Hi,
which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
Hi Caiuz,
Why not try a LS4? It has about the same performance and is more fun to fly in my opinion. The cockpit is quite large and should be no problem. Regards, Erik. ginopagino wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
Met a German pilot last week who is 7 feet tall, touring North America
with his 26E !!!! He modified the rudder pedals, made special instrument panel (space for knees), replaced the factory seat pan, and modified the parachute harness so the chute sits on a shelf above his shoulders. Not your standard ship, eh? -- but it shows what determination and skills can do. This is the third design he has modified. He says the resale value (to TALL pilots) is excellent. Erik Braun wrote: Hi Caiuz, Why not try a LS4? It has about the same performance and is more fun to fly in my opinion. The cockpit is quite large and should be no problem. Regards, Erik. ginopagino wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
I have a Discus 2B and at 6" 0" have more room than I need. I am sure
that you will fit this and the similar Ventus fuselage. Why don't you try a few out at your local glider field? Mike ginopagino wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
Holger Weitzel is the tallest glider pilot I know (I'm 6'0" and he
makes me look short). He flies an ASH26E for the roomy cockpit. You might also want to consider a two-place ship like a DuoDiscus. I fly a Janus, and it is quite comfortable in front and back. ginopagino wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
I'm just under 6ft but once had a Ventus B (same fuse as the Discus B
or CS) and had to pull the rudder pedals back and put cushions behind me to fit well with a parachute on. You might find someone with one and see you can fit. Also, the PIK20D78 has a longer/larger fuse than the other PIK20 models. See if you can find one of those to try on for size as well. Even try taking out the seatback to make more room if it is possible to do so. Good luck! At my size I feel too tall for many gliders when wearing a chute. You are just going to try on gliders until you find one that fits..... Then find one to buy! Patman "CQ" ginopagino wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
Do a search on this newsgroup using groups.google.com for threads
relating to tall pilots--there have been quite a few over the years. One caution is that the torso/leg length ratio is as important as overall height. The original Ventus and Discus, for example, had good leg room but were tight for pilots with long torsos, at least without what I consider to be extreme measures such as parachutes stowed behind the pilot's head (because of the danger in a crash of it breaking your neck). The parachute can also be a critical factor. Some parachutes have more thickness in the lower back, others behind the shoulders (the former works better for me, allowing me to recline more). Some have comfort foam, which increases the thickness, some not. Sometimes even the way a rigger packs the parachute will have an effect. Removing the adjustable back rest may provide enough room to get a tall pilot into the cockpit. If you're buying new, the factories will often work with you. For my ASW 24, for example, Schleicher provided an aftermarket instrument panel with higher cutouts for the knees, omitted the rudder pedals (only the metal bars are there) and moved the mounting forward a few cm, and replaced the adjustable seat back with the covers for the baggage compartment used in the motorglider; they form a nice backrest. Chip Bearden ASW 24 "JB" |
Jantar-Std 3 has a very long cockpit that fits pilots over 2 m.
Nils ginopagino wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Any suggestions? Many Tks Caiuz |
On 28 Aug 2006 02:48:31 -0700, "ginopagino"
wrote: Hi, which european medium/high performance glider would you reccommend for tall people? I am ~6.5 / 199cm and looking to buy something like a Discus but apparently cockpit is supersmall Being 2.01m myself, here's my list of gliders that I fit in: ASW-19/20/Pegase (very comfortable with seatback removed) ASW-24 (special chute required - Kohnke Paeckchen) ASW-27 (special chute required, seatback removed) ASW-28 (special chute required, seatback removed) DG-300/600/800 (very comfortable) Ventus c Discus b Discus 2b (very comfortable) Ventus 2b (very comfortable) Nimbus 2 (very comfortable) Janus/Duo Discus/Numbus 3D/4D front seat (comfortable) LS-3/4 (very comfortable) LS-6/7/8 (long enough, but a little narrow for my taste) Choose one... ![]() Bye Andreas |
Refinish a Glider in Europe | Jim Culp | Soaring | 4 | November 19th 05 08:21 PM |
Aerodynamics of carrying water | Gene Whitt | Soaring | 54 | October 19th 05 07:24 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Newbie seeking glider purchase advice | Ted Wagner | Soaring | 19 | January 2nd 04 07:00 PM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
