Thankfully the pilot is OK, but for me, another ship in the skies to avoid is one thing, a glider without a pilot is technology without need. Can someone explain to me the benefit of this weapon?
http://www.reflector-online.com/vnew.../45383b26859e8 Bagmaker |
Have you ever been in the battle field and get shot at..?
this is not a "glider", but a test design of a powered Unmanned Arial Vehicle (UAV) based on a glider design with an engine attached.. the "test pilot" was there as a safety pilot.. There are dozen's of UAV designs and sizes, each with their own "combat mission" and used every day to collect information on the battle field.. and to keep the ground based operator with remote controlled sensors out of harms way. BT "bagmaker" wrote in message ... Thankfully the pilot is OK, but for me, another ship in the skies to avoid is one thing, a glider without a pilot is technology without need. Can someone explain to me the benefit of this weapon? http://tinyurl.com/yckmho Bagmaker -- bagmaker |
![]() "BT" wrote in message news:uIh_g.5973$gM1.2824@fed1read12... Have you ever been in the battle field and get shot at..? this is not a "glider", but a test design of a powered Unmanned Arial Vehicle (UAV) based on a glider design with an engine attached.. the "test pilot" was there as a safety pilot.. There are dozen's of UAV designs and sizes, each with their own "combat mission" and used every day to collect information on the battle field.. and to keep the ground based operator with remote controlled sensors out of harms way. I doubt very much the utility of this UAV. As a former designer of weapon systems and surveillance gear using UAVs I have to say a glider with its very low speed would not last long over most battlefields. UAVs are mostly used for low level surveillance AFAIK and the ones I have been involved with (two UK types) all flew at quite a high speed to avoid being shot down. Alistair Wright ex BAE Systems Scotland |
![]() Alistair Wright wrote: "BT" wrote in message news:uIh_g.5973$gM1.2824@fed1read12... Have you ever been in the battle field and get shot at..? this is not a "glider", but a test design of a powered Unmanned Arial Vehicle (UAV) based on a glider design with an engine attached.. the "test pilot" was there as a safety pilot.. There are dozen's of UAV designs and sizes, each with their own "combat mission" and used every day to collect information on the battle field.. and to keep the ground based operator with remote controlled sensors out of harms way. I doubt very much the utility of this UAV. As a former designer of weapon systems and surveillance gear using UAVs I have to say a glider with its very low speed would not last long over most battlefields. UAVs are mostly used for low level surveillance AFAIK and the ones I have been involved with (two UK types) all flew at quite a high speed to avoid being shot down. Alistair Wright ex BAE Systems Scotland The 'glider' looks a lot like a Sparrow Hawk to me. Chip F |
"chipsoars" wrote in message
oups.com... Alistair Wright wrote: "BT" wrote in message news:uIh_g.5973$gM1.2824@fed1read12... Have you ever been in the battle field and get shot at..? this is not a "glider", but a test design of a powered Unmanned Arial Vehicle (UAV) based on a glider design with an engine attached.. the "test pilot" was there as a safety pilot.. There are dozen's of UAV designs and sizes, each with their own "combat mission" and used every day to collect information on the battle field.. and to keep the ground based operator with remote controlled sensors out of harms way. I doubt very much the utility of this UAV. As a former designer of weapon systems and surveillance gear using UAVs I have to say a glider with its very low speed would not last long over most battlefields. UAVs are mostly used for low level surveillance AFAIK and the ones I have been involved with (two UK types) all flew at quite a high speed to avoid being shot down. Alistair Wright ex BAE Systems Scotland The 'glider' looks a lot like a Sparrow Hawk to me. Chip F It is.. a Sparrow Hawk with an engine added, and when he got the contract to build lot's or "Owls" the commercial customers for his "Sparrow Hawk" were pushed aside. BT |
![]() Alistair Wright wrote: "BT" wrote in message news:uIh_g.5973$gM1.2824@fed1read12... Have you ever been in the battle field and get shot at..? this is not a "glider", but a test design of a powered Unmanned Arial Actually it is a glider. it is the Windward Performance, Sparrowhawk. MSU has a program to turn it into a UAV. I understand the production of the Sparrowhawk is moving from Bend to MSU. Robert Mudd Moriarty, New Mexico |
