GPS vs ADF
Old October 13th 06, 04:59 AM posted to rec.aviation.ifr
Mortimer Schnerd, RN[_2_]
Default GPS vs ADF
I actually posted this in another aviation newsgroup in which I actively post
all the time but didn't get a reply... I assume because of the crash in
Manhattan got everybody's attention. That being said, I'm still hoping for some
insight from the more recently trained.
==== cut begins ====
I'm still a little confused how I'm expected to legally fly an ILS approach that
uses a NDB as its IAF with a GPS on board instead of an ADF. (For example, the
ILS Runway 2 approach into KUZA (Rock Hill, SC)). The rental aircraft I have
access to these days all come with GPS, which is very nice, but I still want my
ADF for the little airports I sometimes fly into.
Feel free to educate me... I was out of flying for 15 years and the technology
passed me by. The last time I was flying regularly LORAN was just coming to
aircraft, and everybody was flying ILS, NDB, and VOR approaches. I took an IPC
to get my instrument currency up to date but we used the older equipment with
which I was already familiar. I'm comfortable enough setting up a Garmin 430 to
navigate to another airport but that's about the limits of what I can do with
one. Don't have a clue about GPS approaches....
mschnerdatcarolina.rr.com
Old October 13th 06, 10:07 AM posted to rec.aviation.ifr
Dave S
Default GPS vs ADF
Mort.. welcome back into the air.
First off.. I am assuming that the Garmin 430 or other GPS is certified
for use in approaches IN YOUR INSTALLATION.. that usually means a couple
of specifics when installed and configured, and also a current database.
When you power the box up it will indicate if you are able to use it for
VFR navigation only. In the case of the 430, I cant rightfully think of
why someone would by a $10,000 box and not have it installed to its
fullest capability..
anyways.. You can use an IFR certified GPS LEGALLY to substitute for an
ADF or DME if the navaid's physical location is in the supplied database
(user made waypoints dont meet this requirement). So as long as you have
an IFR GPS, with current database, it would substitute where an
approach has "ADF" or "DME" required on the plate. I am not referring to
NDB approaches, but keep in mind that in many many instances, NDB and
other approach paths have "overlay" approaches that are GPS procedures..
so chances are if there is an NDB approach into someplace, there is
likely also a GPS/RNAV approach into there as well. My information is a
little dated here, so if there is a more correct version, someone will
surely update this thread.
Most of my GPS use has been with king products with minimal time behind
the Garmin.. did safety pilot a few times with a guy using dual 430's..
Pretty much in your scenario, with the ILS approach, with an ADF for the
IAF.. one possible way to tackle this is to have the Direct To set to
the ADF location/identifier. Then set the Nav to the ILS frequency, set
the panel CDI to indicate NAV instead of GPS.. and fly the needles..
The needles will give you your ILS info.. the GPS in the stack will give
you distance and bearing to the IAF (NDB).. and the moving map will show
you a pretty purple line going to your IAF. I do not recall if the 430
has ILS approaches "overlaid" in its database for GPS situational
awareness. If this is the case, selecting the ILS approach on the GPS
flight plan would provide GPS guidance that would automatically sequence
you past the ADF in question.. and probably cut the workload. You'd
still fly the ILS needles in either case, regardless of how you dial the
GPS in.
There is lots of good reading on AOPA's website that is archived over
the years on issues like this.. Find you an instructor who is savvy with
the new boxes and go play for a bit.. or find a pilot who is really
savvy and have him be your safety pilot and again.. go play..
There is also a free software download you can get from Garmin
(www.garmin.com) that is a "trainer" for their 400/500 product line that
can get you more familiar with it. The manuals are also available for
download for free if I remember correctly. Do some homework now and save
some money later.
Its a brave new world out there, Mort..
Dave (RN too)
Old October 13th 06, 03:33 PM posted to rec.aviation.ifr
Ross Richardson[_2_]
Default GPS vs ADF
GPS in.
some money later.
