PCAS - Portable Collision Avoidance System
http://www.zaonflight.com/mrx.html Is there anyone out there using this system in their glider? From what I have read, it seems like a like a pretty nice system to at least make you aware of what fast moving traffic is approaching your current airspace. If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. When I flew my glider in Moriarty last June, I was amazed at the number of large jets coming in from the east passing above and below me. I was talking and listening to ABQ approach control. ACT gave the approaching traffic my position and altitude and none of the airliners could look visually locate me. I saw all of them. I am sure that most of these pilots are running their descent and approach check lists, doing an approach briefing and saying a few last words to the passengers. At work when we get below 18,000 feet, I am always looking for gliders below the base of the clouds. I have never seen a glider in over 19 years of flying, but I know that they are there. I am hoping that they see me. It seems to me that a PCAS type of system would help me locate a majority of the biggest and fastest moving threats in the sky, commercial airliners, corporate jet and higher-end general aviation aicraft). Any PCAS users out there? Randy |
I fly with a PCAS, Randy. I bought it because my glider club lies
inside the Mode C veil of PHL, because an active military air base is 5 miles away, and because there are several airways that lie within several miles of us. It has gone off several times during each of the 5 flights that I've had it in my glider. As I get height and distance readings, it is usually pretty easy to spot the traffic. Once I had difficulty finding the threat, and it turned out to be a commuter running through the clouds above me. I wasn't too worried, because the MRX indicated that he was level and 600 feet higher than me, but if he had been descending I would have been sweating big time! Incidentally, I did a review of the various PCAS units available; you can read the discussion he http://tinyurl.com/pcmkw -John wrote: PCAS - Portable Collision Avoidance System http://www.zaonflight.com/mrx.html Is there anyone out there using this system in their glider? From what I have read, it seems like a like a pretty nice system to at least make you aware of what fast moving traffic is approaching your current airspace. If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. When I flew my glider in Moriarty last June, I was amazed at the number of large jets coming in from the east passing above and below me. I was talking and listening to ABQ approach control. ACT gave the approaching traffic my position and altitude and none of the airliners could look visually locate me. I saw all of them. I am sure that most of these pilots are running their descent and approach check lists, doing an approach briefing and saying a few last words to the passengers. At work when we get below 18,000 feet, I am always looking for gliders below the base of the clouds. I have never seen a glider in over 19 years of flying, but I know that they are there. I am hoping that they see me. It seems to me that a PCAS type of system would help me locate a majority of the biggest and fastest moving threats in the sky, commercial airliners, corporate jet and higher-end general aviation aicraft). Any PCAS users out there? Randy |
John,
I've read your review of the various PCAS (same as TPAS) devices. I use the Proxalert R-5 and would add to your comments re this unit. You are correct, it does not have internal batteries and so needs ship's power. This has not been much of an issue for me - - install the wire and plug once, don't have to change batteries. It does hang down some 3/4" below the glare shield. This allows it to have a good sized display, while not blocking forward view. In my ASH26E, it sits on the glareshield and doesn't block the view of the upper portion of the panel (this area is already blocked by the glare shield "brow", nor does it block forward view at all. The Proxalert is the only unit I'm aware of that displays threat aircraft squawk code. This is important to me as the threat level from a 1200 squawk aircraft, all other things being equal, is much higher than that from a discreet squawking aircraft. The discreet squawking aircraft is talking to ATC and probably has been told of my presence (I use a transponder). If the host, PCAS glider, has no transponder, then I guess it doesn't much matter what the threat aircraft is squawking - - not likely he is aware of you in any case! I have heard complaints from some R-5 owners that their unit did not alarm reliably or was inconsistent. I've not had that problem with mine at all. It finds traffic that I otherwise wouldn't see, some of which I never do see (g). When I'm talking to ATC getting flight following, the R-5 display is remarkably consistent with their advisories. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit and MKII yaw string "jcarlyle" wrote in message oups.com... I fly with a PCAS, Randy. I bought it because my glider club lies inside the Mode C veil of PHL, because an active military air base is 5 miles away, and because there are several airways that lie within several miles of us. It has gone off several times during each of the 5 flights that I've had it in my glider. As I get height and distance readings, it is usually pretty easy to spot the traffic. Once I had difficulty finding the threat, and it turned out to be a commuter running through the clouds above me. I wasn't too worried, because the MRX indicated that he was level and 600 feet higher than me, but if he had been descending I would have been sweating big time! Incidentally, I did a review of the various PCAS units available; you can read the discussion he http://tinyurl.com/pcmkw -John wrote: PCAS - Portable Collision Avoidance System http://www.zaonflight.com/mrx.html Is there anyone out there using this system in their glider? From what I have read, it seems like a like a pretty nice system to at least make you aware of what fast moving traffic is approaching your current airspace. If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. When I flew my glider in Moriarty last June, I was amazed at the number of large jets coming in from the east passing above and below me. I was talking and listening to ABQ approach control. ACT gave the approaching traffic my position and altitude and none of the airliners could look visually locate me. I saw all of them. I am sure that most of these pilots are running their descent and approach check lists, doing an approach briefing and saying a few last words to the passengers. At work when we get below 18,000 feet, I am always looking for gliders below the base of the clouds. I have never seen a glider in over 19 years of flying, but I know that they are there. I am hoping that they see me. It seems to me that a PCAS type of system would help me locate a majority of the biggest and fastest moving threats in the sky, commercial airliners, corporate jet and higher-end general aviation aicraft). Any PCAS users out there? Randy |
Thanks for the input, Bumper. I got my information solely from the
