Reliability and Clubs...
Old August 23rd 06, 04:18 AM posted to rec.aviation.piloting
Default Reliability and Clubs...
I've been renting from the local flying club.
In the last five flights I've had 4 issues /maintance problems.
1Pilots PTT switch fails on 3 hour cross country, hand mic inop.
Finished flight using copilots mic jack and PTT.
2)Alternator charge indicator fails. maintance ended up replacing the
alternator.
3)Found cracked cowl on 172 , the fiberglass cowl ring just behind
the spinner was cracked 3/4 of the way around and about to come loose.
4)Took off in 172 to finish my IPC tonight and at 700 feet just off
the end of the runway the engine lost power for the longest 5 seconds
of my life. Returned to the field did a hard runup all normal.
After parking the plane I drained several cups of gas from both wing
tanks and the gas sump under the engine.
No dirt, no water the fuel is perfect.
The Fuel seector was on both and in place.
The primer was locked. (first thing I checked)
Am I just having a run of bad luck, or is this normal for older (mid
70's well used airplanes. All of this really makes me want to buy my
own plane,
I fear that I will be jumping out of the frying pan into the fire.
How long does take to get the bugs and issues worked out of an
older plane once purchased...
a)Never,
b)Its always perfect
c)Somewhere in between?
Lastly in a case of an issue like #4 what do you do if the mechanic
doesn't find anything?
Old August 23rd 06, 05:46 AM posted to rec.aviation.piloting
Don Tuite
own plane,
Ha!
Yep.
a)Never,
I was talking to the guy we sold our club '61 172 to about a month
ago. There'd been an issue of a tiny oil leak around the accessory
case when he bought it. He said something along the lines of, "I
finally took everything off to get at that drip. Now the tube that
lubricates the top end of cylinder so-and-so is gushing oil."
Something had got loose and floated downstream, I guess.
Us old silverbacks, we look for a medical doctor around our own age.
The new guys/gals may be more current on the latest procedures, but
sometimes you have to factor in the age of the patient.
So, is a new plane better? Let's talk about "infant mortaility" as it
relates to failure rates.
It's a crapshoot, but one thing is certain. If a 172 gets used almost
exclusively for primary training, it'll need a lot of maintenance.
Don (Nobody in our club has done primary training for 20 years. That
was an extremely well caref-for 172, a lovingly maintained plane, but
it is defnitely a mature bird.)
Old August 23rd 06, 09:04 AM posted to rec.aviation.piloting
Peter Duniho
own plane
An engine failure is certainly NOT normal, for any properly maintained
airplane.
The airplane you describe is certainly below the quality of any airplane
I've ever rented, and that includes a well-aged 1950's era 172 I ran into in
southwest Virginia ten or so years ago (actually, aside from being
cosmetically inferior, that plane was a pretty nice one to fly).
Seems to me that, at the very least, you need to find somewhere else to rent
from. Individually, the first two items on your list sound like reasonably
normal "could have happened to anyone" sorts of things, but the third and
fourth are just plain wrong. Taken together, they imply some significant
neglect of the airplane.
Depends on whether you have enough cash on hand to take care of problems.
a)Never,
Define "bugs". Any mechanical device, including an airplane, requires
maintenance. Things wear out and eventually fail. You will *always* be
fixing *something*.
However, it certainly is possible to get an airplane into a highly reliable
state. That is, you can't guarantee that things won't break, but you can
come pretty close to certainty that if something does break, it won't ruin
your day. You can never get to 100% -- even the most perfectly-maintained
plane can fail -- but you can get quite a bit better than what you've seen
in the plane you've been renting.
That said, you don't have to buy a plane to get one in that state. A large
proportion of the planes offered for sale will need some significant work
(and money) to get it up to snuff after purchase, since many planes are sold
because the owner lacked the time or funds to keep the airplane maintained
(or it became neglected simply because the sale of the plane was impending).
There ARE rentals available that have had this kind of maintenance done on
them regularly already. You can reap the benefits of good maintenance
without making yourself financially liable for that maintenance and without
putting down the capital investment in the airplane itself.
There are other aspects of ownership that provide benefits you can't get
from a rental situation, but quality maintenance isn't really one of them,
not if you find a good rental outfit.
