Turnbuckle Cleaning
Old October 18th 06, 02:37 AM posted to rec.aviation.homebuilt
Default Turnbuckle Cleaning
I've got a bunch of old turnbuckles that were apparently removed from planes
eons ago. They're covered with black, cruddy, dirt and grease. What's the best
way to clean these up?
Old October 18th 06, 02:52 AM posted to rec.aviation.homebuilt
Paulus
Ron;
Try soaking them in mineral spirits (varsol) for a few hours if you
need to use them, otherwise leave them as they are. They are probably
still coated with the original wax corrosion protective coating.
Paulus
Old October 18th 06, 06:31 AM posted to rec.aviation.homebuilt
RST Engineering
I tend to use small or large rotary devices that I can let run for hours or
days if needs be. If the turnbuckles are small, the little "rock polishers"
from Harbor Freight are good with whatever abrasive/solventive media you
wish in with the parts.
If the turnbuckles are large, a **clean** cement mixer withOUT the internal
stirring paddles and the holes blocked with botch buttons along with the
media work just fine.
The abrasive media of choice here for that sort of crap is "playground sand"
from Home Depot. It is very fine and clean, but you may wish to research
other less invasive media. Pistons and valves come out sparkling clean with
this media but you've got to figure out how to get ALL the remaining sand
off of the part ... generally a solvent soak followed by an air blast
followed by another solvent soak.
"Ron Wanttaja" wrote in message
planes
the best
Old October 20th 06, 11:43 PM posted to rec.aviation.homebuilt
.Blueskies.
"RST Engineering" wrote in message ...
:I tend to use small or large rotary devices that I can let run for hours or
: days if needs be. If the turnbuckles are small, the little "rock polishers"
: from Harbor Freight are good with whatever abrasive/solventive media you
: wish in with the parts.
: If the turnbuckles are large, a **clean** cement mixer withOUT the internal
: stirring paddles and the holes blocked with botch buttons along with the
: media work just fine.
: The abrasive media of choice here for that sort of crap is "playground sand"
: from Home Depot. It is very fine and clean, but you may wish to research
: other less invasive media. Pistons and valves come out sparkling clean with
: this media but you've got to figure out how to get ALL the remaining sand
: off of the part ... generally a solvent soak followed by an air blast
: followed by another solvent soak.
: Jim
Corn cob media works real well
check out: http://www.shorinternational.com/TumblingMedia.htm
Old November 3rd 06, 03:42 PM posted to rec.aviation.homebuilt
(Original question was about how to clean a thick layer of grease and dirt off
some old turnbuckles with minimum manual effort.)
Just as an update to folks...I ran one turnbuckle through the dishwasher. Did
well at taking off the surface crud, but it didn't really shine up the metal.
Going to try the rock-polisher next. My wife has a small one, with
buckshot-sized media for cleaning metal for jewelry work. Think the media is
too large, so I might try (unused) kitty litter.
Old November 3rd 06, 04:15 PM posted to rec.aviation.homebuilt
Bill Daniels
This may not solve everything but it's what I use.
I have an old collander and a rattle can of brake or carb/throttle body
cleaner from an auto parts store. I just squirt off the small parts in the
collander. Call it a poor mans parts cleaner. It's a pretty agressive
solvent so be careful what you use it on. The collander can also be used to
soak parts in a can of solvent.
For polish, why not use a fiber polishing wheel charged with some brass
polish. Comet copper and stainless cleaner from the kitchen also works on
some metals.
Bill Daniels
off
Did
metal.
is
Old November 3rd 06, 06:23 PM posted to rec.aviation.homebuilt
Anthony W
Try ground corn cob from the pet store (sold as small animal bedding) in
the rock tumbler. Add 1 ounce of automatic transmission fluid and
tumble for a couple hours before adding the parts to get it mixed.
Tony
Old October 18th 06, 08:20 AM posted to rec.aviation.homebuilt
Morgans[_2_]
best
How about taking them to a garage that has a parts cleaner, one that has a
vibrating action, with a pump circulating a solvent across the parts. A small
bribe ought to do it!
Jim in NC
Old October 19th 06, 05:51 AM posted to rec.aviation.homebuilt
Thanks a ton to everyone who replied. I've got several turnbuckles, and will
probably try a different approach on each. :-)
Old October 19th 06, 01:19 PM posted to rec.aviation.homebuilt
ChuckSlusarczyk
In article , Ron Wanttaja says...
Hey Ron
Since your taking the scientific approach how about letting us know the results?
As an ex NASA R & D guy I like the scientific approach :-)
See ya
Chuck S
Cleaning up brushes/dope? Michael Horowitz Home Built 5 June 23rd 11 02:11 AM
Cleaning out the hangar acroav8r Home Built 3 January 4th 06 07:31 AM
Cleaning bugs - the real secret Maule Driver Owning 11 January 18th 05 10:38 PM
landing gear cleaning Bob Miller Owning 4 July 5th 04 09:24 PM
Cleaning a 3-way TE probe Jack Glendening Soaring 37 November 5th 03 06:45 PM