manufacturer's web sites, so user reports are very welcome! I've had the same experience that you've had, that my PCAS/TPAS unit sometimes picks threats up I never see. However, these threats are typically 3 miles or more distant, and several thousand feet above or below me. The commuter running through the clouds above me was also invisible, until he was practically overhead - but at least I knew we had sufficient vertical separation! One question - in your flight experience, does the way the R5 combines threats having the same squawk code on the same line of the display, showing only the closest threat's distance, and flip-flopping the various threat altitudes, cause you any confusion? -John bumper wrote: John, I've read your review of the various PCAS (same as TPAS) devices. I use the Proxalert R-5 and would add to your comments re this unit. You are correct, it does not have internal batteries and so needs ship's power. This has not been much of an issue for me - - install the wire and plug once, don't have to change batteries. It does hang down some 3/4" below the glare shield. This allows it to have a good sized display, while not blocking forward view. In my ASH26E, it sits on the glareshield and doesn't block the view of the upper portion of the panel (this area is already blocked by the glare shield "brow", nor does it block forward view at all. The Proxalert is the only unit I'm aware of that displays threat aircraft squawk code. This is important to me as the threat level from a 1200 squawk aircraft, all other things being equal, is much higher than that from a discreet squawking aircraft. The discreet squawking aircraft is talking to ATC and probably has been told of my presence (I use a transponder). If the host, PCAS glider, has no transponder, then I guess it doesn't much matter what the threat aircraft is squawking - - not likely he is aware of you in any case! I have heard complaints from some R-5 owners that their unit did not alarm reliably or was inconsistent. I've not had that problem with mine at all. It finds traffic that I otherwise wouldn't see, some of which I never do see (g). When I'm talking to ATC getting flight following, the R-5 display is remarkably consistent with their advisories. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit and MKII yaw string "jcarlyle" wrote in message oups.com... I fly with a PCAS, Randy. I bought it because my glider club lies inside the Mode C veil of PHL, because an active military air base is 5 miles away, and because there are several airways that lie within several miles of us. It has gone off several times during each of the 5 flights that I've had it in my glider. As I get height and distance readings, it is usually pretty easy to spot the traffic. Once I had difficulty finding the threat, and it turned out to be a commuter running through the clouds above me. I wasn't too worried, because the MRX indicated that he was level and 600 feet higher than me, but if he had been descending I would have been sweating big time! Incidentally, I did a review of the various PCAS units available; you can read the discussion he http://tinyurl.com/pcmkw -John wrote: PCAS - Portable Collision Avoidance System http://www.zaonflight.com/mrx.html Is there anyone out there using this system in their glider? From what I have read, it seems like a like a pretty nice system to at least make you aware of what fast moving traffic is approaching your current airspace. If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. When I flew my glider in Moriarty last June, I was amazed at the number of large jets coming in from the east passing above and below me. I was talking and listening to ABQ approach control. ACT gave the approaching traffic my position and altitude and none of the airliners could look visually locate me. I saw all of them. I am sure that most of these pilots are running their descent and approach check lists, doing an approach briefing and saying a few last words to the passengers. At work when we get below 18,000 feet, I am always looking for gliders below the base of the clouds. I have never seen a glider in over 19 years of flying, but I know that they are there. I am hoping that they see me. It seems to me that a PCAS type of system would help me locate a majority of the biggest and fastest moving threats in the sky, commercial airliners, corporate jet and higher-end general aviation aicraft). Any PCAS users out there? Randy |
![]() "jcarlyle" wrote in message oups.com... One question - in your flight experience, does the way the R5 combines threats having the same squawk code on the same line of the display, showing only the closest threat's distance, and flip-flopping the various threat altitudes, cause you any confusion? -John No, that hasn't been an issue. When I first got the R-5, I tried using the included headset adapter for audio warnings in the Mooney. The sound level would not match the radio output well, too loud as I recall. Thought about adding a resistor to drop it some, but then decided that the bright red alarm LED, when right in front of the pilot, is all that's needed to get my attention. In the glider, the self contained beeper can be heard as well as the bright LED. I believe the Proxalert was initially designed with gliders in mind. bumper |
my glider club lies
inside the Mode C veil of PHL, because an active military air base is 5 miles away, and because there are several airways that lie within several miles of us. -John Great perspective. PCAS or no PCAS, the future for us glider pilots will be the same. EXTINCTION. rk |
![]() wrote: PCAS - Portable Collision Avoidance System http://www.zaonflight.com/mrx.html If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. But doesn't TCAS gives you resolution without the need to spot the threat? I was under the impression that it does. Ramy |
Ramy wrote:
wrote: PCAS - Portable Collision Avoidance System http://www.zaonflight.com/mrx.html If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. But doesn't TCAS gives you resolution without the need to spot the threat? I was under the impression that it does. Only if the threat is also equipped with TCAS... Marc |
That is NOT correct. TCAS was specifically designed to provide evasive
maneuver info for airliners that are on a collision course with GA aircraft. However, the GA aircraft needs a Mode C Transponder (and it needs to be turned on). Mike Schumann "Marc Ramsey" wrote in message ... Ramy wrote: wrote: PCAS - Portable Collision Avoidance System http://www.zaonflight.com/mrx.html If you think that an airliner in going to spot you just because you have a transponder, is a very false security. I fly a Boeing jet for a living and at times it is very hard to see another jet that ATC and TCAS alerted us to. But doesn't TCAS gives you resolution without the need to spot the threat? I was under the impression that it does. Only if the threat is also equipped with TCAS... Marc |
Collision Avoidance and ATC | Bubba | Soaring | 5 | September 1st 06 04:31 AM |
Getting the MOCA | Dan | Instrument Flight Rules | 59 | July 3rd 06 01:43 AM |
Collision Avoidance Systems | [email protected] | Products | 0 | May 21st 06 10:15 PM |
WANTED: WTB - Portable Ox system | ecktoeman | Aviation Marketplace | 0 | November 26th 03 01:18 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
