In other threads, people are talking of "sunset" as the latest landing
time for flights to IGC Sporting Code rules. I do not think that this is quite right, I believe that the critical time is a bit later. The aviation rules of most countries say something like: "Night. The hours between the end of evening Civil Twilight and the beginning of morning Civil Twilight. Civil Twilight ends in the evening when the centre of the sun's disc is 6 degrees below the horizon and begins in the morning when the centre of the sun's disc is 6 degrees below the horizon". (Source: Para 53 of FAA Civil Aviation Regulations, Part 1 - General Policies, Procedures, and Definitions, Version 2.3, October 2002) The Sporting Code Section 3 Gliding, says: "4.5.3 Night flight. A flight that continues beyond the hours of legal daylight in the country concerned shall not be validated, except where the glider and pilot comply with the laws of that country for night flight." Are some people taking the first part of this Sporting Code wording to mean "sunset" rather than Civil Twilight? Perhaps it would be better if the wording was something like: "A flight that includes any part of the official night flying period as definined by the Aviation Authorities in the country concerned, except ... " The logic of using Civil Twilight is that it is also defined as "the limit at which illumination is sufficient, under good weather conditions, for terrestrial objects to be clearly distinguished. At the beginning of morning Civil Twilight, or end of evening Civil Twilight, the horizon is clearly defined, only the brightest stars are normally visible and artificial illumination should not be required to carry on ordinary outdoor activities". Finally, there may be insurance considerations as well as sporting and legal ones. Damage in the event of landing after Civil Twilight may lead to difficulties with insurers. In the UK, the BGA publishes a time table of last landing times for this and other reasons, for application at BGA member clubs. Ian Strachan Lasham Gliding Centre, UK |
In message . com, Ian
Strachan writes snip Civil Twilight ends in the evening when the centre of the sun's disc is 6 degrees below the horizon and begins in the morning when the centre of the sun's disc is 6 degrees below the horizon". Snip The phrase 'civil twilight' always leaves me wondering what uncivil twilight is... (I'll get my coat) -- Surfer! Email to: ramwater at uk2 dot net |
![]() Ian Strachan wrote: Are some people taking the first part of this Sporting Code wording to mean "sunset" rather than Civil Twilight? Perhaps it would be better if the wording was something like: "A flight that includes any part of the official night flying period as definined by the Aviation Authorities in the country concerned, except ... " Ian, in the USA, the critical issue is that no AIRCRAFT may fly after SUNSET without proper lighting. If the sailplane has the proper lighting, then there are no further requirements (if not carrying passengers) or restrictions about flying between sunset and sunrise. The "problem" here is that it is quite easy to still be airborne, and see the ground, etc, well after sunset. But IT IS NOT LEGAL in *most* sailplanes. Because the FAR most of us are familiar with has to do with carriage of passengers, many, including myself, have been under the mistaken impression that it is OK to fly after sunset, but before twilight. So, IMO, all that needs to be stated in the SC is that the flight shall comply with all applicable regulations of the country concerned - period. In the USA that means that "day" flight is not permitted during 100% of the FAA defined day, but only between sunrise and sunset - UNLESS the sailplane is equipped with anti collision lights. If we want to legislate safety in the SC, then we should just set a maximum duration of the flight. If there were a full moon, and my sailplane had the appropriate lighting, I could very safely repeat my 100km speed triangle in wave at midnight. The flight would be less than 2 hours in duration, and I would at all times be within a 10:1 or better glide to a good airport. However, if I were in (for example) Argentina, it could be possible to work the wave for 20, 30, or more hours. Would that be safe in a single place glider? How about multiplace? What if Steve Fossett's Global Flyer were converted into a motorglider, and he decided to attempt a huge wave flight in the Andes? -Tom |
US Federal Aviation Regulation definition of night: From FAR official
