Today I went out to my plane to fly and found a very odd problem. When
I started the plane after taxiing over the fuel, I could only get it to run when the mixture was just at the edge of idle cut off. Moving it even 1/8 forward caused the engine to die right away. I did some diagnostics. At 1500 RPM I was getting 22lbs of fuel pressure (normal) and 5GPH in fuel flow (very high). As I moved the mixture about 1/8 forward that jumped to about 6GPH until the engine started to die. Running at 2000RPM moving the mixture control to 1/4 caused the engine to totally die. I run the engine like this for about 20 minutes to make sure it was hot but no improvement. I even stalled it several times (by moving the mixture to 1/4 rich) and restarted it. Each restart required 2 seconds of fuel boost so I don't think it was flooded. On one restart it ran totally fine, and I was getting about 3.0 GPH at 1500 at 1/4 mixture and about 3.8GPH at 2000 RPM at full rich. So I shut down again and tried it again and it was having the problem again, running about 5GPH at 1500 RPM with mixture at the edge of cut-off. The only thing I can think if is it would be a fuel servo issue. It seems a little bit intermitant but I seem to be able to make it happen often enough. Sadly, I'm not at the airport where I normally have maintenance done and I don't want to fly it now. I've been told to expect approx $3000 to OH the fuel servo. This is for an IO-360-A3B6 engine. -Robert |
Do you have an EGT on each cylinder? Do all the cylinders
run at the same temperature? Most fuel flow gauges actually measure pressure and are calibrated for know orifice sizes and fuel density. A plugged fuel spider line or nozzle or a nozzle that is too big will cause problems. Does the engine run rough at any time before it dies? If there is a mechanic who can help you, you can run some time fuel flow tests by placing containers on the engine and putting the fuel injectors in the containers ( clean painters can could be hung under the cylinders ) and run the boost pump for a few seconds, then measure the amount of fuel delivered. Repeat the test with just the fuel lines if necessary. Do this outside and have two fire guard with extinguishers ready. You can also check the fuel pump pressure directly. I would not fly the airplane in that condition, either see the maintenance people on that airport or pay your favorite mechanic to come to you. You might contact the factory for advise. You also might be able to rent or borrow parts to get the plane flown to a repair facility of your choice. -- James H. Macklin ATP,CFI,A&P "Robert M. Gary" wrote in message ups.com... | Today I went out to my plane to fly and found a very odd problem. When | I started the plane after taxiing over the fuel, I could only get it to | run when the mixture was just at the edge of idle cut off. Moving it | even 1/8 forward caused the engine to die right away. | I did some diagnostics. At 1500 RPM I was getting 22lbs of fuel | pressure (normal) and 5GPH in fuel flow (very high). As I moved the | mixture about 1/8 forward that jumped to about 6GPH until the engine | started to die. Running at 2000RPM moving the mixture control to 1/4 | caused the engine to totally die. | I run the engine like this for about 20 minutes to make sure it was hot | but no improvement. I even stalled it several times (by moving the | mixture to 1/4 rich) and restarted it. Each restart required 2 seconds | of fuel boost so I don't think it was flooded. | On one restart it ran totally fine, and I was getting about 3.0 GPH at | 1500 at 1/4 mixture and about 3.8GPH at 2000 RPM at full rich. So I | shut down again and tried it again and it was having the problem again, | running about 5GPH at 1500 RPM with mixture at the edge of cut-off. | | The only thing I can think if is it would be a fuel servo issue. It | seems a little bit intermitant but I seem to be able to make it happen | often enough. Sadly, I'm not at the airport where I normally have | maintenance done and I don't want to fly it now. I've been told to | expect approx $3000 to OH the fuel servo. This is for an IO-360-A3B6 | engine. | | -Robert | |
Jim Macklin wrote:
Do you have an EGT on each cylinder? Do all the cylinders run at the same temperature? Most fuel flow gauges actually measure pressure and are calibrated for know orifice sizes and fuel density. A plugged fuel spider line or nozzle or a nozzle that is too big will cause problems. Fuel pressure stayed around 22lbs. Flow is measured by a transducer spinning wheel ala JPI. Adding that was the best buy I ever made. What would have happened if this happened in flight? -Robert |
You'd get busy finding a nice place to land.
"Robert M. Gary" wrote in message ups.com... | Jim Macklin wrote: | Do you have an EGT on each cylinder? Do all the cylinders | run at the same temperature? | | Most fuel flow gauges actually measure pressure and are | calibrated for know orifice sizes and fuel density. A | plugged fuel spider line or nozzle or a nozzle that is too | big will cause problems. | | Fuel pressure stayed around 22lbs. Flow is measured by a transducer | spinning wheel ala JPI. Adding that was the best buy I ever made. | | What would have happened if this happened in flight? | | -Robert | |
We replaced our fuel servo on our '79 Mooney 201 in June at annual time.
They (Money Service Center) told us that the fuel servos last around 1000 hours and then need to be rebuilt. You can tell if it is time becasue the adjustment screw will be just about out of adjustment. We were in a hurry for our servo so replaced ours with a rebuilt unit instead of having ours rebuilt. The cost was around 1.9 AMU's and a couple hours labor. No where near the 3.0 AMU's you were quoted. I think if you wanted to send yours out for rebuild it would be around 1.5 AMU's and this includes the lines and spider. Jon Kraus '79 Mooney 201 4443H @ UMP Robert M. Gary wrote: Today I went out to my plane to fly and found a very odd problem. When I started the plane after taxiing over the fuel, I could only get it to run when the mixture was just at the edge of idle cut off. Moving it even 1/8 forward caused the engine to die right away. I did some diagnostics. At 1500 RPM I was getting 22lbs of fuel pressure (normal) and 5GPH in fuel flow (very high). As I moved the mixture about 1/8 forward that jumped to about 6GPH until the engine started to die. Running at 2000RPM moving the mixture control to 1/4 caused the engine to totally die. I run the engine like this for about 20 minutes to make sure it was hot but no improvement. I even stalled it several times (by moving the mixture to 1/4 rich) and restarted it. Each restart required 2 seconds of fuel boost so I don't think it was flooded. On one restart it ran totally fine, and I was getting about 3.0 GPH at 1500 at 1/4 mixture and about 3.8GPH at 2000 RPM at full rich. So I shut down again and tried it again and it was having the problem again, running about 5GPH at 1500 RPM with mixture at the edge of cut-off. The only thing I can think if is it would be a fuel servo issue. It seems a little bit intermitant but I seem to be able to make it happen often enough. Sadly, I'm not at the airport where I normally have maintenance done and I don't want to fly it now. I've been told to expect approx $3000 to OH the fuel servo. This is for an IO-360-A3B6 engine. -Robert |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Jet fuel A-1 specific gravity | [email protected] | Piloting | 7 | May 20th 06 04:39 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 09:10 PM |
Cherokee Six Fuel problem | EDR | General Aviation | 1 | August 15th 03 03:03 PM |
