Landing on the numbers
Old October 30th 06, 03:43 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Landing on the numbers
What does the expression "landing on the numbers" mean?
Old October 30th 06, 04:30 AM posted to rec.aviation.piloting,rec.aviation.student
gpsman
It's an old Vietnam-era military aviation tradition.
A firebase support crew twists up a few "numbers" (aka blunts, rounds,
hooters, spliffs, joints) and fixes them to the runway/LZ with duct
tape or a rock, ammo can, etc. They were awarded to the first chopper
crew returning from a mission who lands close enough to collect them.
FYI:
Vietnam: A country in SE Asia.
Vietnam Era: Between August 5, 1964 and May 7, 1975
Firebase: An secure or semi-secure encampment designed to provide fire
support to infantry via helicopters and howitzers.
Support: The inverse of resistance.
Runway: A defined rectangular area on a land airport that is prepared
for the landing and takeoff of aircraft.
LZ: Landing zone.
Duct tape: An adhesive tape intended to seal joints in sheet metal duct
work.
Rock: A piece of stone.
Ammo can: A metal container for holding ammunition.
Chopper: A helicopter.
Helicopter: An aircraft that obtains its primary lift from the rotation
of overhead blades.
- gpsman
Old October 30th 06, 05:19 AM posted to rec.aviation.piloting,rec.aviation.student
Wade Hasbrouck
Interesting insight/history... Today it means pretty much what it says...
touching down on the runway numbers. Pretty straight forward... While it
is probably debatable, in my opinion, this is not always the safest thing to
do, I believe most will aim for the center of the first third of the runway.
Reason "landing on the numbers" is not always safe, is if you "miss."
Missing "long" in this case isn't bad, but missing "short" can be, and many
things can happen to cause you to miss short, like wind dying down,
turbulence, etc. There are times when you will probably want to land on
the numbers, such as a medical emergency on board and need to get to medical
assistance as quickly as possible.
"gpsman" wrote in message
FYI:
LZ: Landing zone.
work.
of overhead blades.
- gpsman
Old October 30th 06, 04:47 PM posted to rec.aviation.piloting,rec.aviation.student
turbulence, etc.
A good pilot anticipates performance decrease in turbulence and
wind shear, and still hits the numbers. There are a lot of bush
operators who have to get in and out of really short strips; aiming for
the first third is not good enough and is a good way to either break an
airplane or get fired. Those guys can put an airplane exactly where
they want it, every time, in almost any weather condition. Most pilots
could do it, too, if they just took it seriously enough. If we can keep
a car between the lines on the highway for thousands of miles because
to fail to do so will eventually result in an accident, we can learn to
handle an airplane with consummate skill. Too many of us are satisfied
with mediocre ability.
In the late '70s I towed gliders on weekends. I was a 65-hour
pilot when I began this, and since it was an unpaid position a
commercial ticket wasn't required. Within 25 or 30 landings I could put
that airplane exactly where I wanted it, and stop it in less distance
than the book cited for landing roll. The glider guys loved it because
it minimized turnaround times. I didn't have to taxi half a mile back
to the starting point.
Dan
Dan
Old October 31st 06, 12:00 AM posted to rec.aviation.piloting,rec.aviation.student
Kyle Boatright
ps.com...
it
to
runway.
many
turbulence, etc.
Dan
I used to be a big believer in landing on the numbers until I really thought
about it. My airplane requires 1,000' or so to roll-out under light
braking. Also, I probably use another 250' in the flare (slick airplane,
course pitch prop). So, what benefit is it to me to land on the numbers
when I'm flying from a 5,500' runway? I can still do stop and go landings
if I touch down 500' or 1,000' down the strip, and I'm not risking an
undershoot if something bad happens. By the way, I fly fairly steep
power-off approaches beginning when I'm even with the numbers on downwind. I
frequently end up slipping all the way to the flare.
One thing that concerns me is when I see someone coming in on a flat, slow,
power-on approach in an attempt to put the airplane on the numbers. That's
a great way to land just short if the engine burps.
KB
Old November 2nd 06, 02:58 AM posted to rec.aviation.piloting,rec.aviation.student
vincent p. norris
So, what benefit is it to me to land on the numbers when I'm flying from a 5,500' runway?
The practice enables you to do it when you must.
The only place I deliberately land long is at Dulles, to save a looong
taxi.
By the way, I fly fairly steep power-off approaches beginning
That's the right way. Always be in a position to make the runway.
That's the wrong way.
vince norris
Old November 2nd 06, 08:37 AM posted to rec.aviation.piloting,rec.aviation.student
Roger (K8RI)
On Sun, 29 Oct 2006 21:19:45 -0800, "Wade Hasbrouck"
"Landing on the Numbers" has been one of my pet peeves for many years.
My motto is don't land long on short runways and don't land short on
long runways.
Rather than aim for the numbers I was taught to aim for the beginning
of the touchdown zone if such exists, or any particular spot if space
permits and it's safe.
www.rogerhalstead.com
Old October 30th 06, 09:00 AM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Gpsman,
of overhead blades.
That one you got wrong. So ugly the earth repels it, and all that ;-)
Thomas Borchert (EDDH)
Old October 30th 06, 12:15 PM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
FYI:
You left out the two words that still puzzle me: "twists up", "numbers"
and "collect". By your narrative, "numbers" sounds like it means
"ammunition", although I suppose it could refer to mammary glands or
illegal drugs.
"twists up" sounds like it ought to mean "concocts" (supporting the last
definition of "numbers" and giving a reason to collect, in the standard
sense of the word).
Have I got that right?
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old October 30th 06, 05:24 AM posted to rec.aviation.piloting,rec.aviation.student
BT
"Brick One"
"Mxsmanic" wrote in message
Landing on a sloping runway with different wind velocities Tony Cox Piloting 47 October 16th 06 03:31 PM
Check this Approach & Landing out! nmg175 Naval Aviation 5 September 27th 06 02:07 AM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 05:40 PM
Grumman E2C Parts Numbers needed CaptAro Restoration 0 July 9th 04 12:50 AM