definitions Night means the time between the end of evening civil twilight and the beginning of morning civil twilight, as published in the American Air Almanac, converted to local time. Equipment requirements for night flight: FAR 91.205(c) (c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (1) Instruments and equipment specified in paragraph (b) of this section. (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made. (4) If the aircraft is operated for hire, one electric landing light. I can find no reference in the FARs that further limits gliders to operations between sunrise and sunset. Ben Jeffrey "5Z" wrote in message ups.com... Ian Strachan wrote: Are some people taking the first part of this Sporting Code wording to mean "sunset" rather than Civil Twilight? Perhaps it would be better if the wording was something like: "A flight that includes any part of the official night flying period as definined by the Aviation Authorities in the country concerned, except ... " Ian, in the USA, the critical issue is that no AIRCRAFT may fly after SUNSET without proper lighting. If the sailplane has the proper lighting, then there are no further requirements (if not carrying passengers) or restrictions about flying between sunset and sunrise. The "problem" here is that it is quite easy to still be airborne, and see the ground, etc, well after sunset. But IT IS NOT LEGAL in *most* sailplanes. Because the FAR most of us are familiar with has to do with carriage of passengers, many, including myself, have been under the mistaken impression that it is OK to fly after sunset, but before twilight. So, IMO, all that needs to be stated in the SC is that the flight shall comply with all applicable regulations of the country concerned - period. In the USA that means that "day" flight is not permitted during 100% of the FAA defined day, but only between sunrise and sunset - UNLESS the sailplane is equipped with anti collision lights. If we want to legislate safety in the SC, then we should just set a maximum duration of the flight. If there were a full moon, and my sailplane had the appropriate lighting, I could very safely repeat my 100km speed triangle in wave at midnight. The flight would be less than 2 hours in duration, and I would at all times be within a 10:1 or better glide to a good airport. However, if I were in (for example) Argentina, it could be possible to work the wave for 20, 30, or more hours. Would that be safe in a single place glider? How about multiplace? What if Steve Fossett's Global Flyer were converted into a motorglider, and he decided to attempt a huge wave flight in the Andes? -Tom |
Ben Jeffrey wrote:
US Federal Aviation Regulation definition of night: From FAR official definitions Night means the time between the end of evening civil twilight and the beginning of morning civil twilight, as published in the American Air Almanac, converted to local time. Equipment requirements for night flight: FAR 91.205(c) (c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (1) Instruments and equipment specified in paragraph (b) of this section. (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made. (4) If the aircraft is operated for hire, one electric landing light. I can find no reference in the FARs that further limits gliders to operations between sunrise and sunset. See 91.209. Ben Jeffrey |
But, as I have recently told you all ad nauseam, sunset is NOT defined
in the FARs, nor is it known with an accuracy of better than a few minutes. Complaining of a flight that lands a few minutes after sunset is, in my view, picayune to the extreme. Analagous to trapping motorists who exceed a speed limit by less than 1%. I'm sure no-one at the FAA would ever worry about this unless it was a contributory factor to an accident. I certainly know of no enforcement action by any authority in such cases. However, I'll never be as good as you guys, I'm afraid. I freely admit to driving over the speed limit every day, rolling through stop signs and breaking sundry other driving regulations from time to time. I also sometimes fly closer to clouds than I should, have flown through airspace that maybe I shouldn't and have landed after sunset on a couple of occasions. Mike Greg Arnold wrote: Ben Jeffrey wrote: US Federal Aviation Regulation definition of night: From FAR official definitions Night means the time between the end of evening civil twilight and the beginning of morning civil twilight, as published in the American Air Almanac, converted to local time. Equipment requirements for night flight: FAR 91.205(c) (c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (1) Instruments and equipment specified in paragraph (b) of this section. (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made. (4) If the aircraft is operated for hire, one electric landing light. I can find no reference in the FARs that further limits gliders to operations between sunrise and sunset. See 91.209. Ben Jeffrey |
