Solar storms spell trouble for GPS
Old October 25th 06, 12:12 PM posted to rec.aviation.piloting
Larry Dighera
Default Solar storms spell trouble for GPS
http://www.newscientisttech.com/chan...e-for-gps.html
SOLAR flares can drown out GPS signals with potentially serious
consequences for airlines, emergency services, and anyone relying on
satellite navigation.
It turns out these bursts of charged particles, which produce auroras
and geomagnetic storms, also generate radio waves in the 1.2 and
1.6-gigahertz bands used by GPS.
How was such a clash missed? Because GPS receivers only became common
during a period of low solar activity. By 2011 solar flares will reach
the peak of their cycle and receivers will likely fail. Or so
Alessandro Cerruti of Cornell University, New York, told a meeting of
the Institute of Navigation in Fort Worth, Texas, last week. The only
solution would be to redesign GPS receivers or satellites, which may
not be practical, says Cerruti.
From issue 2572 of New Scientist magazine, 07 October 2006, page 27
Old October 25th 06, 12:17 PM posted to rec.aviation.piloting
Jim Macklin
BFD, All those radios are called Aids to navigation for a
reason, they are conveniences. CAL found Paris with just a
compass and a chart.
"Larry Dighera" wrote in message
serious
relying on
produce auroras
1.2 and
became common
flares will reach
so
meeting of
week. The only
which may
2006, page 27
Old October 25th 06, 02:38 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 25 Oct 2006 06:17:38 -0500, "Jim Macklin"
wrote in
Were you aware of the design flaw in GPS as implemented? I just
thought it might be a good idea to provide the information to those
weren't.
Of course, this issue makes no mention of solar mass ejections, that
can potentially knock out any satellite.
It appears that we are (finally?) seeing some technological innovation
tickling down to the GA fleet, but I'm becoming uneasy with the
apparent lack of robustness engineered in these early systems.
CAL found Paris with just a compass and a chart.
Yes. It was an Earth Inductor Compass*. I've never seen one of those
in any aircraft in which I've flown, let alone piloted.
* http://oldbeacon.com/beacon/earth_inductor_compass.htm
Old October 25th 06, 03:34 PM posted to rec.aviation.piloting
Ross Richardson[_2_]
wrote in
weren't.
Did anybody see NOVA on PBS last night. The earth is overdue for a pole
reversal. According to the program, we are already seeing issues towards
that. Interesting program.
Regards, Ross
C-172F 180HP
KSWI
Old October 25th 06, 08:43 PM posted to rec.aviation.piloting
Jim Macklin
The Earth is rotating and orbiting within a strong magnetic
field of the Sun, [not to mention the whole Universe].
The magnetic pole is not located on the axis and as a result
the variation wanders. It appears that the Earth's magnetic
field is electromagnetic and AC.
The Earth doesn't physically flip over, the phase angle
flips.
"Ross Richardson" wrote in message
| wrote in
a
I just
| weren't.
ejections, that
with the
systems.
seen one of those
overdue for a pole
issues towards
| Regards, Ross
| C-172F 180HP
| KSWI
Old October 25th 06, 09:11 PM posted to rec.aviation.piloting
flips.
| wrote in
a
I just
| weren't.
ejections, that
with the
systems.
seen one of those
overdue for a pole
issues towards
| Regards, Ross
| C-172F 180HP
| KSWI
What this program stated and I had read it elsewhere, is the magnetic
core within the earth had flipped every 200K to 700K years. Geologist
know how to figure this out from core samples. They said the last one
was over 700K years ago. The north magnetic pole (as we know it) flips
to the south pole.
Regards, Ross
C-172F 180HP
KSWI
Old October 25th 06, 05:37 PM posted to rec.aviation.piloting
Mxsmanic
Larry Dighera writes:
What design flaw?
They seem to be designed just like personal computers, which is very
bad and very dangerous for safety-of-life systems.
Old October 25th 06, 08:38 PM posted to rec.aviation.piloting
Jim Macklin
An early version if the slaved compass, just like nearly all
cabin class and all G1000 systems use.
| wrote in
a
I just
to those
| weren't.
ejections, that
with the
systems.
one of those
Old October 25th 06, 11:07 PM posted to rec.aviation.piloting
Larry Dighera
| wrote in
a
I just
to those
| weren't.
ejections, that
with the
systems.
one of those
On Wed, 25 Oct 2006 14:38:27 -0500, "Jim Macklin"
wrote in
Correct me if I'm wrong, but doesn't a slaved compass require
electrical power to operate? "Slim's" Earth Inductor Compass didn't
require any power except that generated by the coil rotating in the
Earth's magnetic field. So if I'm correct, those pilots flying behind
a dead glass-cockpit would only have a whiskey compass to navigate
with.
Old October 25th 06, 11:54 PM posted to rec.aviation.piloting
Jim Macklin
The Earth compass, was powered by a windmill, just as many
crop dusters power their spray pumps, and similarly to using
a venturi to power gyros, if you're flying you have power.
Using a retractable generator is even part of the modern jet
airliner.
Yes, when your G1000 dies, you will have very limited
navigation or even communication options. Check out the
difference between a Beech Baron or Bonanza G36/G58 and a
Cessna NAV III on the manual section at Garmin. com
| | wrote in
for
| a
implemented?
| I just
information
| to those
| | weren't.
| ejections, that
| with the
| systems.
seen
| one of those
| wrote in
all
require
Compass didn't
rotating in the
flying behind
navigate
| with.
Removing Ethanol from Gas? Jay Honeck Piloting 67 August 16th 06 03:29 PM
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Piloting 7 March 14th 05 07:36 AM
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Soaring 7 March 14th 05 07:36 AM
