I'm somewhat surprised to see Airbus having such difficulties
considering the A380's having been designed on a computer (3D digital mock up). I thought the main benefit of CAD was to have the ability to test for systems integration before any metal is cut(?) Of course this is an extremely complex aircraft with many complicated systems that must all play together, and the latest wiring harness issue may not be related to any design deficiency. By comparison, I recall seeing a documentary on the 747's service entry (1970) that had its share of gremlins. (IIRC a big source of headaches were the Pratt JT9D fans) The documentary didn't go into much detail about the program's problems, (I'm sure there were a few) but that airplane was designed by engineers on drafting tables and not computers. I just assumed new aircraft designs would have smoother & shorter development because of modern computing power. |
In article . com,
"Kingfish" wrote: I'm somewhat surprised to see Airbus having such difficulties considering the A380's having been designed on a computer (3D digital mock up). I thought the main benefit of CAD was to have the ability to test for systems integration before any metal is cut(?) Of course this is an extremely complex aircraft with many complicated systems that must all play together, and the latest wiring harness issue may not be related to any design deficiency. By comparison, I recall seeing a documentary on the 747's service entry (1970) that had its share of gremlins. (IIRC a big source of headaches were the Pratt JT9D fans) The documentary didn't go into much detail about the program's problems, (I'm sure there were a few) but that airplane was designed by engineers on drafting tables and not computers. I just assumed new aircraft designs would have smoother & shorter development because of modern computing power. Physical mockups were actually constructed at that time of various components. If it didn't fit, you saw why. |
![]() john smith wrote: Physical mockups were actually constructed at that time of various components. If it didn't fit, you saw why. Correct, but the CATIA program used in the A380 development allowed the designers to virtually mock up the components and check for interference etc. The same program was used during the 777 program development, apparently with better results(?) |
CAD programs like CATIA work great at making everything fit mechanically.
It sounds like a lot of the 380 delays are related to wiring issues due to the large number of customizations for the individual airline customers. I suspect that CATIA doesn't help solve that problem very much. Mike Schumann "Kingfish" wrote in message oups.com... john smith wrote: Physical mockups were actually constructed at that time of various components. If it didn't fit, you saw why. Correct, but the CATIA program used in the A380 development allowed the designers to virtually mock up the components and check for interference etc. The same program was used during the 777 program development, apparently with better results(?) |
Today's WSJ (Thursday) reports that Airbus has announced the first
delivery of an A380 will not occur until October 2007, with service beginning first quarter of 2008. |
![]() Mike Schumann wrote: CAD programs like CATIA work great at making everything fit mechanically. It sounds like a lot of the 380 delays are related to wiring issues due to the large number of customizations for the individual airline customers. I suspect that CATIA doesn't help solve that problem very much. Hi Mike, I worked on the 777, and CATIA does help with wiring in terms of checking the routing of the wiring bundles, potential interferences, and making sure that they reach to where they need to go. The rest of it is schematics and good old fashioned engineering planning and execution. It sounds to me like Airbus may have been a little too disorganized in this department on the A380. Many people may not realize it, but when Boeing came out with the 747-400 it was treated by Boeing as a fairly minor upgrade, but was in fact closer to designing a whole new airplane. The result was not enough up front engineering and a program fraught with problems. Boeing took the lessons learned from the 747-400 and applied them to the 777 with the intent to do it right from the start. As a result, the 777 was the smoothest, most problem free airplane Boeing ever designed (not without problems, but manageable). Unfortunately Boeing has stepped back from the level of effort put forth on the 777 for the 787 a bit due to the high development cost of the 777. The 787 is having more problems than the 777 did, but not as much as the A380. It remains to be seen how smoothly the 787 development turns out... I am hoping it comes together well because it is a really cool airplane. The 787 is going to set a whole new standard for commercial jets. Dean Wilkinson |
On 4 Oct 2006 13:29:06 -0700, "Kingfish" wrote:
john smith wrote: Physical mockups were actually constructed at that time of various components. If it didn't fit, you saw why. Correct, but the CATIA program used in the A380 development allowed the designers to virtually mock up the components and check for interference etc. The same program was used during the 777 program development, apparently with better results(?) Ummmm....Airbus used CATIA for the 380, but had one big, big, problem: They didn't require everyone to use the same VERSION. And the versions weren't compatible. http://aecnews.com/articles/2035.aspx "It only makes sense if appeasement is a core corporate value" Ron Wanttaja |
Kingfish writes:
I just assumed new aircraft designs would have smoother & shorter development because of modern computing power. I think what actually happens is that designs take the same amount of time as before, but the resulting aircraft is fifty times more complicated. -- Transpose mxsmanic and gmail to reach me by e-mail. |
I just read an article indicating that the various countries involved used
non-compatible software, each thinking that theirs was the best, and they were wrong. Bob Gardner "Kingfish" wrote in message ups.com... I'm somewhat surprised to see Airbus having such difficulties considering the A380's having been designed on a computer (3D digital mock up). I thought the main benefit of CAD was to have the ability to test for systems integration before any metal is cut(?) Of course this is an extremely complex aircraft with many complicated systems that must all play together, and the latest wiring harness issue may not be related to any design deficiency. By comparison, I recall seeing a documentary on the 747's service entry (1970) that had its share of gremlins. (IIRC a big source of headaches were the Pratt JT9D fans) The documentary didn't go into much detail about the program's problems, (I'm sure there were a few) but that airplane was designed by engineers on drafting tables and not computers. I just assumed new aircraft designs would have smoother & shorter development because of modern computing power. |
"Bob Gardner" wrote: I just read an article indicating that the various countries involved used non-compatible software, each thinking that theirs was the best, and they were wrong. why, that's hard to believe :-) -- Bob Noel Looking for a sig the lawyers will hate |
Aviation Insurance History, data, records? | cloudclimbr | General Aviation | 0 | February 17th 04 03:36 AM |
How find out one's aviation insurance claims history? Aviation Claims Information Bureau? | cloudclimbr | Owning | 1 | February 15th 04 11:16 PM |
Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 10:13 PM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
