Hi All!
I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
I have never flown a Discus, nor anything close, but when I was
learning to fly 23 years ago, my instructor told me to keep a little top rudder in turns and when thermalling. I tried to keep that in mind but it was not until I transitioned to glass years later that I really discovered why: slipping a little makes centering the thermal easier and that results in better climb. This has been true whether I was flying a 2-33, 1-34, BG-12, even a T-31, but it is especially noticable in my LS-1. Fox Two wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
raulb wrote:
I have never flown a Discus, nor anything close, but when I was learning to fly 23 years ago, my instructor told me to keep a little top rudder in turns and when thermalling. I tried to keep that in mind but it was not until I transitioned to glass years later that I really discovered why: slipping a little makes centering the thermal easier and that results in better climb. This has been true whether I was flying a 2-33, 1-34, BG-12, even a T-31, but it is especially noticable in my LS-1. Dick Johnson wrote a SOARING article about this that is on the SSA webpage (members only). There seems to be some question about how much of a slip is desirable when a glider has winglets, since the winglets could have an excessively low or high angle of attack. Fox Two wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
Of all the gliders I have flown or owned, the one that really seemed to benefit from a bit of top rudder was my ASW-20. Anecdotal evidence suggests that winglets help in thermals and reduce the need for this little slip. I find my D2 seems to ride on rails in thermals, probably because of the double dihedral and winglets, and I just keep the yaw string centered. You may find the nose-high attitude of the D2 will take some getting used to. Enjoy your new ship! Mike On Oct 30, 6:26 pm, "Fox Two" wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
Chris: Now all you need is; A D2b, and B thermals. Zulu |
Chris,
The D2 definitely has to be slipped in the turn. Ask Davis or Darroze and they will confirm this. Just fly it EXACTLY the same way you would fly your Discus CS. Cheers, Ben At 20:36 31 October 2006, Mike The Strike wrote: Of all the gliders I have flown or owned, the one that really seemed to benefit from a bit of top rudder was my ASW-20. Anecdotal evidence suggests that winglets help in thermals and reduce the need for this little slip. I find my D2 seems to ride on rails in thermals, probably because of the double dihedral and winglets, and I just keep the yaw string centered. You may find the nose-high attitude of the D2 will take some getting used to. Enjoy your new ship! Mike On Oct 30, 6:26 pm, 'Fox Two' wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
I just reviewed a couple of cockpit photos I took of my D2 thermalling
and note that the yaw string in both cases shows about a 10 degree slip. While flying, I haven't noticed that I needed to deliberately keep this slip and wonder if this is the way the ship just sits. Or perhaps I just fly it that way without thinking? Mike On Nov 2, 2:42 am, Ben Flewett wrote: Chris, The D2 definitely has to be slipped in the turn. Ask Davis or Darroze and they will confirm this. Just fly it EXACTLY the same way you would fly your Discus CS. Cheers, Ben At 20:36 31 October 2006, Mike The Strike wrote: Of all the gliders I have flown or owned, the one that really seemed to benefit from a bit of top rudder was my ASW-20. Anecdotal evidence suggests that winglets help in thermals and reduce the need for this little slip. I find my D2 seems to ride on rails in thermals, probably because of the double dihedral and winglets, and I just keep the yaw string centered. You may find the nose-high attitude of the D2 will take some getting used to. Enjoy your new ship! Mike On Oct 30, 6:26 pm, 'Fox Two' wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
I read an article which mentioned that the only way you could really tell via yawstring if in a slip was if it was placed at the CG. by positioning the string forward, i.e., on the canopy, one could expect it to show a small amount of error. I find that my b likes to climb in a slight skid for some reason. sounds weird (and a bit dangerous) but works for me At 16:31 02 November 2006, Mike The Strike wrote: I just reviewed a couple of cockpit photos I took of my D2 thermalling and note that the yaw string in both cases shows about a 10 degree slip. While flying, I haven't noticed that I needed to deliberately keep this slip and wonder if this is the way the ship just sits. Or perhaps I just fly it that way without thinking? Mike On Nov 2, 2:42 am, Ben Flewett wrote: Chris, The D2 definitely has to be slipped in the turn. Ask Davis or Darroze and they will confirm this. Just fly it EXACTLY the same way you would fly your Discus CS. Cheers, Ben At 20:36 31 October 2006, Mike The Strike wrote: Of all the gliders I have flown or owned, the one that really seemed to benefit from a bit of top rudder was my ASW-20. Anecdotal evidence suggests that winglets help in thermals and reduce the need for this little slip. I find my D2 seems to ride on rails in thermals, probably because of the double dihedral and winglets, and I just keep the yaw string centered. You may find the nose-high attitude of the D2 will take some getting used to. Enjoy your new ship! Mike On Oct 30, 6:26 pm, 'Fox Two' wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
I constructed a to-scale CAD drawing of a glider in a very agressive 300
foot diameter turn and looked at the angle difference between a nose and a CG yaw string. - it's something like a 1/100 of a degree. The difference is so small you'd never see it. In fact, it's likely that any difference would be swamped by local turbulent flow. Bill Daniels "P Ilatus" wrote in message ... I read an article which mentioned that the only way you could really tell via yawstring if in a slip was if it was placed at the CG. by positioning the string forward, i.e., on the canopy, one could expect it to show a small amount of error. I find that my b likes to climb in a slight skid for some reason. sounds weird (and a bit dangerous) but works for me At 16:31 02 November 2006, Mike The Strike wrote: I just reviewed a couple of cockpit photos I took of my D2 thermalling and note that the yaw string in both cases shows about a 10 degree slip. While flying, I haven't noticed that I needed to deliberately keep this slip and wonder if this is the way the ship just sits. Or perhaps I just fly it that way without thinking? Mike On Nov 2, 2:42 am, Ben Flewett wrote: Chris, The D2 definitely has to be slipped in the turn. Ask Davis or Darroze and they will confirm this. Just fly it EXACTLY the same way you would fly your Discus CS. Cheers, Ben At 20:36 31 October 2006, Mike The Strike wrote: Of all the gliders I have flown or owned, the one that really seemed to benefit from a bit of top rudder was my ASW-20. Anecdotal evidence suggests that winglets help in thermals and reduce the need for this little slip. I find my D2 seems to ride on rails in thermals, probably because of the double dihedral and winglets, and I just keep the yaw string centered. You may find the nose-high attitude of the D2 will take some getting used to. Enjoy your new ship! Mike On Oct 30, 6:26 pm, 'Fox Two' wrote: Hi All! I'm currently a Discus CS driver with a new D2-b coming in about 3 months from the factory. I've found that thermalling the CS with the yaw string slightly high in the turn yields a better climb - I'm curious to hear about thermalling techniques from the D2 veterans. Thanks in advance! Chris, F2 |
| Glider Crash - Minden? | Mitch | Soaring | 141 | September 13th 06 08:31 PM |
| Libelle thermalling techniques | AdamLibelle | Soaring | 6 | September 5th 06 07:40 PM |
| The new art of thermalling - with a kite... | [email protected] | Soaring | 3 | July 30th 06 05:06 AM |
| Bronze Badge question | [email protected] | Soaring | 32 | January 11th 06 10:19 PM |
| Hands off thermalling | John Jones | Soaring | 24 | April 26th 04 04:07 PM |
