C-182 pattern help
Old September 14th 06, 09:51 PM posted to rec.aviation.piloting
SilkB
Default C-182 pattern help
I am just starting to fly a C-182T and I was wondering if anyone has
any tips for the settings in the pattern/approach.
I have done most of my hours on C172, but when transitioning to C182 I
noticed that it's hard to get this plane down in the pattern. I enter
the pattern at 17"MP (to slow down) and abeam the numbers I lower it
to 15"MP while putting in 1 notch of flaps and trimming for 90-95KTS.
On base I put in another notch of flaps and trim for 85KTS and the
final notch of flaps on final while keeping 70-75KTS.
My problem is that with these settings the plane is not really
descending until the base to final turn where I need to cut down the
power completely. I would have liked to keep about 15"MP in all the
way to the round-out to make the landing nice and soft.
Any tips?
Thanks.
Old September 14th 06, 10:07 PM posted to rec.aviation.piloting
Jim Macklin
Check your gross weight vs. speed, I think you're too fast
and need to fly a little slower. You're making flap
extension too big an issue, slow down and put the flaps
down. Pay more attention to the outside world indicator and
aim for the runway.
OWI, windows.
"SilkB" wrote in message
anyone has
pattern. I enter
I lower it
for 90-95KTS.
and the
really
cut down the
in all the
| Any tips?
| Thanks.
Old September 14th 06, 10:26 PM posted to rec.aviation.piloting
Michelle P
Any tips?
Thanks.
Flaps?
Michelle P
Old September 14th 06, 10:52 PM posted to rec.aviation.piloting
Newps
Reduce power to 15" farther out. No reason you can't be at 70 kts on
midfield downwind with no flaps. At midfield flaps 20 and reduce power
some more, 12-13". On final either leave the flaps where they are or
use full flaps. Power at about 10" or whatever it takes to maintain
55-60 kts.
Any tips?
Thanks.
Old September 15th 06, 05:11 PM posted to rec.aviation.piloting
Matt Barrow
"Newps" wrote in message
some more, 12-13". On final either leave the flaps where they are or use
full flaps. Power at about 10" or whatever it takes to maintain 55-60
kts.
Does Cessna have any course equivalent to the Beechcraft Pilot Proficieny
Program (BPPP)? (Worth the $$ at twice the price)
Any tips?
Thanks.
Old September 15th 06, 10:55 PM posted to rec.aviation.piloting
Newps
kts.
No.
Ben Jackson
That sounds a little high. I fly a Comanche which also has an IO-540,
and I use 15" in the pattern and 12" abeam the numbers. I touch down
with the power off. The last bit of throttle is pretty dramatic. From
12" down to min goes from about 500fpm to 1000fpm+. At 15" and even
with full flaps I might even be able to maintain level flight.
Ben Jackson AD7GD
http://www.ben.com/
Old September 15th 06, 12:43 AM posted to rec.aviation.piloting
kontiki
I noticed a big change in the difference in the last inch or so of MP
when I went from a 2 blade to a 3 blade prop in my PA24-250. What prop
do you have?
Old September 15th 06, 01:20 AM posted to rec.aviation.piloting
Ben Jackson
do you have?
I have the 2 blade "compact" prop. I'm not sure what "compact" means,
other than it's not subject to the AD that has caused many Comanche
owners to go to 3 blade props!
Ben Jackson AD7GD
http://www.ben.com/
Old September 15th 06, 11:19 AM posted to rec.aviation.piloting
kontiki
Okay, that's the compact hub. To go that route with a Comanche 250 you
need an engine counterweight change that I didn't want to mess with. The
3 blade McCauley has worked out for me, I get solid 160kt cruise and better
climb. I've heard that going from 2-3 blade can cost a knot or 2 in cruise
but I didn't see that... I think the new APP cowling helped.
Pattern Entry Procedures - FAA Guidance Bill Denton Piloting 15 January 22nd 04 02:13 PM
Right pattern for practice? BJen Piloting 9 July 9th 03 08:52 PM