Dave (RN too)
actively post all the time but didn't get a reply... I assume because
of the crash in Manhattan got everybody's attention. That being said,
I'm still hoping for some insight from the more recently trained.
approach that
example, the
I have
still want my
technology
coming to
took an IPC
equipment with
Garmin 430 to
do with
Be careful with the DIRECT TO command. I have KLN 89/B and it will not
enter the approach mode from Direct to. You must be on a flight plan
(e.g., from some point TO some point). Then you can select the approach.
Like Dave said, many NDB approaches have a GPS overlay. But what is
really nice is the GPS only "T" approaches. Very easy and no reversal turn.
Regards, Ross
C-172F 180HP
KSWI
Old October 13th 06, 06:49 PM posted to rec.aviation.ifr
Sam Spade
Default GPS vs ADF
certified for use in approaches IN YOUR INSTALLATION.. that usually
means a couple of specifics when installed and configured, and also a
current database. When you power the box up it will indicate if you
are able to use it for VFR navigation only. In the case of the 430, I
cant rightfully think of why someone would by a $10,000 box and not
have it installed to its fullest capability..
an ADF or DME if the navaid's physical location is in the supplied
database (user made waypoints dont meet this requirement). So as long
as you have an IFR GPS, with current database, it would substitute
where an approach has "ADF" or "DME" required on the plate. I am not
referring to NDB approaches, but keep in mind that in many many
instances, NDB and other approach paths have "overlay" approaches that
are GPS procedures.. so chances are if there is an NDB approach into
someplace, there is likely also a GPS/RNAV approach into there as
well. My information is a little dated here, so if there is a more
correct version, someone will surely update this thread.
behind the Garmin.. did safety pilot a few times with a guy using dual
430's..
the IAF.. one possible way to tackle this is to have the Direct To set
to the ADF location/identifier. Then set the Nav to the ILS frequency,
set the panel CDI to indicate NAV instead of GPS.. and fly the needles..
give you distance and bearing to the IAF (NDB).. and the moving map
will show you a pretty purple line going to your IAF. I do not recall
if the 430 has ILS approaches "overlaid" in its database for GPS
situational awareness. If this is the case, selecting the ILS approach
on the GPS flight plan would provide GPS guidance that would
automatically sequence you past the ADF in question.. and probably cut
the workload. You'd still fly the ILS needles in either case,
regardless of how you dial the GPS in.
with the new boxes and go play for a bit.. or find a pilot who is
really savvy and have him be your safety pilot and again.. go play..
that can get you more familiar with it. The manuals are also available
for download for free if I remember correctly. Do some homework now
and save some money later.
Dave (RN too)
said, I'm still hoping for some insight from the more recently trained.
approach that
example, the
aircraft I have
still want my
technology
coming to
took an IPC
equipment with
Garmin 430 to
do with
With a Garmin 400/500 so long as the approach is loaded, going direct-to
some fix prior to the FAF will not adversely affect approach sequencing.
Old October 13th 06, 10:58 AM posted to rec.aviation.ifr
Thomas Borchert
Default GPS vs ADF
RN,
Well, you need one to substitute the ADF ;-)
Mainly, read the 430 manual part about loading and acitivating approaches. What
you would do is to activate the NDB approach to the airport in question. After
that, the 430 will guide you through the approach since the approach is in its
database. The CDI slaved to the GPS will give the indications as if there was a
VOR in place of the NDB - in principle (there are some differences in the
details). This together with the moving map (and the track indication) makes it
vastly easier to fly an NDB approach that way than with an ADF.
This all pertains to an IFR certified installation.
Thomas Borchert (EDDH)
Old October 13th 06, 04:16 PM posted to rec.aviation.ifr
Mark Hansen
Default GPS vs ADF
On 10/13/06 01:58, Thomas Borchert wrote:
RN,
Perhaps I'm missing something here, but it sounds like you're talking about
using the GNS 430 in GPS mode to fly the NDB approach, which is not allowed.
You can use the GPS as a substitute for the NDB, but not when the NDB is
the primary navigational station for the approach.
Now, if the airport has a GPS overlay associated with the NDB approach, you
can fly that using the GPS (in GPS mode).
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old October 13th 06, 05:00 PM posted to rec.aviation.ifr
Thomas Borchert
Default GPS vs ADF
Mark,
You are correct.
