in the 118 hp to 160 hp range. The engine used in the 4-place RV-10 is the Lycoming IO-540D4A5 rated at 260 hp. Van's recommendation for the 4 place includes any of the parallel valve 540's which are available from 235hp on up to the 260hp version. These engines are the most readily available, affordable, and reliable of the possible choices. Other aircraft engines of similar configuration, weight and power might possibly be used, but only the Lycoming will fit the mounts and cowls supplied with our kits. Van's volume allows us to buy appropriate models of new engines at O.E.M. (Original Equipment Manufacturer) prices direct from Lycoming. We market these engines to our customers at far less than list price. This makes them an affordable alternative, even when compared to the traditional used engine. Van's has similar arrangements with Hartzell Propeller, Sensenich Propeller and other manufacturers. Other Engines We are often asked about using non-aircraft engine conversions. We'd like to pass along a quote from a colleague in the homebuilt airplane business: "the best conversion I know is to take $8000 and convert it into a good used Lycoming." This may sound a bit narrow-minded, but it reflects the basic truth: no non-aircraft engine has yet proven to be as reliable, available, and inexpensive (everything considered) as a traditional aircraft engine. It seems that magazines are always printing stories about automobile engines bought for junkyard prices, mated to inexpensive reduction drives and flown off into the sunset. It simply doesn't work like that in the real world. The reliability we have come to expect from aircraft engines is the result of years of development and refinement of engines designed specifically for the task. Automobile engines function well in their intended application: delivering low cruising power in vehicles with well designed transmissions and power trains. Using them successfully in an airplane requires continuous high power outputs and reduction systems coupled to the propeller. This is completely foreign to their design intent. (You can imagine the car engine designer banging his head slowly against his desk..."no, no, no. If I'd known you wanted to do that with it, I would have designed something different....) (Why are Lycomings never found in boats, fire pumps, gensets or other high output and often life-critical applications? They are less reliable intrinsically than commodity powerplants, and secondarily ridiculously priced.) With enough research and development effort, auto engines may be made to work acceptably or even well in an airplane. We are not opposed, in principle, to RV builders using alternate engines, but we would hope that this choice is made on facts, not hopes or dreams. Do you want to spend your time and effort on engine development or do you want to fly confidently behind an engine that has already been developed? (Using that logic why should I spend more money to build your noncertified, and presumably intrinsically uncertificatable by design, airframe when less will buy me a PROVEN, certificated aircraft? ) We, too, would like to see "something better" in available powerplants. We are carefully watching some alternatives. Meanwhile, the proven Lycomings do the job very well and are the best "available now" option. Despite the many claims and promises made by promoters, we feel that if you will look closely at what is actually available, how many are really flying, and how well they really perform, you will agree with our conclusions. (Not "you may" agree, "YOU WILL". Ja wohl Mein Führer! With all due disrespect, Dick, I don't think you really would like to see any other powerplant succeed because one, you have a sweetheart deal with Lycoming, and two, you want your RVs to be alike as production aircraft to fluff resale and insurability without the bother of type certification and production. This is called "the tragedy of the commons" or "why buy the cow if all those heifers will come to you for you to milk the living daylights out of and they will buy you breakfast too".) While we are not opposed to RV builders installing alternate engines, we simply cannot recommend or encourage the installation of any other engine - we don't feel it would best serve the interest or safety of the builder. (It wouldn't serve OUR interest.) |
![]() Bret Ludwig wrote: (Not "you may" agree, "YOU WILL". Ja wohl Mein Führer! Godwin PLONK |
![]() Richard Riley wrote: Bret Ludwig wrote: (Not "you may" agree, "YOU WILL". Ja wohl Mein Führer! Godwin PLONK Richard Riley=HITLER PLONK, you stupid moron! |
On 16 Aug 2006 11:19:23 -0700, "Bret Ludwig"
wrote: My armored infantry outfit drove all over south Germany in T-18 Armored personnel carriers which were powered by a big jesus Continental 6 cylinder, horizontallyl opposed engines, worked pretty good. |
The problem with the guys putting in the V-8's is they are leaving out
the FOUR ON THE FLOOR. I'm gonna put in a CORVETT firebreathing turbocharged chrome plated V-8, and by gum, it's gonna have a bitchin' FOUR ON THE FLOOR!!! So there you have it. Auto conversions work great on planes, but you gotta have the four on the floor, by gum.... |
![]() Doug wrote: The problem with the guys putting in the V-8's is they are leaving out the FOUR ON THE FLOOR. I'm gonna put in a CORVETT firebreathing turbocharged chrome plated V-8, and by gum, it's gonna have a bitchin' FOUR ON THE FLOOR!!! So there you have it. Auto conversions work great on planes, but you gotta have the four on the floor, by gum.... The Corvette has SIX. |
Bret Ludwig wrote:
Automobile engines function well in their intended application: delivering low cruising power in vehicles with well designed transmissions and power trains. Using them successfully in an airplane requires continuous high power outputs and reduction systems coupled to the propeller. This is completely foreign to their design intent. Join me for a drive in the off-peak hours on the Autobahn and then tell me again that auto engines can't stand continuous high power output. In German, there's even a word for that: "vollgasfest", roughly "full-throttle safe", indicating that an engine is fit for continuous operation at full throttle. Engines that aren't full-throttle safe don't sell in Germany and are cause of ridicule, as FIAT had to learn the hard way. Anno. |
