flap that is?
On Mon, 16 Oct 2006 21:02:58 -0500, "Jim Burns"
wrote: flap that is? Pump it up and down faster. Don |
Jim Burns wrote:
flap that is? You must be lowering the wrong handle. Mine flap. |
![]() Emily wrote: Jim Burns wrote: flap that is? You must be lowering the wrong handle. Mine flap. Yes. On the Baron 58 the flap handle and the gear handle are often reversed. |
Beech was correct in the old airplanes, flaps close to the
throttle and the landing gear a long reach. Mooney went one better with their gear switch on some models at the top center of the instrument panel But Cessna built 5-10 times as many airplanes as Beech so the FAA adopted the Cessna pattern in Part 23. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "cjcampbell" wrote in message ups.com... | | Emily wrote: | Jim Burns wrote: | flap that is? | | | You must be lowering the wrong handle. Mine flap. | | Yes. On the Baron 58 the flap handle and the gear handle are often | reversed. | |
flap that is?
Wine were the same - finally found the problem. You need to remove a few nuts & bolts Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
Wine were the same?
Wood er you tolk in bout? The cerk comes owt ferst then youse can pour the wine. Must be cold up thare, my lips don't work either when I'm cold. David Wine were the same - finally found the problem. You need to remove a few nuts & bolts Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
ok Mxsanic... how did you make us think you were Jim..
"Jim Burns" wrote in message ... flap that is? |
Jim Burns wrote:
flap that is? It's getting colder out; your bird is trying to conserve fuel. Try pouring about half a pound of sunflower seeds into it and then try again. Matt Roberds |
You know what!? THAT"S why it always wants to turn towards the south! I
just thought it was compass turning error, but I think it's wanting to migrate! Jim wrote in message news:KyYYg.4339$uJ2.2874@dukeread03... Jim Burns wrote: flap that is? It's getting colder out; your bird is trying to conserve fuel. Try pouring about half a pound of sunflower seeds into it and then try again. Matt Roberds |
Grob G102 Setup | BDS | Soaring | 11 | August 30th 05 03:42 PM |
Negative flaps for better low speed aileron control? | [email protected] | Soaring | 41 | August 25th 05 06:01 AM |
Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 04:54 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