Old October 13th 06, 06:47 PM posted to rec.aviation.ifr
Sam Spade
Default GPS vs ADF
As a matter of FAA policy "or...GPS" will not be removed from an NDB
with straight-in minimums until an RNAV approach with straight-in
minimums is published to the same runway end.
Old October 13th 06, 11:41 AM posted to rec.aviation.ifr
Bob Noel
Default GPS vs ADF
some
that
http://www.faa.gov/ATPubs/AIM/
from chapter 1:
f. Use of GPS in lieu of ADF and DME
1. Subject to the restrictions below, operators in the U.S. NAS are authorized
to use GPS equipment certified for IFR operations in place of ADF and/or DME
equipment for en route and terminal operations. For some operations there is no
requirement for the aircraft to be equipped with an ADF or DME receiver, see
subparagraphs f(b)(7) and (8) below. The ground-based NDB or DME facility may be
temporarily out of service during these operations. Charting will not change to
support these operations.
(a) Operations allowed:
(1) Determining the aircraft position over a DME fix. GPS satisfies the 14 CFR
Section 91.205(e) requirement for DME at and above 24,000 feet mean sea level
(MSL) (FL 240).
(2) Flying a DME arc.
(3) Navigating to/from an NDB/compass locator.
(4) Determining the aircraft position over an NDB/compass locator.
(5) Determining the aircraft position over a fix defined by an NDB/compass
locator bearing crossing a VOR/LOC course.
(6) Holding over an NDB/compass locator.
NOTE-
This approval does not alter the conditions and requirements for use of GPS to
fly existing nonprecision instrument approach procedures as defined in the GPS
approach overlay program.
(b) Restrictions
(1) GPS avionics approved for terminal IFR operations may be used in lieu of ADF
and/or DME. Included in this approval are both stand-alone and multi-sensor
systems actively employing GPS as a sensor. This equipment must be installed in
accordance with appropriate airworthiness installation requirements and the
provisions of the applicable FAA approved AFM, AFM supplement, or pilot's guide
must be met. The required integrity for these operations must be provided by at
least en route RAIM, or an equivalent method; i.e., Wide Area Augmentation
System (WAAS).
(2) For air carriers and operators for compensation or hire, Principal
Operations Inspector (POI) and operations specification approval is required for
any use of GPS.
(3) Waypoints, fixes, intersections, and facility locations to be used for these
operations must be retrieved from the GPS airborne database. The database must
be current. If the required positions cannot be retrieved from the airborne
database, the substitution of GPS for ADF and/or DME is not authorized.
(4) The aircraft GPS system must be operated within the guidelines contained in
the AFM, AFM supplement, or pilot's guide.
(5) The Course Deviation Indicator (CDI) must be set to terminal sensitivity
(normally 1 or 1 1/4 NM) when tracking GPS course guidance in the terminal area.
This is to ensure that small deviations from course are displayed to the pilot
in order to keep the aircraft within the smaller terminal protected areas.
(6) Charted requirements for ADF and/or DME can be met using the GPS system,
except for use as the principal instrument approach navigation source.
(7) Procedures must be established for use in the event that GPS integrity
outages are predicted or occur (RAIM annunciation). In these situations, the
flight must rely on other approved equipment; this may require the aircraft to
be equipped with operational NDB and/or DME receivers. Otherwise, the flight
must be rerouted, delayed, canceled or conducted VFR.
(8) For TSO-C129/129A users, any required alternate airport must still have an
approved instrument approach procedure other than GPS that is anticipated to be
operational and available at the estimated time of arrival, and which the
aircraft is equipped to fly. If the non-GPS approaches on which the pilot must
rely require DME or ADF, the aircraft must be equipped with DME or ADF avionics
as appropriate.
NOTE-
Coincident with WAAS commissioning, the FAA will begin removing the Inverse A
Icon NA (Alternate Minimums Not Authorized) symbol from select RNAV (GPS) and
GPS approach procedures so they may be used by approach approved WAAS receivers
at alternate airports. This does not change the above alternate airport
requirements for users of GPS TSO-C129/129A, Airborne Supplemental Navigation
Equipment Using the Global Positioning System (GPS), receivers.
