In my last post, I mentioned that I was curently off the airshow circut
for a number of reasons. Greatest of which is the issue with the homebuilt trailer that formerly hauled my plane and equipment. Well, for those of you that havn't heard this before, here's the whole story. The trailer was originally intended to make (and last for) one trip from Covington, GA to Nag's Head, NC and back. Nothing more. It was also originally designed to be as small, light, and cheap as possible. My original tow vehicle was a 4-cyl. Chevy Cavalier, and anything resembling a "normal" trailer just wouldn't work. So I cobbled together a bunch of cheap junk. The rolling chasis started with a 4x8 bolt-together kit from Northern Tool. The kit was then stretched 13 ft. by replacing the factory tongue with an 11 ga. 2x3" steel box-tube. Add a pair of 12"x4.8" wheels and tires. The deck is 4'x18', pressure-treated 2x4s on 24" ctrs. covered with 3/4" pressure-treated plywood. Everything is screwed and glued and the corners are steel plate braced. The box was originally 4'w x 4 1/2' h, 1x2's covered with corrugated roofing steel. This configuration leaked like the Titanic was nearly unworkable due to the tight fit of the wings inside. I used the trailer like this for my first show in Raleigh and my second show in Atlanta. This configuration also proved nearly uncontrollable behind the little Cavalier, which had neither the horsepower, nor the brakes or suspension to handle the load. Following the second show, I tore off the original box using a sledgehammer. I then rebuilt the box using 26 ga. steel studs for framing, and 26 ga. steel "5-V" flat roofing pannels. I also added a 45-degree v-nose. The new demensions were now 4'w. x 6'h. x 18'l. with an additional 2' in the v-nose. I used the trailer in this confiruration for the remainder of the 2003 and 2004 seasons, towing it behind a rented Chevy 3500 Dually. It worked fairly well in this configuration in the light winds of the southeast, and recorded about 5,000 miles. I upgraded to a 2002 Dodge Dakota V-8 for the ferry-trip to Colorado. At about the 2,000 mile mark, I encountered a violent thunderstorm just outside of Byers, CO. Keep in mind that this territory is open plains with nothing to break the wind. I intended to turn the rig into the wind if I encountered a storm, since I knew the trailer was good for at least 100 MPH in tow. But, two lane roads aren't very accomodating and I had to turn broadside for 3/4 of a mile to reach the shelter of a truck stop. Of course, as soon as I turned, a 50+MPH gust hit me and rolled the trailer. Damage was limited to the coupler, left fender, and left front corner, and 2 hours later I was rolling again. Thank you, Byers citizens. Since then, I've experimented by loading the trailer with sandbags. At its max gross of 1150 lbs., its still uncontrollable in winds over 20 mph. There's not enough steel in the rolling chasis to change axles or go to a tandem-axle. Since the trailer is currently configured to haul my wings standing on their leading edges, ther's no real way to just cut a little off the top. And since ballast doesn't seem to help much, I'll have to concentrate on lowering the side profile. This means the wings will now have to be transported flat, rather than on edge. That will allow me to reduce the side profile by at least 1/2, if not more. But it also means the new trailer box will have to be about 6' wide, and the wings will need to ride in some sort of jig that will allow them to be packaged and loaded as a single protected unit. I'm currently working on various methods of accomplishing the new goal without spending too much cash. I think most of the steel framing and sheet metal can be used again. But I'll have to work out a new decking system, etc. Harry Frey Wright Brothers Enterprises Specialist in impractical aircraft and cheap junky trailers |
wright1902glider wrote:
Since then, I've experimented by loading the trailer with sandbags. At its max gross of 1150 lbs., its still uncontrollable in winds over 20 mph. There's not enough steel in the rolling chasis to change axles or go to a tandem-axle. Since the trailer is currently configured to haul my wings standing on their leading edges, ther's no real way to just cut a little off the top. And since ballast doesn't seem to help much, I'll have to concentrate on lowering the side profile. This means the wings will now have to be transported flat, rather than on edge. That will allow me to reduce the side profile by at least 1/2, if not more. But it also means the new trailer box will have to be about 6' wide, and the wings will need to ride in some sort of jig that will allow them to be packaged and loaded as a single protected unit. Never occured to me that a trailer would have a max crosswind rating (: |
