Hunting scopes in fighter jets?
Old August 26th 06, 02:30 PM posted to rec.aviation.military.naval
DDAY
Default Hunting scopes in fighter jets?
I read somewhere that the Navy used rifle scopes in some of its fighter jets
for spotting other planes. Is this true? And were they mounted in the
cockpit or used like binoculars?
D
Old August 26th 06, 03:30 PM posted to rec.aviation.military.naval
John Carrier
Done on the Phantom in some squadrons. Lined up with boresight. With radar
lock and bogey on the nose, you'd lean forward and get a magnified view and
hopefully an early VID. Somewhat awkward to use.
R / John
"DDAY" wrote in message
.net...
jets
D
Old August 27th 06, 12:33 AM posted to rec.aviation.military.naval
Gordon[_1_]
Going back in time, Galland had a similar sight set up in his BoB-era
Bf 109 E. It didn't work in practice so he went back to the old
fashioned Revi.
v/r
Gordon
PS, nice to see you JC
Old August 27th 06, 01:35 AM posted to rec.aviation.military.naval
WaltBJ
FWIW I flew with a pair of 7x35 wide angle binocs in the F4. With a
radar lockon, select heat, fly the steering dot to the center of the
scope, and then the bogey was inside the gunsight reticle. Now the
binocs allowed ID at way beyond normal tallyho ranges. Also FWIW I
suggested to the VWingCo of the first ever A10 wing they try Bushnell's
1-4x variable power rifle scope to employ the 30mm at longer ranges.
The 2-mil pipper is just too big for use at such ranges even though the
gun is affective way out there. I guess that suggestion was 'filed';
never heard of it even being tried out.
Walt BJ
Old August 27th 06, 05:26 PM posted to rec.aviation.military.naval
Blair Haworth
.net...
jets
With radar
view and
F-15 units were big on the practice, too, starting with the
AIMVAL/ACEVAL tests of 1977. One account is in Cecil Anderegg, _Sierra
Hotel_ (USAF History and Museums, 2001), p.161:
[...] The F–15, surprisingly to some, did not have the powerfully
magnified telescope, TISEO [Television Identification System,
Electro-Optical], that the F–4 carried. TISEO allowed the F–4 crew to
see what the radar was locked to and identify targets from many miles
away. The idea of TISEO was to give the crew enough time to identify the
target visually in order to fire a Sparrow before the target could shoot
at them. Since they had no such system, the F–15 pilots were
hard-pressed to get a Sparrow shot off before minimum range when the
rules of engagement required a visual identification. Often, they could
see the F–5 in the TD box as a black dot, yet still not positively
identify it until it was too late to shoot. Blue Force pilots rigged a
simple piece of equipment that made their problem much easier to solve.
They purchased a standard telescope of the type used on hunting rifles
and manufactured a bracket to attach the scope to the side of the HUD
glass. On the HUD was a “W” symbol that always showed exactly where the
nose of the airplane was pointed during flight. Before takeoff, the
pilot would note where the W was projected on the ground in front of his
aircraft. He then leaned forward and used two small adjusting screws on
the scope bracket to tweak the scope to exactly that same place. Then,
in the air, when the radar was locked to a target, he had only to fly
the W so that it was exactly over the TD box, then look through his
rifle scope. If he did those things carefully, the target would be in
the scope field of view, and he could identify it in plenty of time to
fire his Sparrow. The Blue pilots nicknamed this clever modification
Eagle Eye, and it quickly swept throughout the growing F–15 community.
It was not long before every F–15 awaiting takeoff at the end of the
runway at Langley or Bitburg had a rifle scope attached to the side of
the HUD.
[https://www.airforcehistory.hq.af.mi...erraHotel.pdf]
Old August 28th 06, 04:18 PM posted to rec.aviation.military.naval
nmg175
"Blair Haworth" wrote in message .net...
jets
We heard it was to help Single Engine Weenies find their Dicks! :-)
Old August 29th 06, 12:34 AM posted to rec.aviation.military.naval
John Carrier
In the single engine F-8, one had to slip in the cockpit carefully because
the canopy rails were a bit narrow and made fitting those big brass ones
(and their associated offensive equipment) difficult to fit into the
airplane.
R / John
PS Falcon 109
"nmg175" wrote in message
jets
Old August 29th 06, 01:42 PM posted to rec.aviation.military.naval
Ed Rasimus[_1_]
On Mon, 28 Aug 2006 18:34:19 -0500, "John Carrier"
airplane.
R / John
Are you going to require me to point out that Keith Ferris' famous
painting "Big Brass Ones" isn't of an F-8? It's of an F-105G flown by
John Revak and Stan Goldstein.
Or need I mention that the wheelbarrow rack at the back of the
standard F-105 revetment?
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Navy pilots thank plant with tours of fighter jets Otis Willie Naval Aviation 0 November 13th 05 01:50 AM
U.S. Air Force to purchase 1,763 LOCKHEED MARTIN F-35 Joint Strike Fighter jets for $245 billion Larry Dighera Military Aviation 0 July 22nd 04 06:06 AM
Air Force fighter pilots train in tactic that scopes out enemy targets, By Franklin Fisher, Stars and Stripes Otis Willie Military Aviation 27 June 13th 04 01:33 AM
Langley busy preparing for arrival of stealthy fighter jets Henry J Cobb Military Aviation 2 April 4th 04 09:53 PM
A-4 / A-7 Question Tank Fixer Military Aviation 135 October 25th 03 03:59 AM
