Hi,
Can anyone tell me if a Ventus 2C panel will fit in a Ventus C tilt panel installation with little or no modification? Also, if someone has a DXF, CAD, DWG file whatever, of either of these I'd be very greatful for a copy. Cheers Fish |
Fish wrote: Hi, Can anyone tell me if a Ventus 2C panel will fit in a Ventus C tilt panel installation with little or no modification? Also, if someone has a DXF, CAD, DWG file whatever, of either of these I'd be very greatful for a copy. Cheers Fish on www.mandhsoaring.com you can see some suggested panel layouts for each SH Glider. |
These two panels are different. The Ventus b/c panel is flat and mounts
with 3 bolts, two on top and one near the center. The V2 panel is not flat and mounts with 4 bolts. Whether modification is possible I can't answer, but I doubt it would be worth the effort. Bob Mottley wrote: Fish wrote: Hi, Can anyone tell me if a Ventus 2C panel will fit in a Ventus C tilt panel installation with little or no modification? Also, if someone has a DXF, CAD, DWG file whatever, of either of these I'd be very greatful for a copy. Cheers Fish on www.mandhsoaring.com you can see some suggested panel layouts for each SH Glider. |
Thanks Bob. You've talked me out of it.
Cheers Fish Robert Backer wrote: These two panels are different. The Ventus b/c panel is flat and mounts with 3 bolts, two on top and one near the center. The V2 panel is not flat and mounts with 4 bolts. Whether modification is possible I can't answer, but I doubt it would be worth the effort. Bob Mottley wrote: Fish wrote: Hi, Can anyone tell me if a Ventus 2C panel will fit in a Ventus C tilt panel installation with little or no modification? Also, if someone has a DXF, CAD, DWG file whatever, of either of these I'd be very greatful for a copy. Cheers Fish on www.mandhsoaring.com you can see some suggested panel layouts for each SH Glider. |
| Thread Tools | |
| Display Modes | |
| Glass panel upgrade to a Turbo Arrow? | Tauno Voipio | Owning | 9 | March 12th 06 05:29 AM |
| panel upgrade from VFR to IFR | John Doe | Owning | 5 | September 26th 05 11:05 PM |
| cost of panel upgrade on bonanza | soxinbox | Owning | 19 | October 29th 04 05:35 AM |
| Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 04:33 PM |
| Beech F-33/B-55 panel upgrade or STC | Gordon Rich-Phillips | Owning | 2 | January 14th 04 02:28 PM |