![]() "wright1902glider" wrote I'm currently working on various methods of accomplishing the new goal without spending too much cash. I think most of the steel framing and sheet metal can be used again. But I'll have to work out a new decking system, etc. What is the total weight of the loaded trailer, and what is the weight of the tongue (at the ball) with the load on the trailer? You could have a balance problem. -- Jim in NC |
of the tongue (at the ball) with the load on the trailer? You could have a balance problem. -- Jim in NC No dice Jim. The axle is only 4' forward of the back end. Loaded tongue weight is at the upper limits, usually 200+, but I've tried several different balance combinations within the 10-20% of gross range without any improvement. I don't think an anti-sway hitch would do much good either, since the trailer has a tendancy to just roll over, rather than sway wildly. Good news though. A few months ago, I ferried the boat I inhierited (sp?) from my Dad. 1500 miles from Louisiana to CO. with no problems. The boat is 17' long, about 1,000 lbs. gross, and has a side profile about 3' high. I ran on the same 12x4.8" tires that I pulled off of the glider trailer, and didn't have any problems with 15-20 MPH crosswinds. It did tuck in rather nicely behind the Dak, with the top deck at the same height as the top of the tailgate, so that may help as well. FYI: I've looked very hard at several sailplane trailers. But all that I've seen so far will not accomodate the 60" chord wings from the Wright machine. If anyone knows of a trailer that might, I'm open to suggestions. Otherwise, I'll keep saving my pennies until I can afford a 8x44' gooseneck & dually. Then, it would just be a matter of pulling the front feathers off and stuffing the whole assembled glider into its rolling hangar. Harry |
![]() There are several good trailer threads on rec.aviation.soaring. It's been debated endlessly ;-) There are also manufactured closed trailers for wide chord sailplane wings. You might check with Blanik America. They have a closed trailer for the Blanik that has a 66" interior height. http://www.nwi.net/~blanikam/ba/prod05.htm Best regards, Craig |
![]() "wright1902glider" wrote No dice Jim. The axle is only 4' forward of the back end. Loaded tongue weight is at the upper limits, usually 200+, but I've tried several different balance combinations within the 10-20% of gross range without any improvement. I don't think an anti-sway hitch would do much good either, since the trailer has a tendancy to just roll over, rather than sway wildly. So what is the total weight? 200 pounds does not sound like all that much on the tongue. Ok, I'm thinking out of the box, here. Aerodynamics. How about making it more stable to the side wind. First idea, a skirt around the bottom, lower to the road, so the wind keeps it sucked down to the road. Plus, if wind can not get under it from the side, then it is also less likely to be contributing to blowing it over. Along those same lines, it occurs to me that this light of a trailer must bounce a good bit. Does it have leaf springs? If so, how about some light shock absorbers to keep it from bouncing. Every time it gets up in the air, it gives wind an extra chance at the bottom of it. If the upwind side is bouncing up, while the downwind side is headed down, that gives it extra exposed bottom surface area and increased wind pressure on the bottom, plus making the center of gravity closer to being unstable. If the only spring is the air in the tires, a different inflation may make it bounce less. If possible, mount the axles to a swing arm, and use some air adjustable shocks and use the air pressure as the spring. Now, really out of the box. Create an adjustable ballast system. Some type of water containers, one on each side, and as low as possible. Enough water to fill one container, plus a small amount for plumbing and an inch or so in the bottom of the empty one. Plumb an electric reversible pump, or two with check valves. When the wind is not a factor, keep the tanks balanced. When it starts blowing like snot, fill up the upwind tank. You could run a few wires to the cab and control it all. This idea would work, without a doubt. The only question is if you want to go to the trouble and expense to make it happen. -- Jim in NC |
I have two Hovey Delta Bird biplane ultralights and a non-enclosed trailer
