I've taken my aileron apart and notice corrosion on the thin aluminum
parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike |
Michael Horowitz wrote:
I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike Dunk it in a concentrated solution of lye, come back in a day, and you won't see any corrosion! OTOH, the aluminium will have totally dissolved. Lye as a aluminium cleaner is possible, in some very few circumstances. I'd suggest thin aluminium parts are not one. You might find a wirebrush in a drill is a good idea. And if they are in fact that corroded, consider if the strength has been affected. |
On 14 Oct 2006 13:25:41 GMT, Ian Stirling
wrote: Michael Horowitz wrote: I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike Dunk it in a concentrated solution of lye, come back in a day, and you won't see any corrosion! OTOH, the aluminium will have totally dissolved. Lye as a aluminium cleaner is possible, in some very few circumstances. I'd suggest thin aluminium parts are not one. You might find a wirebrush in a drill is a good idea. And if they are in fact that corroded, consider if the strength has been affected. I've wirebrushed 'til everything is shiny and was looking for an inexpensive cleaner prior to alodizing; maybe it is poor economy; someone suggested I look for the PPG line of cleaner and alodiner - that would help keep me from wrapping myself around the axle over which way to go. Thanks, Mike |
Phosphoric acid. Diluted about 50% with distilled water. apply with
brush. Leave on 3 minutes Rinse the hell out of it with fresh water and neutralize with baking soda. Taste the rinse water. If it tastes like acid, rinse some more. Dry, prime. |
"Michael Horowitz" wrote in message
... I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike I assume that this person is not a friend... I've used Drano to remove the remains of an aluminium piston from inside an iron cylinder (it was already bored to the max). It worked great... bye-bye aluminium. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() Michael Horowitz wrote: I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike It's almost against the rules of this newsgroup to make a positive suggestion, dedicated as we are to tearing one another down, but I'll risk it ;-) The Right Way to clean mild surface corrosion off aluminum is to soak it in a mild solution of phosphoric acid, and scrub it with a scotchbrite pad. Suitable solutions are sold as tile cleaners or "metal prep". Personally, I wouldn't use a stainless wire brush. It's a little too aggressive, and the deep scratches it will leave are likely places to start a fatigue crack. If Jasco Metal Prep (a common West Coast brand) and a scotchbrite pad won't take off the corrosion, you've got a Dead Part, IMHO. |
On 14 Oct 2006 09:19:06 -0700, "flybynightkarmarepair"
wrote: Michael Horowitz wrote: I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike It's almost against the rules of this newsgroup to make a positive suggestion, dedicated as we are to tearing one another down, but I'll risk it ;-) The Right Way to clean mild surface corrosion off aluminum is to soak it in a mild solution of phosphoric acid, and scrub it with a scotchbrite pad. Suitable solutions are sold as tile cleaners or "metal prep". Personally, I wouldn't use a stainless wire brush. It's a little too aggressive, and the deep scratches it will leave are likely places to start a fatigue crack. If Jasco Metal Prep (a common West Coast brand) and a scotchbrite pad won't take off the corrosion, you've got a Dead Part, IMHO. Thanks; I have a similar product I used to strip zinc off conduit for inexpensive tubing (for welding practice); I'll give it a whirl - Mike |
Michael Horowitz wrote: I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike Yes -- lye is used as an etch prior to alodyning. I would, however, use a mild phosphoric acid solution first to remove the corrosion. The aluminum should be left in the lye solution (NOT Drano, as it contains potassium hydroxide, in addition to the sodium hydroxide) for no more than 5 minutes -- just enough to etch the aluminum. The handbooks recommend a sodium hydroxide solution heated to 120 F for best results. |
Orval Fairbairn wrote: In article , Michael Horowitz wrote: I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike Yes -- lye is used as an etch prior to alodyning. I would, however, use a mild phosphoric acid solution first to remove the corrosion. The aluminum should be left in the lye solution (NOT Drano, as it contains potassium hydroxide, in addition to the sodium hydroxide) for no more than 5 minutes -- just enough to etch the aluminum. The handbooks recommend a sodium hydroxide solution heated to 120 F for best results. Sorry -- I neglected to state that you have to rinse the metal thoroughly after the lye etch, and before the alodine. |
"Orval Fairbairn" wrote in message
news ![]() In article , Orval Fairbairn wrote: In article , Michael Horowitz wrote: ... Yes -- lye is used as an etch prior to alodyning. I would, however, use a mild phosphoric acid solution first to remove the corrosion. The aluminum should be left in the lye solution (NOT Drano, as it contains potassium hydroxide, in addition to the sodium hydroxide) for no more than 5 minutes -- just enough to etch the aluminum. The handbooks recommend a sodium hydroxide solution heated to 120 F for best results. Sorry -- I neglected to state that you have to rinse the metal thoroughly after the lye etch, and before the alodine. Well, I guess you learn something every day. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Corrosion at Aluminum/Steel Junction | Front Office | Home Built | 17 | June 26th 06 01:12 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