Don't fly the airplane until the mechanic does find something.
I suppose if you owned the airplane, AND the mechanic spend two days or so
looking at it and still could not find anything wrong with the engine, AND
the engine had been run on the ground (including at full power) for some
significant amount of time (30-60 minutes at a minimum, though probably not
all at the same time) without ANY sign of hesitation, then you might
consider spending a couple of hours or so test flying within gliding
distance of the airport (hopefully you've got a long runway, and use Vx
until you've got plenty of altitude) and eventually getting to a point where
you feel you can trust the airplane again.
After all, no one else is going to be your test pilot (well, actually...I
suppose you could find someone who might be willing to do it if you paid
them, but you'd better be sure you get them to sign a liability waiver so
it's clear everyone involved knows there's a larger than normal possibility
the engine could quit). And you might find it hard to sell an airplane when
the reason for selling is "unresolved engine failure".
But for a rental, you have no financial stake in the airplane. Why mess
around with it? Just find some place that rents airplanes that don't quit
on you just after takeoff.
Pete
Old August 23rd 06, 06:17 PM posted to rec.aviation.piloting
The issues are with three different airplanes
Mic issues and Engine cough 172 #1
Bad crack on cowl 172 #2
Dead Alternator Dakota.
The Club has owners that leaseback to the club.
The owners are responsible for getting the maintance done.
(In all fairness the dakota owner seems to stay on top of things and the only reason
I ever fly the 172's is when the dakota is not availible.)
As it is one of the nicer aircraft in the fleet It is also often booked weeks in advance.
I'm the the process of getting checked out in a new G1000 182 at an FBO on the field,
the price is a bit steep at $185.00/hr, but the part that really hurts is
the 2.5 hr cross country minimum.
Paul (Same as the paul that started this thread, just a differnt computer)
Old August 23rd 06, 01:19 PM posted to rec.aviation.piloting
Dave S
a)Never,
Are these all the same plane? or different planes?
Who manages the maintenance? the owner? the club? an FBO that serves as
the broker for the leaseback (if not club owned aircraft).
When you say flying club, I envision a cooperative entity, not for
profit, run collectively by members or a volunteer board, with no paid
staff.
The club I was in (currently inactive) is selective about aircraft, has
squawks addressed promptly, and planes that become problem-children tend
to be weeded out fairly quickly. The owners were responsible for
having/paying the maintenance performed at a mechanic of the owners
choosing, but the club specified the minimum requirements (which were
essentially the same as if it was in for-profit use - 100 hr inspections
and such).
A general rule I've seen thrown around is about 200 hrs a year to make
ownership financially breakeven compared to rental (without any BIG
uh-ohs coming up).
Pros include knowing that YOU are where the buck stops with regard to
maintenance decisions and upkeep. If you have a tight month on money,
the hangar rent/tiedown rent/insurance bill comes due, as does the plane
note. You may spend a lot of money and never fly. You ALSO may come
across the deal of a lifetime and get a plane that will suit you well
for many years to come. Look for airplanes that fly often, and have well
documented maintenance, including compliance with AD's.
Another hint I've had thrown out to me.. the best deals are advertised
on bulletin boards at the airport.. not on the net or in glossy picture
magazines. Look around. Find a partnership - you arent't going to fly
every day are you? Sharing with one other or two other people may work
out just fine, and split the costs 3 ways. If one of them is an A&P then
thats even better.
Dave
Old August 23rd 06, 03:05 PM posted to rec.aviation.piloting
Jay Honeck
magazines.
And the REAL cream puffs never make it to the bulletin board -- they
sell strictly by word of mouth, to people who have been waiting to buy
it.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 23rd 06, 07:41 PM posted to rec.aviation.piloting
Andrew Gideon
and such).
One of the many things I like about the club to which I belong is that the
owner of the aircraft is the club...in other words, the members. So
there's no "owner" making choices; just the members.
That avoids any motivational conflict.
[It also makes for an excellent training ground for ownership.]
- Andrew
Paramus Flying Club
http://flyingclub.org/
Single-Engine Partnership vs. Used vs. Flying Clubs [email protected] Owning 16 January 14th 06 06:56 AM