(c) Guidance. The following provides general guidance which is not specific to
any particular aircraft GPS system. For specific system guidance refer to the
AFM, AFM supplement, pilot's guide, or contact the manufacturer of your system.
(1) To determine the aircraft position over a DME fix:
[a] Verify aircraft GPS system integrity monitoring is functioning properly and
indicates satisfactory integrity.
[b] If the fix is identified by a five letter name which is contained in the GPS
airborne database, you may select either the named fix as the active GPS
waypoint (WP) or the facility establishing the DME fix as the active GPS WP.
NOTE-
When using a facility as the active WP, the only acceptable facility is the DME
facility which is charted as the one used to establish the DME fix. If this
facility is not in your airborne database, you are not authorized to use a
facility WP for this operation.
[c] If the fix is identified by a five letter name which is not contained in the
GPS airborne database, or if the fix is not named, you must select the facility
establishing the DME fix or another named DME fix as the active GPS WP.
NOTE-
An alternative, until all DME sources are in the database, is using a named DME
fix as the active waypoint to identify unnamed DME fixes on the same course and
from the same DME source as the active waypoint.
CAUTION-
Pilots should be extremely careful to ensure that correct distance measurements
are used when utilizing this interim method. It is strongly recommended that
pilots review distances for DME fixing during preflight preparation.
[d] If you select the named fix as your active GPS WP, you are over the fix when
the GPS system indicates you are at the active WP.
[e] If you select the DME providing facility as the active GPS WP, you are over
the fix when the GPS distance from the active WP equals the charted DME value
and you are on the appropriate bearing or course.
(2) To fly a DME arc:
[b] You must select, from the airborne database, the facility providing the DME
arc as the active GPS WP.
NOTE-
The only acceptable facility is the DME facility on which the arc is based. If
this facility is not in your airborne database, you are not authorized to
perform this operation.
[c] Maintain position on the arc by reference to the GPS distance in lieu of a
DME readout.
(3) To navigate to or from an NDB/compass locator:
NOTE-
If the chart depicts the compass locator collocated with a fix of the same name,
use of that fix as the active WP in place of the compass locator facility is
authorized.
[b] Select terminal CDI sensitivity in accordance with the AFM, AFM supplement,
or pilot's guide if in the terminal area.
[c] Select the NDB/compass locator facility from the airborne database as the
active WP.
[d] Select and navigate on the appropriate course to or from the active WP.
(4) To determine the aircraft position over an NDB/compass locator:
[b] Select the NDB/compass locator facility from the airborne database as the
active WP.
NOTE-
When using an NDB/compass locator, that facility must be charted and be in the
airborne database. If this facility is not in your airborne database, you are
not authorized to use a facility WP for this operation.
[c] You are over the NDB/compass locator when the GPS system indicates you are
at the active WP.
(5) To determine the aircraft position over a fix made up of an NDB/compass
locator bearing crossing a VOR/LOC course:
[b] A fix made up by a crossing NDB/compass locator bearing will be identified
by a five letter fix name. You may select either the named fix or the
NDB/compass locator facility providing the crossing bearing to establish the fix
NOTE-
[c] If you select the named fix as your active GPS WP, you are over the fix when
the GPS system indicates you are at the WP as you fly the prescribed track from
the non-GPS navigation source.
[d] If you select the NDB/compass locator facility as the active GPS WP, you are
over the fix when the GPS bearing to the active WP is the same as the charted
NDB/compass locator bearing for the fix as you fly the prescribed track from the
(6) To hold over an NDB/compass locator:
active WP.
NOTE-
NDB/compass locator facility which is charted. If this facility is not in your
airborne database, you are not authorized to use a facility WP for this
operation.
[d] Select nonsequencing (e.g., "HOLD" or "OBS") mode and the appropriate course
in accordance with the AFM, AFM supplement, or pilot's guide.
[e] Hold using the GPS system in accordance with the AFM, AFM supplement, or
pilot's guide.
(d) Planning. Good advance planning and intimate knowledge of your navigational
systems are vital to safe and successful use of GPS in lieu of ADF and/or DME.
