Aircraft Blue Book
Old September 24th 06, 12:54 AM posted to rec.aviation.owning
Default Aircraft Blue Book
Hello, anyone out there have a fairly recent Aircraft Blue Book, I
would like to know the value on an aircraft. Tried looking it up on
aopa's vref since I'm a member but the plane wasn't in the drop down
menu. Can't call the finance company I'm using since it's Saturday. I
know, patience Danielsan....
Thanks,
Dave
Old September 24th 06, 02:29 AM posted to rec.aviation.owning
Montblack[_1_]
wrote)
Hello, anyone out there have a fairly recent Aircraft Blue Book, I would
A hint might get the ball rolling...
What plane? Features? Hours? Condition? Location?
Montblack
Old September 24th 06, 02:45 AM posted to rec.aviation.owning
Montblack wrote:
wrote)
Montblack
It's a 72 Socata Rallye model MS 894A 1192 ttaf 886 smoh Narco at50a
transponder, Narco nav 122D, Narco com 810, PS engineering pma 7000B
audio panel, 7 int 7 ext.
Located in the upper midwest.
Thanks,
Dave
Old September 24th 06, 06:05 AM posted to rec.aviation.owning
Montblack[_1_]
("Marty Shapiro" wrote)
I don't think there are enough Rallye's left in the U.S. for them to
appear in the blue book. The last time I looked at the FAA data base there
were around 93 of ALL models in the U.S. I forget if that count included
the Koliber, which is the Polish version of the Rallye 150.
http://www.airport-data.com/manuf/S.o.c.a.t.a..html
Yup, 93.
http://www.airport-data.com/search/search2.html?field=model&search=Search&code=S.o.c. a.t.a.+MS894A
Model MS894A
Montblack
Old September 24th 06, 09:06 AM posted to rec.aviation.owning
Marty Shapiro
"Montblack" wrote in
http://www.airport-data.com/search/s...el&search=Sear
ch&code=S.o.c.a.t.a.+MS894A
Thanks. That data base is easier to search than the FAA data base.
In looking through the FAA data base, several of the listed Rallye's do not
have a valid Airworthiness Certificate and some are flagged as "status in
question".
I did find a 235E advertised for sale, but this is a step up from the
MS894A for which the OP was seeking price information. The 235E for sale
is at http://www.global-air.com/global/g06171.htm
For the OP: The big difference between the 894A and 235E is the engine.
The 894A has the Franklin 220 HP engine, while the 235E has the Lycoming O-
540 B4B5 235 HP engine. Both are the "heavy" airframes and come with 2
hardpoints on each wing, so you can hang all sorts of interesting stuff if
you want. Some countries in Latin America used them as light
fighter/bombers.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
