Aircraft systems RS232 voltage levels?
Old September 17th 06, 02:37 AM posted to rec.aviation.owning
mikem
Default Aircraft systems RS232 voltage levels?
While checking my new Garmin 496 power/data cable, I put a scope on the
NEMA DATAOut line. Just like the EI instruments, the Garmin puts out
TTL (0V and 4V) logic levels instead of the normal RS232 voltage levels
(-5V / -12V to +5V /+12V)
Do all aircraft systems that communicate via "RS232" use the TTL
levels? How about if I drag my Labtop out to the computer to read some
diagnostics or upload a new database?
Old September 17th 06, 04:00 AM posted to rec.aviation.owning
I had a gadget (Caller ID interface) that was designed to plug into the
serial port of a PC. It didn't have an onboard way to generate the
negative voltage - no dual power supply, nor a MAX232 or similar chip.
Instead, it depended (IIRC) on one of the handshake lines on the PC
being set to mark (negative voltage), and used a transistor to switch
this voltage onto the data line when a mark was needed. I think you
could even use the transmit line from the PC as the source of the
negative voltage (it idles in mark), as long as you could guarantee that
the software on the PC wouldn't try to talk and listen at the same time -
in other words, half duplex.
If you have an RS232 breakout box, or a cable you don't mind cutting up,
you might connect the Garmin to your laptop through the box/cable and see
what the voltage levels look like then.
Matt Roberds
Old September 17th 06, 06:11 PM posted to rec.aviation.owning
Tauno Voipio
Is the idle line up or down?
If it's cheated RS-232 (negative half missing),
the idle level is down. If it's logic level,
the idle line (marking) is up.
For a logic-level line you need a MAX232 or clone
to create correct RS-232 levels. For a cheat RS
you need additionally a logci inverter ahead of
the buffer.
HTH
Tauno Voipio (OH-PYM, PA28RT201T)
tauno voipio (at) iki fi
Old September 18th 06, 11:34 PM posted to rec.aviation.owning
mikem
Down, which I think you are saying means that the signal I see is the
same polarity as full-blown RS232 levels, but the amplitude is reduced
to only 4V p-p. (0 to 4V).
Obviously, the trip point of the receiver of such a reduced amplitude
signal would have to be at about 1.5V (TTL like).
Thanks,
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue Mike Naval Aviation 26 July 11th 06 11:38 PM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
