Build an RV of ???
Old August 31st 06, 04:08 PM posted to rec.aviation.owning
William Snow
Default Build an RV of ???
I am considering building an RV-7A. I currently own an Arrow. I would like
to have an airplane that will cruise at about 200, with a 200 Hp engine in
order to keep the fuel burn numbers within reason. Is the RV the way to go
or am I missing something??
Any words of wisdom would be greatly appreciated and probably heeded.
William L. Snow, PE
CP, IA, ASEL
Old August 31st 06, 06:37 PM posted to rec.aviation.owning
JJS
"William Snow" wrote in message . ..
I am considering building an RV-7A. I currently own an Arrow. I would like to have an airplane that will cruise at
about 200, with a 200 Hp engine in order to keep the fuel burn numbers within reason. Is the RV the way to go or am
William L. Snow, PE
CP, IA, ASEL
Go get a demo flight first, either at Van's (like I did) or from a local owner.
Join a local EAA club, preferably one that has someone in the process of building or has completed an RV.
This is a huge project.
Talk to lots of builders.
Build only if you want to build. Not because you want to fly.
I have just started the tail kit for an RV-7. I'm mean just barely scratched to surface. Here are my observations
so far.
The kit is very high quality. I have not been disappointed so far.
There is lots of help out there on the internet and at Van's but having a local builder would be much better and I do
not have that option.
This a tremendously huge project. It takes a lot of study.
Expect to pay much more for tools and other stuff that you hadn't planned for.
I read that the average builder screws up around $400 in parts that he has to re-order.
So far I'm enjoying it, but it will be several years before it flies, and that is if I decide to go on to the next
kit. I'm approaching it as a learning experience.
Am I glad I tried it. So far... yep!
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old August 31st 06, 06:50 PM posted to rec.aviation.owning
Orval Fairbairn
William L. Snow, PE
CP, IA, ASEL
Van probably has the best kits for the money in the business -- and --
he keeps improving them! You can build the quick build kit for some
extra dollars. I have looked at some of his QB kits and am impressed!
Most of the hard stuff is done -- no jigs required -- and -- the work is
first rate. Be sure to get in with your EAA Chapter, as it is invaluable.
We have something like 30 RVs of one kind or another here at Spruce
Creek -- most of them RV-8s.
Old August 31st 06, 06:59 PM posted to rec.aviation.owning
Tom Young[_1_]
"William Snow" ... wrote in message
William L. Snow, PE
CP, IA, ASEL
rec.aviation.homebuilt would be another good place to ask. For RV-specific
questions, the two best groups I know of are Van's Airforce
(http://www.vansairforce.com/) and the Matronics RV mailing list
(http://www.matronics.com/rv-list/index.htm).
Tom Young
RV-4 empennage under construction
Old August 31st 06, 09:59 PM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
William L. Snow, PE
CP, IA, ASEL
If your objective is to fly, find a used one for sale somewhere.
If you objective is to enjoy the process of building your own airplane, then
build one.
Your stated objectives are 200 mph, 200 hp - sounds to me like you want to
fly, not build.
Geoff
Old August 31st 06, 10:27 PM posted to rec.aviation.owning
Newps
RV's are great if you don't need to carry anything other than a toothbrush.
William L. Snow, PE
CP, IA, ASEL
build one.
fly, not build.
Geoff
Old August 31st 06, 10:46 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Jim Logajan
(Added rec.aviation.homebuilt to newsgroups header.)
like to have an airplane that will cruise at about 200, with a 200 Hp
RV the way to go or am I missing something??
William L. Snow, PE
CP, IA, ASEL
airplane, then build one.
want to fly, not build.
Geoff
toothbrush.
Even for the RV-10?
Unless the pilot and any passengers are morbidly obese, I'd think there
would be enough useful load to carry moderate amounts of luggage. While
I've been less than thrilled by the rather low useful loads of the other
RV's, they aren't that bad.
Old September 8th 06, 03:12 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Charlie[_1_]
om...
William L. Snow, PE
CP, IA, ASEL
Geoff
toothbrush.
Even for the RV-10?
The -7 & -8 have very reasonable useful loads, as 2 seat a/c go. Full
fuel, 2 normal (not super-)sized adults, & ~100 lbs of baggage should
get you through at least a week of travel.
My wife & I are both a bit under the FAA 'standard'; we've camped for a
week at major flyins without over-grossing either the -4 or the folks
around us. (Includes clothes, tent, sleeping bags, softside cooler,
sandwich food & breakfast food for the week.)
Obviously, this can't be done if you throw anything that catches your
eye into the plane.
Charlie
flying -4, -7 in the oven
Old August 31st 06, 11:50 PM posted to rec.aviation.owning
Kyle Boatright
"Newps" wrote in message
toothbrush.
The truth is that any of the 2 seat RV's except the RV-4 can carry between
60 and 100 pounds of baggage plus full fuel and two normal sized adults.
The final numbers depend on how careful the builder was in keeping the
aircraft's weight down and avoiding an aft empty CG.
My airplane, an RV-6, has a useful load of about 650 lbs. That's 38 gallons
of fuel plus another 420 lbs of whatever else you want to load in the
airplane. If you plan to run the main dry, 60 pounds in the baggage
compartment is about the max allowable due to CG issues. In my case, 38
gallons is 4 hours @155-160 knots plus a 45 minute reserve.
KB
Old August 31st 06, 10:55 PM posted to rec.aviation.owning
William Snow
It sounds like it is more effort than I want to put in. I want to fly not
build.
How about buying one already built. Sounds risky to me.
This group knows the in's and outs' so advice is welcomed.. Thanks
Bill Snow
William L. Snow, PE
CP, IA, ASEL
Could Canada Build Charles Talleyrand Military Aviation 22 July 11th 04 10:05 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
propeller calculation and how to build jgarner Home Built 7 August 25th 03 03:23 AM
I Wanna Build an Aeroplane Badwater Bill Home Built 71 August 19th 03 02:24 PM
[Fwd: Why I'll never build a kit plane.] Corky Scott Home Built 16 July 28th 03 01:56 AM
