I just pulled off the wheels to replace the tires (cracked side walls),
and I'm wondering about the wheel bearings. I see a grease gun fitting threaded into a cup, which is captured by a 'C' ring. The grease gun fitting looks pretty rusty itself. Should I replace the zerk and pump in new grease, or should I take the whole cup out, flush out the old grease, put the cup back in with a new grease gun fitting and start fresh? Anything else I should look at while I'm in there? Ken |
![]() "Ken Ward" wrote in message ... I just pulled off the wheels to replace the tires (cracked side walls), and I'm wondering about the wheel bearings. I see a grease gun fitting threaded into a cup, which is captured by a 'C' ring. The grease gun fitting looks pretty rusty itself. Should I replace the zerk and pump in new grease, or should I take the whole cup out, flush out the old grease, put the cup back in with a new grease gun fitting and start fresh? Anything else I should look at while I'm in there? Ken I would star fresh and clean the bearings up if the are unsealed ! Make sure you put in a new grease seal and new split pins. http://www.diynetwork.com/diy/ab_tra...788278,00.html http://www.off-road.com/chevy/tech/wheel_bearings/ http://autorepair.about.com/cs/doity...h_bearing1.htm |
Eberle trailer wheel rims | Bob | Soaring | 7 | November 25th 11 05:39 PM |
K21 brake parts | Stuart Kinnear | Soaring | 10 | June 26th 06 09:54 PM |
BGA Tech. News, Wheel brakes. | W.J. \(Bill\) Dean \(U.K.\). | Soaring | 8 | May 31st 05 01:55 PM |
US source for wheel on the tongue of Cobra trailer? | Mark Zivley | Soaring | 3 | January 18th 05 03:51 AM |
E2-C wheel bearings needed | CaptAro | Restoration | 1 | July 19th 03 04:32 AM |
