Here is something that I have always wondered about, but have yet to
hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I hope someone can enlighten me on this. I know that there must be a good explanation, but as I said, I just can't visualize it. Thanks... Randy L. -- Remember: Any landing that you can walk away from, is a landing that you can be fined, sued, or prosecuted for. |
RandyL wrote:
Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? No, Vx will get you to a given altitude while covering the shortest distance, but not generally in the shortest time. When climbing at a steeper angle the plane will be going slower so even though Vx will get you there in a shorter distance you'll get there a little quicker by choosing a slightly shallower angle that lets you go faster, i.e. Vy. It's similar to choosing whether to climb a mountain by either going straight up the side in which case you may need ropes and make very slow progress, or by hiking up the less steep switchback trail in which case you'll have to go farther but will be able to go faster. |
Thanks Peter - and everybody who replied to this. It took a mighty effort,
but I think I may have finally wrapped my brain around this concept. Take care... Randy L. -- "When making an emergency off-field landing at night, turn on the landing lights just prior to touchdown. If you don't like what you see, then turn off the landing lights." "peter" wrote in message oups.com... RandyL wrote: Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? No, Vx will get you to a given altitude while covering the shortest distance, but not generally in the shortest time. When climbing at a steeper angle the plane will be going slower so even though Vx will get you there in a shorter distance you'll get there a little quicker by choosing a slightly shallower angle that lets you go faster, i.e. Vy. It's similar to choosing whether to climb a mountain by either going straight up the side in which case you may need ropes and make very slow progress, or by hiking up the less steep switchback trail in which case you'll have to go farther but will be able to go faster. |
Don't feel bad. It took me a while to grasp this concept effectively as
a student, too. Chris RandyL wrote: Thanks Peter - and everybody who replied to this. It took a mighty effort, but I think I may have finally wrapped my brain around this concept. Take care... Randy L. |
![]() "RandyL" wrote in message Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. Vy is time, and Vx is distance. The key, Randy, is to look at what the definition says and consider the words carefully. Best rate of climb considers feet of climb per unit of time past, without considering distance travelled at all. Best angle of climb considers feet of climb per unit of distance travelled, without considering time at all. .....To my feeble way of thinking, Vx - the best climb angle - NO. There's part of your difficulty, possibly. Stick with the proper terminology. Don't switch words around, because they mean something. "Best angle of climb" is not necessarily the same thing as "best climb angle". |
... Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I think the other two posts cover the basic definition adequately. I'll offer a mental view that sometimes helps me understand the relationship, and which might clarify the difference a little bit mo Vy is about the best *rate* of climb. That is, the most vertical distance over a period of time. Vx is about the best *angle* of climb. That is, the most vertical distance of a horizontal distance. That much has been explained. It may also be helpful to know that Vy occurs when you have the most excess power, while Vx occurs when you have the most excess thrust. Power, being a rate-based measure (that is, work (that is, force times distance) over a period of time), winds up contributing to the best climb performance over a period of time. On the other hand, thrust, being a measurement of the specific force acting on the airplane (and which is independent of time), winds up contributing to the best climb performance when time is ignored. I admit that the above may only be helpful if you already think in terms of physics. But perhaps it provides some additional insight into why there even are two different V speeds and how they relate to the definitions of them. Pete |
On Mon, 25 Sep 2006 23:21:44 -0700, "Peter Duniho"
wrote: "RandyL" wrote in message ... Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I think the other two posts cover the basic definition adequately. I'll offer a mental view that sometimes helps me understand the relationship, and which might clarify the difference a little bit mo Vy is about the best *rate* of climb. That is, the most vertical distance over a period of time. Vx is about the best *angle* of climb. That is, the most vertical distance of a horizontal distance. That much has been explained. It may also be helpful to know that Vy occurs when you have the most excess power, while Vx occurs when you have the most You might try the reverse order too. Look at best glide speed. In calm air the best glide speed gives you the most distance per time unit, but traveling either faster or slower will cause you to lose altitude faster. Now compare best rate of climb; a speed either faster or slower (Vx) will produce less climb versus time, so although the best angle for clearing an object at a given distance you will be going slower then the best rate of climb, but at a steeper angle. It's that slower speed with less lift that gives you less altitude versus time. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On 2006-09-26, Roger (K8RI) wrote:
You might try the reverse order too. Look at best glide speed. In calm air the best glide speed gives you the most distance per time unit, but traveling either faster or slower will cause you to lose altitude faster. Not quite - minimum sink (the speed at which you'll lose altitude at the lowest rate) is slower than best glide. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
On Tue, 26 Sep 2006 11:29:52 +0000, Dylan Smith wrote:
Not quite - minimum sink (the speed at which you'll lose altitude at the lowest rate) is slower than best glide. Right. Which makes best glide and Vy analogous and best loiter and Vx analogous. - Andrew |
On Tue, 26 Sep 2006 17:35:51 -0400, Andrew Gideon
wrote: On Tue, 26 Sep 2006 11:29:52 +0000, Dylan Smith wrote: Not quite - minimum sink (the speed at which you'll lose altitude at the lowest rate) is slower than best glide. Right. Which makes best glide and Vy analogous and best loiter and Vx Depends on what you are flying. in the Deb Vy is a tad slower than best glide which gives 500 to 600 fpm while Vx which is a lot slower gives the express elevator down at about 800 fpm or a tad more. Gliding at Vx gives me a very fast and steep descent for short field landings and a bunch of power. In the Deb Vx is definitely not going to keep you up there longer. Maximum range under power is about the same as Vy. analogous. - Andrew Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
figuring Rate of Climb | Michael Horowitz | Home Built | 1 | June 19th 05 03:16 AM |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Rate of climb | Dillon Pyron | Home Built | 3 | May 8th 04 01:08 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
