Looking at buying an altitude encoder for the transponder in my
yet-to-be-born homebuilt. I see some altitude encoders have an RS-232 output for sending altitude information to a GPS. What kind of functionality does this provide? Is it "real-world" useful? Thanks! Scott |
Scott Rodriguez wrote:
Looking at buying an altitude encoder for the transponder in my yet-to-be-born homebuilt. I see some altitude encoders have an RS-232 output for sending altitude information to a GPS. What kind of functionality does this provide? Is it "real-world" useful? It's required for IFR approach certification I believe. I'd suspect that the MX20 also uses it for the terrain warning feature because it asks me for the altimeter setting periodically as well (which only would be useful if it was looking at a pressure alt somewhere). |
Ron Natalie wrote:
Scott Rodriguez wrote: Looking at buying an altitude encoder for the transponder in my yet-to-be-born homebuilt. I see some altitude encoders have an RS-232 output for sending altitude information to a GPS. What kind of functionality does this provide? Is it "real-world" useful? It's required for IFR approach certification I believe. Negative. The encoder can be used to provide altitude alerting functions through the gps, but it's not precise enough for providing vertical guidance in an approach. The typical serial encoder reports in 100 ft increments. Baro-vnav (which is not required to utilize an otherwise approach certified GPS) requires a much more precise input signal. My KLB 89B allows the connection of an encoder to it. It's sole usefulness is in serving as an altitude alert, and in calculating density altitude/true airspeed (not having to enter pressure altitude manually) Dave |
Our KLN94 is the same. Best thing the encoder can be used for in our unit
is to cancel the "Altitude Fail" message that pops up requiring you to cancel it. Jim "Dave S" wrote in message ink.net... Ron Natalie wrote: Scott Rodriguez wrote: Looking at buying an altitude encoder for the transponder in my yet-to-be-born homebuilt. I see some altitude encoders have an RS-232 output for sending altitude information to a GPS. What kind of functionality does this provide? Is it "real-world" useful? It's required for IFR approach certification I believe. Negative. The encoder can be used to provide altitude alerting functions through the gps, but it's not precise enough for providing vertical guidance in an approach. The typical serial encoder reports in 100 ft increments. Baro-vnav (which is not required to utilize an otherwise approach certified GPS) requires a much more precise input signal. My KLB 89B allows the connection of an encoder to it. It's sole usefulness is in serving as an altitude alert, and in calculating density altitude/true airspeed (not having to enter pressure altitude manually) Dave |
Dave S wrote:
Ron Natalie wrote: Scott Rodriguez wrote: Looking at buying an altitude encoder for the transponder in my yet-to-be-born homebuilt. I see some altitude encoders have an RS-232 output for sending altitude information to a GPS. What kind of functionality does this provide? Is it "real-world" useful? It's required for IFR approach certification I believe. Negative. The encoder can be used to provide altitude alerting functions through the gps, but it's not precise enough for providing vertical guidance in an approach. The typical serial encoder reports in 100 ft increments. Did I say SQUAT about vertical guidance. It is a requirement for TSO-C129a CERTIFICATION. I didn't say what it was used for. My statement appears to still hold true. |
Ron Natalie wrote:
Did I say SQUAT about vertical guidance. It is a requirement for TSO-C129a CERTIFICATION. I didn't say what it was used for. My statement appears to still hold true. ARRGGGHHH!!!.. You are ABSOLUTELY CORRECT. The altitude source must be connected in order to have an IFR certified installation. It even states as such in my King KLN-89B installation manual. I missed those 2 sentences previously. The irony of it is, I've got the wires installed for it on mine, even though the only discernable function is the altitude alert, which I'm not sure I'm going to use. Thanks Ron.. I was wrong and you were right. |
![]() "Dave S" wrote in message ink.net... Ron Natalie wrote: Did I say SQUAT about vertical guidance. It is a requirement for TSO-C129a CERTIFICATION. I didn't say what it was used for. My statement appears to still hold true. ARRGGGHHH!!!.. You are ABSOLUTELY CORRECT. The altitude source must be connected in order to have an IFR certified installation. It even states as such in my King KLN-89B installation manual. I missed those 2 sentences previously. The irony of it is, I've got the wires installed for it on mine, even though the only discernable function is the altitude alert, which I'm not sure I'm going to use. Thanks Ron.. I was wrong and you were right. The RAIM algorithm in the GPS needs the BARO input. It's only required use is to support the integrity monitor. The altitude alert is a 'feature' that King added for marketing (value-added) reasons. It cost them almost nothing per unit and just a few thousand $ of non-recurring costs to develop the software. Gerry |
Question: Velocity/Cozy and high altitude | Shin Gou | Home Built | 6 | February 16th 05 02:03 AM |
Altitude loss for 5h Duration Flight | nyffeler | Soaring | 9 | August 28th 04 11:12 AM |
S-TEC 60-2 requires re-trim after altitude hold? | Peter R. | Owning | 7 | March 2nd 04 03:46 PM |
Altitude encoder | Chad Lemmen | Owning | 9 | August 23rd 03 01:13 AM |
