I have a Glasair 1 FT with the newer style trim system that uses a trim
wheel connected to a gear train that winds and unwinds stainless steel control cable and adjusts the relative tension of springs bias the elevator up and down. This system works well in flight. The existing indicator was a rotary wheel attached to the top of the gear train with arbitrary markings. It spun as you cranked on the trim wheel. It is in a hard to see location and I cut it off since we never used it. I would like to create an electronic trim indicator based on a Wheatstone bridge. This bridge resistance divider would drive a linear miniature panel zero center (milli)ammeter of the "mag negative", "zero", "max positive" type. I don't know what the full scale + and - should be of the meter. Should it be +/- 1 ma, +/- 10ma, etc? I would couple the moving trim cable to a linear taper slide potentiometer that would be nominally centered in its motion range when the trim was set to what has been determined to be the takeoff trim position. As the trim wheel is rotated, the moving control cable moves the slide pot and unbalances the circuit, moving the needle on the meter which indicates relative trim up or trim down. The circuit would include one adjustable pot to intially balance the meter at 0 for nominal takeoff trim. I would like to power this off of unregulated aircraft bus voltage. Would the current be insensitive to actual voltage? I would image it would be insensitive at the zero position, since if the four resistances are equal, the voltage on each side of the ammeter is the same and hence no current regardless of voltage. I guess that the sensitivity would vary with voltage nominal changes when off zero. Is there someone who could suggest nominal values for the four resistors and the range of the (milli)ammeter? It this idea even practical? Nominal aircraft bus voltage is about 14.4 volts. |
The current through your meter can easily be calculated
by applying ohm's law. i.e if using a 10K pot and 2 resistors of 4K7, max. current would be 14.4V divided by 10K or about 1,5 mA. I am afraid you will not easily find a potmeter that can stand the vibration, dust and oil present in any aircraft over a reasonable amount of time. Also the coupling to the trim cable might not be an easy task. My approach to this problem would be a series of opto-detectors and a vane on the trim cable. Each of the opto-detectors could drive one LED on the panel. This setup has no moving parts except the vane, does not suffer from variations in the supply voltage, and offers digital readout which not only looks cooler but is actually clearer. Only drawback is the multiwire cable to the panel. This could be avoided by using more electronics. |
![]() "karel" wrote I am afraid you will not easily find a potmeter that can stand the vibration, dust and oil present in any aircraft over a reasonable amount of time. Also the coupling to the trim cable might not be an easy task. Fiddlesticks! You just are not going to find it at Rat Shack. -- Jim in NC |
![]() "Morgans" wrote in message ... "karel" wrote I am afraid you will not easily find a potmeter that can stand the vibration, dust and oil present in any aircraft over a reasonable amount of time. Also the coupling to the trim cable might not be an easy task. Fiddlesticks! You just are not going to find it at Rat Shack. And your positive addition of information is ( .................. fill out here .............) |
![]() karel wrote: "Morgans" wrote in message ... "karel" wrote I am afraid you will not easily find a potmeter that can stand the vibration, dust and oil present in any aircraft over a reasonable amount of time. Also the coupling to the trim cable might not be an easy task. Fiddlesticks! You just are not going to find it at Rat Shack. I think what you are looking for is available from Ray Allen Company, formerly MAC trim systems. And your positive addition of information is ( .................. fill out here .............) |
On Tue, 12 Sep 2006 20:28:56 -0000, "karel"
wrote: "Morgans" wrote in message ... "karel" wrote I am afraid you will not easily find a potmeter that can stand the vibration, dust and oil present in any aircraft over a reasonable amount of time. Also the coupling to the trim cable might not be an easy task. Fiddlesticks! You just are not going to find it at Rat Shack. And your positive addition of information is Try Mouser Electronics. The have a rather large catalog. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Home Built | 23 | June 9th 04 02:48 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
turbine propeller | sebastian | Home Built | 19 | March 21st 04 12:47 AM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
Propellor pitch ... | Bob Noel | Owning | 2 | July 29th 03 04:30 AM |
