Hi all,
I'd like to hear from anyone who has used the EasyPulse 5 while flying, and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. -Dan |
"Dan Youngquist" wrote in message ell.org... Hi all, I'd like to hear from anyone who has used the EasyPulse 5 while flying, and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. Oxygen system oxymoron. (Had to throw that in) |
Matt Barrow wrote:
a good but low-buck oxygen system. Oxygen system oxymoron. (Had to throw that in) Well, not necessarily. (I assume the above is what you're referring to.) I'll have a better system for less than 1/3 the cost of the least expensive aviation oxygen systems I've seen. Including adapters to refill from any medical or welding oxygen cylinder, I'll still be at around half the cost. -Dan |
Dan Youngquist wrote: Matt Barrow wrote: a good but low-buck oxygen system. Oxygen system oxymoron. (Had to throw that in) Well, not necessarily. (I assume the above is what you're referring to.) I'll have a better system for less than 1/3 the cost of the least expensive aviation oxygen systems I've seen. Including adapters to refill from any medical or welding oxygen cylinder, I'll still be at around half the cost. -Dan Do tell/share! |
Do tell/share! I would also like to have a cheaper than average o2 hook up for the few times I need to go high. Can you advise, or others, ideas? |
| Oxygen regulator | Roger Fowler | Soaring | 3 | December 26th 05 12:29 PM |
| What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 08:35 PM |
| Scott oxygen mask and diluter demand regulator for sale | nzuri | Soaring | 0 | October 5th 03 09:18 AM |
| Oxygen mask and regulator sale - update | nzuri | Soaring | 0 | October 1st 03 10:31 AM |
| Scott oxygen mask and diluter-demand regulator for sale in UK | nzuri | Soaring | 0 | September 28th 03 11:46 PM |