Are the comments in parentheses yours? It's kind of hard to tell who wrote
what. In any case, I know of at one Lycoming engine designed for a boat. I think it was used in the 1930s. "Bret Ludwig" wrote in message ups.com... Introduction - Powerplant Choices RV aircraft are designed to use Lycoming aircraft engines. The RV-4 and RV-6/6A use 150/160 hp 0-320 or 180 hp 0-360 engines. The RV-7/7A and RV-8/8A can accommodate O-320, O-360 or angle valve IO-360 (200 hp) engines. The RV-9/9A is suitable for Lycoming engines in the 118 hp to 160 hp range. The engine used in the 4-place RV-10 is the Lycoming IO-540D4A5 rated at 260 hp. Van's recommendation for the 4 place includes any of the parallel valve 540's which are available from 235hp on up to the 260hp version. These engines are the most readily available, affordable, and reliable of the possible choices. Other aircraft engines of similar configuration, weight and power might possibly be used, but only the Lycoming will fit the mounts and cowls supplied with our kits. Van's volume allows us to buy appropriate models of new engines at O.E.M. (Original Equipment Manufacturer) prices direct from Lycoming. We market these engines to our customers at far less than list price. This makes them an affordable alternative, even when compared to the traditional used engine. Van's has similar arrangements with Hartzell Propeller, Sensenich Propeller and other manufacturers. Other Engines We are often asked about using non-aircraft engine conversions. We'd like to pass along a quote from a colleague in the homebuilt airplane business: "the best conversion I know is to take $8000 and convert it into a good used Lycoming." This may sound a bit narrow-minded, but it reflects the basic truth: no non-aircraft engine has yet proven to be as reliable, available, and inexpensive (everything considered) as a traditional aircraft engine. It seems that magazines are always printing stories about automobile engines bought for junkyard prices, mated to inexpensive reduction drives and flown off into the sunset. It simply doesn't work like that in the real world. The reliability we have come to expect from aircraft engines is the result of years of development and refinement of engines designed specifically for the task. Automobile engines function well in their intended application: delivering low cruising power in vehicles with well designed transmissions and power trains. Using them successfully in an airplane requires continuous high power outputs and reduction systems coupled to the propeller. This is completely foreign to their design intent. (You can imagine the car engine designer banging his head slowly against his desk..."no, no, no. If I'd known you wanted to do that with it, I would have designed something different....) (Why are Lycomings never found in boats, fire pumps, gensets or other high output and often life-critical applications? They are less reliable intrinsically than commodity powerplants, and secondarily ridiculously priced.) With enough research and development effort, auto engines may be made to work acceptably or even well in an airplane. We are not opposed, in principle, to RV builders using alternate engines, but we would hope that this choice is made on facts, not hopes or dreams. Do you want to spend your time and effort on engine development or do you want to fly confidently behind an engine that has already been developed? (Using that logic why should I spend more money to build your noncertified, and presumably intrinsically uncertificatable by design, airframe when less will buy me a PROVEN, certificated aircraft? ) We, too, would like to see "something better" in available powerplants. We are carefully watching some alternatives. Meanwhile, the proven Lycomings do the job very well and are the best "available now" option. Despite the many claims and promises made by promoters, we feel that if you will look closely at what is actually available, how many are really flying, and how well they really perform, you will agree with our conclusions. (Not "you may" agree, "YOU WILL". Ja wohl Mein Führer! With all due disrespect, Dick, I don't think you really would like to see any other powerplant succeed because one, you have a sweetheart deal with Lycoming, and two, you want your RVs to be alike as production aircraft to fluff resale and insurability without the bother of type certification and production. This is called "the tragedy of the commons" or "why buy the cow if all those heifers will come to you for you to milk the living daylights out of and they will buy you breakfast too".) While we are not opposed to RV builders installing alternate engines, we simply cannot recommend or encourage the installation of any other engine - we don't feel it would best serve the interest or safety of the builder. (It wouldn't serve OUR interest.) |
![]() "Steve Foley" wrote in message news:F4KEg.3078$df.1829@trndny06... Are the comments in parentheses yours? It's kind of hard to tell who wrote what. In any case, I know of at one Lycoming engine designed for a boat. I think it was used in the 1930s. Lycomings are used in airboats all the time in Florida. And Van's aircraft built one of their RV-10s with a Continental. ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
"JJS" jschneider@remove socks cebridge.net wrote in message
... "Steve Foley" wrote in message news:F4KEg.3078$df.1829@trndny06... Are the comments in parentheses yours? It's kind of hard to tell who wrote what. In any case, I know of at one Lycoming engine designed for a boat. I think it was used in the 1930s. Lycomings are used in airboats all the time in Florida. And Van's aircraft built one of their RV-10s with a Continental. This is an old wooden boat with an inboard marine engine built by Lycoming. It's not an aircraft engine. ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Look at Van's Blather here. | Bret Ludwig | Piloting | 37 | August 19th 06 12:49 AM |
Very Nice Van's RV-6A For Sale | Don | Aviation Marketplace | 3 | January 14th 06 12:13 AM |
Vans RV-11 | Scott Correa | Soaring | 27 | January 5th 04 07:56 AM |
bulding a kitplane maybe Van's RV9A --- a good idea ????? | Flightdeck | Home Built | 10 | September 9th 03 07:20 PM |
Vans RV4 or RV6 wanted | Joe | Home Built | 0 | August 17th 03 01:02 PM |
