In rec.aviation.misc Peter wrote:
Flash alternatives (I believe it is a 1.8" HD inside) are extremely costly, around USD 2000 for 8GB, and I wonder how successful it would be to put in a 4GB SD card (for which there is a slot), put all maps on that, etc. I recently did something like this at work, for somewhat the same reason. In my case, I had a couple of accelerometers connected to a data acquisition card in an old desktop PC. The accelerometers got bolted into a car that was going to be crash-tested, and the PC got to go along for the ride. We decided that a rotating-platter drive probably wouldn't cut it, and looked for alternatives. What we ended up using was an "IDE 4000" series flash drive from M-Systems. This is flash memory in a package with an IDE connector; it looks and works just like a regular hard drive to the operating system. M-Systems sells a couple of different lines of drives - the ones that support the latest and fastest interfaces (Ultra ATA and SATA) are indeed expensive - about US$850-$900 for 2 GB. The IDE 4000 series is not quite as fast but is much cheaper; around $200- $250 for 2 GB in a 3.5" drive. We bought a 2 GB drive from Digi-Key, http://www.digi-key.com/ - current catalog page http://dkc3.digikey.com/PDF/T063/0865.pdf . This system was so old that it was running Windows 98. With the regular hard drive still in the system, I uninstalled all unneeded programs and got the total installed size of the system down to well under 1 GB. I then installed the flash drive and did a drive image copy from the hard drive to the flash drive (think Norton Ghost or similar). Then I removed the hard drive and let the system boot up on the flash drive... no problem. Benchmarking programs showed that the flash drive was indeed slower than the hard drive, but neither Windows nor the data-acquisition software seemed to care - I could still log data to the flash drive as fast as I needed to. The computer and the flash drive survived the wreck and everyone was happy. The problem is that Windoze itself accesses various bits of the HD anyway, and does anyone know which bits, and can they be moved to the SD card? Microsoft knows but they ain't tellin'. I think it's possible to split things up like this, but it will take a lot of trial and error to make sure you've got everything you need on the SD card. Even then, if you accidentally click on the wrong icon or something, Windows may still try to spin up the hard drive. If you have a real Windows installation CD (not a "restore" CD provided by the computer manufacturer), it might be interesting to remove the hard drive from the PC, install the SD card, boot up the Windows install CD, and see if you can convince it to install onto the SD card instead. If that doesn't work, then buying a flash drive that has an IDE interface, installing it along with your current hard drive, and doing a disk copy from your current drive to the flash drive (assuming you can fit everything onto the flash drive) will probably work. If there aren't enough hard drive connections on your portable PC, you may have to temporarily install both drives on a desktop PC to do the drive copy, then put the flash drive back in the portable. I hope this helps! Matt Roberds |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