(1) You should plan ahead before using GPS systems as a substitute for ADF
and/or DME. You will have several alternatives in selecting waypoints and system
configuration. After you are cleared for the approach is not the time to begin
programming your GPS. In the flight planning process you should determine
whether you will use the equipment in the automatic sequencing mode or in the
nonsequencing mode and select the waypoints you will use.
(2) When you are using your aircraft GPS system to supplement other navigation
systems, you may need to bring your GPS control panel into your navigation scan
to see the GPS information. Some GPS aircraft installations will present
localizer information on the CDI whenever a localizer frequency is tuned,
removing the GPS information from the CDI display. Good advance planning and
intimate knowledge of your navigation systems are vital to safe and successful
use of GPS.
(3) The following are some factors to consider when preparing to install a GPS
receiver in an aircraft. Installation of the equipment can determine how easy or
how difficult it will be to use the system.
[a] Consideration should be given to installing the receiver within the primary
instrument scan to facilitate using the GPS in lieu of ADF and/or DME. This will
preclude breaking the primary instrument scan while flying the aircraft and
tuning, and identifying waypoints. This becomes increasingly important on
approaches, and missed approaches.
[b] Many GPS receivers can drive an ADF type bearing pointer. Such an
installation will provide the pilot with an enhanced level of situational
awareness by providing GPS navigation information while the CDI is set to VOR or
ILS.
[c] The GPS receiver may be installed so that when an ILS frequency is tuned,
the navigation display defaults to the VOR/ILS mode, preempting the GPS mode.
However, if the receiver installation requires a manual selection from GPS to
ILS, it allows the ILS to be tuned and identified while navigating on the GPS.
Additionally, this prevents the navigation display from automatically switching
back to GPS when a VOR frequency is selected. If the navigation display
automatically switches to GPS mode when a VOR is selected, the change may go
unnoticed and could result in erroneous navigation and departing obstruction
protected airspace.
[d] GPS is a supplemental navigation system in part due to signal availability.
There will be times when your system will not receive enough satellites with
proper geometry to provide accurate positioning or sufficient integrity.
Procedures should be established by the pilot in the event that GPS outages
occur. In these situations, the pilot should rely on other approved equipment,
delay departure, reroute, or discontinue IFR operations.
g. Equipment and Database Requirements
1. Authorization to fly approaches under IFR using GPS avionics systems requires
that:
(a) A pilot use GPS avionics with TSO- C129, or equivalent, authorization in
class A1, B1, B3, C1, or C3; and
(b) All approach procedures to be flown must be retrievable from the current
airborne navigation database supplied by the TSO-C129 equipment manufacturer or
other FAA approved source.
(c) Prior to using a procedure or waypoint retrieved from the airborne
navigation database, the pilot should verify the validity of the database. This
verification should include the following preflight and in-flight steps:
(1) Preflight:
[a] Determine the date of database issuance, and verify that the date/time of
proposed use is before the expiration date/time.
[b] Verify that the database provider has not published a notice limiting the
use of the specific waypoint or procedure.
(2) Inflight:
[a] Determine that the waypoints and transition names coincide with names found
on the procedure chart. Do not use waypoints, which do not exactly match the
spelling shown on published procedure charts.
[b] Determine that the waypoints are generally logical in location, in the
correct order, and that their orientation to each other is as found on the
procedure chart, both laterally and vertically.
NOTE-
There is no specific requirement to check each waypoint latitude and longitude,
type of waypoint and/or altitude constraint, only the general relationship of
waypoints in the procedure, or the logic of an individual waypoint's location.
[c] If the cursory check of procedure logic or individual waypoint location,
specified in [b] above, indicates a potential error, do not use the retrieved
procedure or waypoint until a verification of latitude and longitude, waypoint
type, and altitude constraints indicate full conformity with the published data.
Bob Noel
Looking for a sig the
lawyers will hate
Old October 13th 06, 04:05 PM posted to rec.aviation.ifr
Doug[_1_]
Default GPS vs ADF
Yup, I miss listenin' to the Hog Report and checkin' out whatever
Elmer's Hardware had on sale at those small Wyomin' towns, with the
local AM station tuned into the ADF, when cummin in fer a landin'. By
guppy, them were the gud ol' days fer sure....
