New GNS 530 getting very hot - Is this normal ?
Old August 31st 06, 11:14 PM posted to rec.aviation.owning
Roy N5804F[_1_]
Default New GNS 530 getting very hot - Is this normal ?
We just had a complete refit of our Piper Archers avionic stack and
collected it from the avionic installers.
We had a two hour flight back to our base and the new equipment performed
very well.
The only issue, is that the 530 got really hot and I wondered what
experience others have the GNS530 ?
I have asked the installers if this is normal.
So does your GNS530 get really hot ?
Thanks for all input,
Roy
Piper Archer N5804F
I
Old September 1st 06, 07:16 AM posted to rec.aviation.owning
jbskies
Yes. When I touch the black frame over the GNS530 after a flight. You
can feel the heat. It is kind of hot. My GNS530 has been installed
for over 6 years, never had problem.
jbskies
Old September 1st 06, 12:22 PM posted to rec.aviation.owning
Doug Vetter
Roy N5804F wrote:
snip
Yes, and it's normal. It's a result of the backlighting. At night when
I manually turn the backlighting down to 250 or so, the face of the unit
is cool to the touch.
-Doug
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old September 2nd 06, 04:39 AM posted to rec.aviation.owning
Peter R.
You may want to ask your avionics tech to investigate this to see if there
is anything that can be done to reduce the heat. Last year I discovered
my Garmin transponder, a GTX330, was getting too hot to touch and I
mentioned this to a local shop tech.
They took a look behind the glare shield and discovered that my avionics
cooling fan had one more available port so the hooked up a hose from the
fan to the transponder. In doing so, they were able to significantly
reduced the heat thrown off by the unit.
Peter
Lycoming O-540, "normal" CHT/EGT??? USA Owning 3 August 1st 05 08:00 AM
Normal voltage drop Robert M. Gary Owning 19 January 3rd 05 04:12 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Is ear-popping normal Piloting 9 April 24th 04 11:25 PM
Normal EGT - Very Low CHT markjen Owning 7 March 4th 04 01:54 PM