Mike Lindsay wrote:
In article om, writes Actually it is a glider. it is the Windward Performance, Sparrowhawk. MSU has a program to turn it into a UAV. I understand the production of the Sparrowhawk is moving from Bend to MSU. Robert Mudd Moriarty, New Mexico It might make a better UAV if they can fix the little problem of the wings falling off under operational conditions. "Fall off" or "torn off"? Do we know it failed below design limitations? -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Sat, 21 Oct 2006 11:19:51 +0100, "Alistair Wright"
wrote: "BT" wrote in message news:uIh_g.5973$gM1.2824@fed1read12... Have you ever been in the battle field and get shot at..? this is not a "glider", but a test design of a powered Unmanned Arial Vehicle (UAV) based on a glider design with an engine attached.. the "test pilot" was there as a safety pilot.. There are dozen's of UAV designs and sizes, each with their own "combat mission" and used every day to collect information on the battle field.. and to keep the ground based operator with remote controlled sensors out of harms way. I doubt very much the utility of this UAV. As a former designer of weapon systems and surveillance gear using UAVs I have to say a glider with its very low speed would not last long over most battlefields. UAVs are mostly used for low level surveillance AFAIK and the ones I have been involved with (two UK types) all flew at quite a high speed to avoid being shot down. Before you can shoot it down you have to SEE it. If it's made of fiberglass, forget seeing it on radar, and once it gets in close, gets its pictures and transmits them, who cares if it's shot down? You're already busted. The next object overhead will be coming in very fast, with a load of explosives aboard. rj |
There have been hints of interest from DARPA about autonomous UAV's that
utilize soaring techniques. In Iraq and Afganistan there are often good thermals under bright, dusty skies. A motorglider-like UAV that can sustain itself by soaring could extend its loiter time significantly. As for stealth, in gliding mode the UAV would have very low thermal and a acoustic signatures. Further out is daylight visual stealth - not exactly an invisibility cloak but pretty darn good. If the airframe could be coated with an OLED film that could make it glow at exactly the same hue and brightness as a dusty sky as seen from the point of interest, it would be very difficult to see. A high L/D glide mode would allow it to approach an area of interest very stealthily. This is all speculation on my part. I don't know what they are up to. Bill Daniels "Ralph Jones" wrote in message ... On Sat, 21 Oct 2006 11:19:51 +0100, "Alistair Wright" wrote: "BT" wrote in message news:uIh_g.5973$gM1.2824@fed1read12... Have you ever been in the battle field and get shot at..? this is not a "glider", but a test design of a powered Unmanned Arial Vehicle (UAV) based on a glider design with an engine attached.. the "test pilot" was there as a safety pilot.. There are dozen's of UAV designs and sizes, each with their own "combat mission" and used every day to collect information on the battle field.. and to keep the ground based operator with remote controlled sensors out of harms way. I doubt very much the utility of this UAV. As a former designer of weapon systems and surveillance gear using UAVs I have to say a glider with its very low speed would not last long over most battlefields. UAVs are mostly used for low level surveillance AFAIK and the ones I have been involved with (two UK types) all flew at quite a high speed to avoid being shot down. Before you can shoot it down you have to SEE it. If it's made of fiberglass, forget seeing it on radar, and once it gets in close, gets its pictures and transmits them, who cares if it's shot down? You're already busted. The next object overhead will be coming in very fast, with a load of explosives aboard. rj |
Bush was a carrier pilot. I saw it with my own eyes. | ArtKramr | Military Aviation | 7 | September 4th 04 08:24 PM |
Some Fiction For Interest | Badwater Bill | Rotorcraft | 8 | March 6th 04 03:45 AM |
Navy eyes new aviation vision | Otis Willie | Naval Aviation | 0 | December 19th 03 10:50 PM |
J4...for your eyes ONLY..... | TomnKeyLargo | Soaring | 0 | October 13th 03 06:42 PM |
