FAA Order 8260.19C, "Flight Procedures and Airspace," Paragraph 852(d) (1):
(1) Fix altitudes established on ILS for LOC-only use should be coincident with the glide slope when possible. Where the fix altitude is not within feet of the glide slope, annotate it for LOC use as follows: MIN ALT CAROL 1600* *LOC only NOTE: This notation is not used when the nonprecision FAF altitude is the same as GS intercept altitude. |
Sam Spade wrote:
FAA Order 8260.19C, "Flight Procedures and Airspace," Paragraph 852(d) (1): (1) Fix altitudes established on ILS for LOC-only use should be coincident with the glide slope when possible. Where the fix altitude is not within feet of the glide slope, annotate it for LOC use as follows: MIN ALT CAROL 1600* *LOC only NOTE: This notation is not used when the nonprecision FAF altitude is the same as GS intercept altitude. should read "not within 20 feet..." |
Sam Spade wrote:
Sam Spade wrote: FAA Order 8260.19C, "Flight Procedures and Airspace," Paragraph 852(d) (1): (1) Fix altitudes established on ILS for LOC-only use should be coincident with the glide slope when possible. Where the fix altitude is not within feet of the glide slope, annotate it for LOC use as follows: MIN ALT CAROL 1600* *LOC only NOTE: This notation is not used when the nonprecision FAF altitude is the same as GS intercept altitude. should read "not within 20 feet..." This is the current criteria as clarified by change 1 in 1998. It was different before then. |
JPH wrote:
Sam Spade wrote: Sam Spade wrote: FAA Order 8260.19C, "Flight Procedures and Airspace," Paragraph 852(d) (1): (1) Fix altitudes established on ILS for LOC-only use should be coincident with the glide slope when possible. Where the fix altitude is not within feet of the glide slope, annotate it for LOC use as follows: MIN ALT CAROL 1600* *LOC only NOTE: This notation is not used when the nonprecision FAF altitude is the same as GS intercept altitude. should read "not within 20 feet..." This is the current criteria as clarified by change 1 in 1998. It was different before then. Here is what is said in the original issuance of 8260.19C, dated 9/16/93 ( Page 8-11, Paragraph 811 d.): (1) Fix altitudes established on ILS for LOC-only should be coincident with the glide slope when possible. Where the stepdown fix altitude is not within 20 feet of the glide slope, annotate it for LOC use as follows: MIN ALT CAROL 1600^ *LOC ONLY This is the same as it reads today, for all practical purposes. Can you cite the language that changed this for some period between late 1993 and 1998? |
| Thread Tools | |
| Display Modes | |
| FAA Advice request: Plus a GlaStar note | Tim Hickey | Home Built | 1 | April 4th 05 02:38 PM |
| correct website link | Shaun | Instrument Flight Rules | 0 | October 10th 04 07:41 PM |
| Duo Discus Tech note | Thomas Knauff | Soaring | 25 | August 9th 03 11:10 PM |
