An odd clearance...can anyone explain?
Old September 10th 04, 11:58 PM
Andrew Gideon
Default An odd clearance...can anyone explain?
Departing Lancaster the other day, I received an odd clearance. I was
cleared from the airport to the Lancaster VOR, then East Texas VOR...
It was that first leg (Lancaster Airport to Lancaster VOR) that confused me.
The VOR is on the field. I have little choice but to go past it as a
trundle down the runway awaiting rotation speed.
So...why that clearance? What is expected of me?
What I did was go to the VOR (as I accelerated down the runway {8^) and then
proceeded to ETX. But was that right?
- Andrew
Old September 11th 04, 12:09 AM
Roy Smith
That's only good enough if it's a "fly by" waypoint :-)
I've gotten clearances like that before. What exactly what your
clearanance? Was it "direct Lancaster, direct East Texas", or was it
"direct Lancaster, Victor-something, East Texas"?
If the latter, they need to stick Lancaster in there because the airway
terminates at the VOR, not at the airport. It's somewhat of a moot
point, but it keeps the flight plan computers happy.
From a practical point of view, you take off, obey any DP's, then turn
direct ETX.
Old September 11th 04, 12:29 AM
Andrew Gideon
Hmm. I doubt I could have had enough altitude to "fly over". Is there such
a thing as a "fly through" waypoint?
then
I'm not sure of the exact wording; sorry. I don't believe airways were
specified, though.
Hmm. That does make sense, I suppose. Silly programmers.
direct ETX.
Good.
- Andrew
Old September 11th 04, 02:11 AM
zatatime
On Fri, 10 Sep 2004 17:58:04 -0400, Andrew Gideon
- Andrew
Your clearance is supposed to start with the closest fix to the
airport. As luck would have it you don't get any closer to an airport
than ON the airport. Where I fly out of there is a VOR on the filed.
What I've been taught to be correct is to maintain runway heading
until at an altitude that maneuvering won't be a problem (just like
any other take off) and then turn and fly direct to the VOR. After
station passage continue on your normal route.
When you turn to go to the first station, you may actually back track
for a mile or so, but its the proper way to execute the clearance.
HTH.
z
Old September 11th 04, 04:52 AM
Andrew Gideon
That was the possibility that I'd considered and rejected. I'd be very
interested to know on what you're basing that this is correct, as it's not
what I ultimately chose.
As far as I know, there's no requirement that a clearance start with "the
closest fix to the airport". When I depart CDW to the west, for example,
the clearance starts with LANNA. If using a closer fix were necessary,
we'd use the closer fix of SBJ...esp. given that LANNA is defined by a
radial from SBJ, and there's no other way a /U can reasonably locate LANNA
w/o passing by SBJ.
More, there's nothing wrong with intercepting an airway at some point not a
defined waypoint. I've been told in clearances to fly some heading or
radial to intercept an airway plenty of times. So intercepting the airway
between the Lancaster VOR and ETX is no great feat.
Finally, turning and flying back toward the VOR on the field puts me into
potential conflict with the VFR pattern. I don't know that there were any
of those on the day of my visit, but I don't know that there weren't.
So I decided to not do what you think is correct. So I might have been
wrong. As I wrote, I'd be very interested in something which shows this to
be the case (or not to be the case, of course {8^).
- Andrew
Old September 11th 04, 10:13 AM
CB
"Andrew Gideon" wrote in message
online.com...
To me it seems the logical thing to do. Take off, establish the departure
then fly to the fix in the clearance. If you have a worry about pattern
traffic climb at a rate that allows you to get above the pattern as you turn
back towards the VOR on the field but stay with the clearance altitude.
It strikes me as a similar situation flying a missed approach when the
holding fix is a VOR on the field.
I think it needs working out but ignoring the clearance as you seem to have
done from what you have written seems wrong.
Mind you I stand to be corrected and flamed by the anti authority, pistol
packing " I do what I like" brigade.
Old September 15th 04, 11:00 PM
zatatime
On Fri, 10 Sep 2004 22:52:44 -0400, Andrew Gideon
I think it would depend on the actual clearance received. If you
received a "...direct Lancaster VOR..." clearance then it would be
proper to overfly the VOR. If you received a different clearance then
you may not have to. In my experiences I usually get something like
"climb to 2000, direct SBJ, Vsoandso to wherever...." so that is why I
said what I said.
w/o passing by SBJ.
This is why there was a delay in my response. I wanted to try to find
some documentation to back up what I was taught, and I wasn't home
much the last few days. Guess what? There isn't any! The only thing
I found was a statement sating the departure point will be to a
'nearby' fix. Nowhere did I find you have to file to the closest fix.
This leads me to questions since I obviously either was taught
incorrectly, or interpreted what I was taught incorrectly.
What is the definition of nearby? Can I file to any VOR or
intersection, say, within 20 miles of my departure point? Do I have
to actually file starting with a fix, or can I just file from any
point on an airway? Given the busy nature of the NY area, what are my
odds of getting a clearance using a fix further away? (That last one
may just come from experience). A better understanding of this sure
will help me pick better routes in the future since I'd always file to
the closest, even if I had a crappy route to my destination.
As far as your example: How the heck do you get to LANNA if your a
/U? I'm thinking your clearances are Radar Vectors to LANNA
then.....otherwise, as you state you have to go to SBJ VOR anyway, so
why doesn't the clearance start there?
Agreed, I've had similar experiences, but can you file it that way?
To know what was right or wrong, as I said, we'd need the actual
clearance. Sitting here I can't tell either way, but I am happy to
have learned something, and hope anyone with answers to the questions
this thread has raised in my head can be discussed.
Again - sorry for the delayed response.
z
Old September 16th 04, 02:09 AM
Ron Rosenfeld
On Wed, 15 Sep 2004 21:00:21 GMT, zatatime
I know of no restrictions such as question.
If I am flying from, let us say, KEPM to KASH, I will either file (and be
cleared), as my initial fix, BRNNS (140 NM) or ENE (178 NM). And I could
just as easily file direct to KASH. I don't because of overwater
considerations.
And those clearances were issued when I was filing /A.
In a non-radar environment, though, different considerations apply.
So far as the NY area, close to NYC (and I would guess in most busy
airspaces), random routes are not commonly approved. I would not expect to
depart KFRG cleared direct ETX, for example. There are also altitude
restrictions on certain routings.
However, you might be able to get something like KBDR direct ACK. And if
over water distance were not a consideration, that's how I would file.
--ron
Old September 16th 04, 02:51 AM
Stan Gosnell
zatatime wrote in
You can file to any fix you can navigate to. I regularly file to and from
lat/lon coordinates, far from any airway. It's easier for ATC if you file to
a fix they have in the database, but it's not absolutely essential. You do
need to be able to navigate to the fix in the event of radar failure.
You may not be cleared to the fix you filed to, and perhaps won't get the
route you filed. But you can *file* what you like.
Regards,
Stan
Old September 16th 04, 04:32 PM
john smith
Reading Don Brown's AvWeb column, filing to lat/lon's is causes problems.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 11:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 07:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 10:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 02:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 01:40 AM
