Transponder Landing System ???
Old September 12th 04, 04:48 PM
Trent D. Sanders
Default Transponder Landing System ???
Have you ever heard of, or have any experience with a thing called the
"Transponder Landing System", a form of IFR approach using a
transponder? What is it, how does it work, does it work, do you have
to have a special "endorsement" to fly it, etc?
TDS
N2997Y
Old September 12th 04, 05:59 PM
Bob Gardner
AIM 1-1-23. Special training is required.
Bob Gardner
"Trent D. Sanders" wrote in message
om...
TDS
N2997Y
Old September 12th 04, 07:04 PM
kage
I have flown the demonstrator that was set up at Madras. A couple of
corporate operators were going to get together and buy one for Sun Valley.
I don't think that ever happened. It takes a controller on the ground with
the equipment and you get a special squawk and just fly it like any other
ILS.
Curved approaches are possible. There was military application as well. The
unit could be parachuted out and set up in 30 minutes to a remote location.
Karl
om...
TDS
N2997Y
Old September 12th 04, 07:29 PM
Frank Stutzman
There was also a demonstrator set up at The Dalles airport (DLS) for a
while. The company working on this is Advanced Navigation Positioning
Systems (www.anpc.com) of Hood River, OR. According to their web site,
they have 4 sites where it is installed and a dozen or so planned. I'm
not sure what installed means as the DLS one is considered "installed",
but it certainly not an approved approach. Ditto for Pullman, WA.
I flew the approach DLS approach under VFR. Seemed to work ok. I'm not
sure what special training would be required. You have to talk to a
controller on the ground and get a transponder code. After that, tune
your radio to the right frequency and follow the needles. The Dalles
approach was an normal dme arc that put you onto the TLS straight-in
approach course. A curving TLS approach could be interesting.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old September 12th 04, 07:57 PM
Gerry Caron
TLS is a substitute for an ILS where an ILS can't be installed due to
terrain or other factors. It's also a whole lot cheaper than an ILS so it's
useful for smaller airports. That's good, because it's capacity limited
(more later) so it's not a good solution for busy airports.
It works by using a Mode A interrogator and multiple receivers around the
periphery of the airport. By measuring the time difference of arrival
(TDOA) of your transponder replies, it calculates your position relative to
the airport and the approach path. It then broadcasts thru an omni antenna
an "ILS" signal modulating the 90 and 150 Hz tones to drive your CDI to
indicate the proper guidance to the approach path.
To fly it, you have to set your transponder to the squawk code on the
approach plate (so it knows who is flying the approach) and tune your ILS
receiver to the "ILS" freq. The you fly it just like an ILS approach. No
special endorsements or training.
The capacity limitation I mentioned above comes about because only one a/c
can have the approach squawk code set at any one time or the system will get
confused and flag.
I haven't flown one. Most are in the pacific northwest at small airports in
the mountains.
Try the following link:
http://anpc.com/
Gerry
om...
TDS
N2997Y
Old September 12th 04, 08:02 PM
john smith
Lousy website!
You have to use MSIE to access it!
http://anpc.com/
Old September 13th 04, 01:18 AM
Mike Rapoport
It isn't cheaper when you consider that it requires an operator.
Mike
MU-2
"Gerry Caron" wrote in message
it's
to
antenna
get
confused and flag.
in
the mountains.
http://anpc.com/
Gerry
om...
TDS
N2997Y
Old September 13th 04, 05:38 PM
Everett M. Greene
"Mike Rapoport" writes:
it's useful for smaller airports. That's good, because it's capacity
limited (more later) so it's not a good solution for busy airports.
to the airport and the approach path. It then broadcasts thru an omni
antenna an "ILS" signal modulating the 90 and 150 Hz tones to drive your
CDI to indicate the proper guidance to the approach path.
get confused and flag.
in the mountains.
Try the following link: http://anpc.com/
The descriptions given above and other followups don't make it
clear: What's the function of the operator?
Old September 13th 04, 05:57 PM
Mike Rapoport
You need an operator to asign codes to inbound aircraft (ATC was not going
to do this). Presumably the machine also need to get the code input. There
was talk about putting one in here at SZT but the operator issue killed it
along with comments by the FAA that the localizer would have to be removed.
The TLS was also only going to be approved for a limited number of users
(certainly not part 91 piston airplanes, after all they only comprise 90% of
the airplanes using the airport). It was also only going to be in use for a
limited number of hours per day (when the operator was present)
I think that the solution is precision GPS approaches.
Mike
MU-2
"Everett M. Greene" wrote in message
relative
your
ILS
No
a/c
will
airports
in the mountains.
Old September 13th 04, 06:02 PM
C Kingsbury
"Mike Rapoport" wrote in message thlink.net...
Mike
MU-2
Does it require a dedicated operator, or can any old controller
hanging out in the tower run it? Out East I can't think of any Class D
fields that don't have at least 1 ILS, but perhaps in other regions
that's sometimes the case?
-cwk.
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
