Hi,
which is the best and not so expensive solution for mobile phone use in plane!?? Im using David Clark 20-10s headset and looking for something to connect my mobile phone (2.5mm jack)? it must have feature to give priority to atc voice when u speak on gsm!! regards! |
Magic11 wrote:
Hi, which is the best and not so expensive solution for mobile phone use in plane!?? Im using David Clark 20-10s headset and looking for something to connect my mobile phone (2.5mm jack)? it must have feature to give priority to atc voice when u speak on gsm!! regards! Sporty's has just an adapter in their catalog. Another answer is to switch to something like the Lightspeeds that have a separate jack for on the control unit that feeds into a cell phone plug. Have fun getting GSM to work at altitude. |
I'd be surprised if the GSM worked at any altitude above pattern
altitude. -Robert Magic11 wrote: Hi, which is the best and not so expensive solution for mobile phone use in plane!?? Im using David Clark 20-10s headset and looking for something to connect my mobile phone (2.5mm jack)? it must have feature to give priority to atc voice when u speak on gsm!! regards! |
Hey gang,
It probably wont work in the air of course that being said mine started ringing at 11,000 ft yesterday above nashville in the t210. I was amazed of course we were moving so fast that we lost that tower in seconds but if you have a helicopter it might work. Cell towers all point down because thats were the people with the electric leashes are! Sportys does have that adapter but you can probably get the same from radio shack for nothin. This all being said I HIGHLY RECOMMEND YOU DO NOT USE YOUR PHONE IN THE AIR!!!!! Not because it is gonna screw with nav radios or anything but because you will be not concentrating on what you need to be concentrating on and that is flying the air plane. Please do not turn into the idiot in his car that is screwing up traffic because he is on the phone driving. "hang up and drive now applies to hang up and fly!!!!" matty Magic11 wrote: Hi, which is the best and not so expensive solution for mobile phone use in plane!?? Im using David Clark 20-10s headset and looking for something to connect my mobile phone (2.5mm jack)? it must have feature to give priority to atc voice when u speak on gsm!! regards! |
Huck,
Not because it is gonna screw with nav radios or anything but because you will be not concentrating on what you need to be concentrating on and that is flying the air plane. Ah, come one. At FL110 in the 210, you simply aren't busy all the time. In fact, with the autopilot on, you're way less busy than any time in a care. -- Thomas Borchert (EDDH) |
![]() "Huck" wrote in message ups.com... Hey gang, It probably wont work in the air of course that being said mine started ringing at 11,000 ft yesterday above nashville in the t210. I was amazed of course we were moving so fast that we lost that tower in seconds but if you have a helicopter it might work. Cell towers all point down because thats were the people with the electric leashes are! Sportys does have that adapter but you can probably get the same from radio shack for nothin. This all being said I HIGHLY RECOMMEND YOU DO NOT USE YOUR PHONE IN THE AIR!!!!! Not because it is gonna screw with nav radios or anything but because you will be not concentrating on what you need to be concentrating on and that is flying the air plane. Please do not turn into the idiot in his car that is screwing up traffic because he is on the phone driving. "hang up and drive now applies to hang up and fly!!!!" I need it for important calls just in case and for passengers, dont worry! ![]() |
I read your original post. If you can live with hearing ATC and the cell at
the same time, without priority for ATC, there's a solution for about $15 which I have used very successfully. Get an earpiece for you phone that has the microphone built into the earbud. These may be a little hard to find now because the bomm variety is all the rage. Jabra used to make one which came with different colored earpieces to customize the fit in your ear. Just slide that under the cup of your headset. The sidetone in your headset transmits the voice well. I used this setup in Canada where cell phone use in the air is legal. I need it for important calls just in case and for passengers, dont worry! ![]() |
good idea, tnx!
On Sat, 16 Sep 2006 02:16:14 +0200, "Magic11"
wrote: "Huck" wrote in message oups.com... Hey gang, It probably wont work in the air of course that being said mine started ringing at 11,000 ft yesterday above nashville in the t210. I was amazed of course we were moving so fast that we lost that tower in seconds but if you have a helicopter it might work. Cell towers all point down because thats were the people with the electric leashes are! Sportys does have that adapter but you can probably get the same from radio shack for nothin. This all being said I HIGHLY RECOMMEND YOU DO NOT USE YOUR PHONE IN THE AIR!!!!! Not because it is gonna screw with nav radios or anything but because you will be not concentrating on what you need to be concentrating on and that is flying the air plane. Please do not turn into the idiot in his car that is screwing up traffic because he is on the phone driving. "hang up and drive now applies to hang up and fly!!!!" I need it for important calls just in case and for passengers, dont worry! ![]() According to a Lightspeed note, it says the "FCC only allows the use of a cell phone within the cockpit when the plane is on the ground". |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Aviation Marketplace | 0 | December 11th 03 09:41 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Instrument Flight Rules | 0 | December 11th 03 09:41 PM |
Intercom: IntelliVox vs. ENRI | ROBIN FLY | Owning | 4 | December 2nd 03 04:36 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Aviation Marketplace | 1 | October 17th 03 02:04 AM |
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Aviation Marketplace | 0 | October 17th 03 01:25 AM |
