Hawker vs. Glider Midair - with photo!
Old September 1st 06, 05:38 PM posted to rec.aviation.piloting,rec.aviation.soaring
Larry Dighera
Default Hawker vs. Glider Midair - with photo!
On Wed, 30 Aug 2006 22:11:59 -0700, "Peter Duniho"
wrote in
For example: under your interpretation of the rules, a balloon overtaking a
helicopter in a hover would have the right-of-way and the helicopter would
be required to give way. That certainly makes no more sense than requiring
a balloon to alter course, and frankly I think it makes a lot less sense (at
least in the converging situation, the balloon pilot can see the other
traffic).
Given the fact that the balloon pilot is at the mercy of the vagaries
of the wind for his navigation control, and the helo is highly
maneuverable, why wouldn't the balloon be given the right-of-way? One
must give way to a balloon; to believe otherwise is foolish.
So, which is it? Are balloon pilots required to alter course to the right?
Or are helicopter pilots required to yield right-of-way to a balloon
approaching them from the rear? You can't have it both ways.
Beats me.
You know, I write from the perspective of a certificated glider pilot
who received his training in the early '70s. My recollection is, that
gliders _always_ have the right-of-way over powered aircraft. Perhaps
that is an erroneous notion today. It might be worth researching the
historical changes to § 91.113.
Old September 1st 06, 06:04 PM posted to rec.aviation.piloting,rec.aviation.soaring
Peter Duniho
"Larry Dighera" wrote in message
A balloon pilot is NOT at the mercy of the wind. It's true that lateral
control is impossible, but that doesn't mean the balloon pilot doesn't have
any way to avoid a collision. And it's simply absurd to think that a pilot
who has no way to know that there is an overtaking aircraft is required to
give way to that overtaking aircraft.
And frankly, don't get too attached to the whole balloon/helicopter example.
It's just an *example*. Even if you somehow, in a bizarre twist of reality,
come to believe that a person is required to react to information they don't
have (for example, manufacture a non-existent requirement to be constantly
maneuvering so as to be aware of other air traffic in all directions), there
are still other similar examples. For example, shall the pilot of a Piper
Cub give way to a faster glider overtaking it? Are all power pilots
required to constantly maneuver so as to know whether they are being
overtaken by an aircraft that has the right of way?
What's foolish is thinking that balloon pilots have no control over their
aircraft, and that a person is required to react to a situation they have no
way to know is occurring.
Pete
Old September 1st 06, 07:00 PM posted to rec.aviation.piloting,rec.aviation.soaring
Jack[_1_]
Yes, exactly so.
If we _read_ the FAR's, 99% of the questions are answered.
http://tinyurl.com/loggu
91.113
(f) Overtaking. Each aircraft that is being overtaken
has the right-of-way and each pilot of an overtaking
aircraft shall alter course to the right to pass well clear.
Jack
Old September 1st 06, 07:04 PM posted to rec.aviation.piloting,rec.aviation.soaring
Ron Garret
No, what is foolish is supposing that a helicopter pilot flying
backwards has no way of knowing what is going on behind him.
rg
Old September 1st 06, 07:20 PM posted to rec.aviation.piloting,rec.aviation.soaring
Larry Dighera
On Fri, 1 Sep 2006 10:04:25 -0700, "Peter Duniho"
wrote in
It means that he is incapable of complying with § 91.113(e) by
altering his course to the right.
Old September 1st 06, 06:26 PM posted to rec.aviation.piloting,rec.aviation.soaring
Jack[_1_]
It might be worth reading today's 91.113 (c):
In distress. An aircraft in distress has the right-of-way
over all other air traffic.
And, reading (d) and it's sub-sections carefully may also add some
clarity.
Jack
Sec. 91.113
Right-of-way rules: Except water operations.
(a) Inapplicability. This section does not apply to the operation of
an aircraft on water.
(b) General. When weather conditions permit, regardless of whether
an operation is conducted under instrument flight rules or visual
flight rules, vigilance shall be maintained by each person operating
an aircraft so as to see and avoid other aircraft. When a rule of this
section gives another aircraft the right-of-way, the pilot shall give
way to that aircraft and may not pass over, under, or ahead of it
unless well clear.
(c) In distress. An aircraft in distress has the right-of-way over
(d) Converging. When aircraft of the same category are converging at
approximately the same altitude (except head-on, or nearly so), the
aircraft to the other's right has the right-of-way. If the aircraft
are of different categories--
(1) A balloon has the right-of-way over any other category of aircraft;
[(2) A glider has the right-of-way over an airship, powered parachute,
weight-shift-control aircraft, airplane, or rotorcraft.
(3) An airship has the right-of-way over a powered parachute,
weight-shift-control aircraft, airplane, or rotorcraft.]
However, an aircraft towing or refueling other aircraft has the
right-of-way over all other engine-driven aircraft.
(e) Approaching head-on. When aircraft are approaching each other
head-on, or nearly so, each pilot of each aircraft shall alter course
to the right.
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter
(g) Landing. Aircraft, while on final approach to land or while
landing, have the right-of-way over other aircraft in flight or
operating on the surface, except that they shall not take advantage of
this rule to force an aircraft off the runway surface which has
already landed and is attempting to
make way for an aircraft on final approach. When two or more
aircraft are approaching an airport for the purpose of landing, the
aircraft at the lower altitude has the right-of-way, but it shall not
take advantage of this rule to cut in front of another which is on
final approach to land or to overtake
that aircraft.
Hawker vs. Glider Midair - with photo! Larry Dighera Soaring 72 September 6th 06 02:03 PM
Hawker vs. Glider Midair - with photo! Darkwing Piloting 151 September 5th 06 05:19 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