![]() Mike the Strike wrote: Complaining of a flight that lands a few minutes after sunset is, in my view, picayune to the extreme. Analagous to trapping motorists who exceed a speed limit by less than 1%. I'm sure no-one at the FAA would ever worry about this unless it was a contributory factor to an accident. I certainly know of no enforcement action by any authority in such cases. Mike, other than an occasional troll, there is no discussion of being this picky. I routinely overtake state police cars while my cruise control is set to 3-4 mph over the limit - while the folks with radar detectors slam on their brakes and slow to match the officer's speed... On the OLC, the whole point is to follow the rules within a reasonable "sporting" environment. There is not movement (except by the trolls) to specify *precisely* what constitutes unsportsmanlike conduct. That is to be determined on a case by case basis. Just as you wouldn't brag to "the world" about a 30 minute drive from Turf to El Tiro in your new Ferrari, you shouldn't post similar exploits on the OLC. There was arecent arrest based on someone who was selling videos of an extremely fast drive down some highway, possibly in Europe. This is what we don't want the OLC to condone. -Tom |
in the FARs, nor is it known with an accuracy of better than a few minutes. Complaining of a flight that lands a few minutes after sunset is, in my view, picayune to the extreme. Analagous to trapping motorists who exceed a speed limit by less than 1%. I'm sure no-one at the FAA would ever worry about this unless it was a contributory factor to an accident. I certainly know of no enforcement action by any authority in such cases. However, I'll never be as good as you guys, I'm afraid. I freely admit to driving over the speed limit every day, rolling through stop signs and breaking sundry other drivng regulations. I also sometimes fly closer to clouds than I should, have flown through airspace that maybe I shouldn't and have landed after sunset on a couple of occasions. Mike Greg Arnold wrote: Ben Jeffrey wrote: US Federal Aviation Regulation definition of night: From FAR official definitions Night means the time between the end of evening civil twilight and the beginning of morning civil twilight, as published in the American Air Almanac, converted to local time. Equipment requirements for night flight: FAR 91.205(c) (c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (1) Instruments and equipment specified in paragraph (b) of this section. (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made. (4) If the aircraft is operated for hire, one electric landing light. I can find no reference in the FARs that further limits gliders to operations between sunrise and sunset. See 91.209. Ben Jeffrey |
![]() Ben Jeffrey wrote: US Federal Aviation Regulation definition of night: From FAR official definitions Night means the time between the end of evening civil twilight and the beginning of morning civil twilight, as published in the American Air Almanac, converted to local time. Equipment requirements for night flight: FAR 91.205(c) (c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (1) Instruments and equipment specified in paragraph (b) of this section. (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made. (4) If the aircraft is operated for hire, one electric landing light. I can find no reference in the FARs that further limits gliders to operations between sunrise and sunset. Technically, this is not a requirement for gliders. See the full heading: 91.205: Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements. Note that this is for *powered* aircraft, so would apply to motorgliders, but not pure gliders. However, if the glider has a standard airworthiness certificate, it is probably limited to VFR day only. If it is experimental, it probably has the same restriction; if not, there would be specific requirements for night flying equipment which would probably also include cockpit lighting in addition to position and possibly anti-collision lights. |
Doug.. read 91.209
BT "Doug Haluza" wrote in message ups.com... Ben Jeffrey wrote: US Federal Aviation Regulation definition of night: From FAR official definitions Night means the time between the end of evening civil twilight and the beginning of morning civil twilight, as published in the American Air Almanac, converted to local time. Equipment requirements for night flight: FAR 91.205(c) (c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (1) Instruments and equipment specified in paragraph (b) of this section. (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made. (4) If the aircraft is operated for hire, one electric landing light. I can find no reference in the FARs that further limits gliders to operations between sunrise and sunset. Technically, this is not a requirement for gliders. See the full heading: 91.205: Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements. Note that this is for *powered* aircraft, so would apply to motorgliders, but not pure gliders. However, if the glider has a standard airworthiness certificate, it is probably limited to VFR day only. If it is experimental, it probably has the same restriction; if not, there would be specific requirements for night flying equipment which would probably also include cockpit lighting in addition to position and possibly anti-collision lights. |