that I picked up at the same time as I bought the first one. The aircraft rolled up ramps sideways onto the trailer and clamped into place and then the tail assembly disconnects at the back of the main wings. The tail assembly then clamps into place reversed to the direction of travel with the tail end up near the tow ball. The complete aircraft is exposed to the elements. The ramps are at different elevations such that the rearmost wheel (starboard landing gear) is about a foot higher than the front wheel (port landing gear). This means the wings are at an angle that tends to push the complete aircraft and trailer down while travelling. A decent sloping roof on your trailer may add considerable downforce to help you handle the crosswinds. The single axle has three leaf springs, two as normal and the third upside down across the axle from side to side. The weight is shared between the springs. This is similar to the centre spring front end used on an old Corolla KE10 from the late sixty's. The cross spring is quite effective in helping to control the trailer. It is bolted to the frame at the centre and the flat ends ride on a section of channel welded to the axle so there is a flat surface to wear. The axle is held in place by the side springs which are mounted with coupling joints like most leaf spring cars. The side springs have three leaves and the centre spring has four leaves. I suspect that about half the trailer weight is supported by the centre spring. This trailer handles quite well and the second aircraft I towed 300 km through a back road mountain range to get it home in the middle of a storm. Although I restricted speed to 70 kmh for most of the trip due to potholes, and 80 kmh for smoother road stretches, I did get up to 110 kmh for a test stretch in calmer winds. I will send a couple of pictures to your email address, and also to anyone else that would like them, just drop a note here.... Hope this helps, Peter |
The over all width before you need special permits is 8 feet. Your thread
width may be all that you need to increase for stability. 5 foot isn't very wide. -- Cy Galley - Chair, AirVenture Emergency Aircraft Repair A 45 Year Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "wright1902glider" wrote in message oups.com... What is the total weight of the loaded trailer, and what is the weight of the tongue (at the ball) with the load on the trailer? You could have a balance problem. -- Jim in NC No dice Jim. The axle is only 4' forward of the back end. Loaded tongue weight is at the upper limits, usually 200+, but I've tried several different balance combinations within the 10-20% of gross range without any improvement. I don't think an anti-sway hitch would do much good either, since the trailer has a tendancy to just roll over, rather than sway wildly. Good news though. A few months ago, I ferried the boat I inhierited (sp?) from my Dad. 1500 miles from Louisiana to CO. with no problems. The boat is 17' long, about 1,000 lbs. gross, and has a side profile about 3' high. I ran on the same 12x4.8" tires that I pulled off of the glider trailer, and didn't have any problems with 15-20 MPH crosswinds. It did tuck in rather nicely behind the Dak, with the top deck at the same height as the top of the tailgate, so that may help as well. FYI: I've looked very hard at several sailplane trailers. But all that I've seen so far will not accomodate the 60" chord wings from the Wright machine. If anyone knows of a trailer that might, I'm open to suggestions. Otherwise, I'll keep saving my pennies until I can afford a 8x44' gooseneck & dually. Then, it would just be a matter of pulling the front feathers off and stuffing the whole assembled glider into its rolling hangar. Harry |
![]() "wright1902glider" wrote in message oups.com... What is the total weight of the loaded trailer, and what is the weight of the tongue (at the ball) with the load on the trailer? You could have a balance problem. -- Jim in NC No dice Jim. The axle is only 4' forward of the back end. Loaded tongue weight is at the upper limits, usually 200+, but I've tried several different balance combinations within the 10-20% of gross range without any improvement. I don't think an anti-sway hitch would do much good either, since the trailer has a tendancy to just roll over, rather than sway wildly. Good news though. A few months ago, I ferried the boat I inhierited (sp?) from my Dad. 1500 miles from Louisiana to CO. with no problems. The boat is 17' long, about 1,000 lbs. gross, and has a side profile about 3' high. I ran on the same 12x4.8" tires that I pulled off of the glider trailer, and didn't have any problems with 15-20 MPH crosswinds. It did tuck in rather nicely behind the Dak, with the top deck at the same height as the top of the tailgate, so that may help as well. FYI: I've looked very hard at several sailplane trailers. But all that I've seen so far will not accomodate the 60" chord wings from the Wright machine. If anyone knows of a trailer that might, I'm open to suggestions. Otherwise, I'll keep saving my pennies until I can afford a 8x44' gooseneck & dually. Then, it would just be a matter of pulling the front feathers off and stuffing the whole assembled glider into its rolling hangar. Harry Yet another clueless response: Have you checked toe-out/in on the trailer wheels? Tim Ward |
![]() "Tim Ward" wrote Yet another clueless response: Have you checked toe-out/in on the trailer wheels? Tim Ward Most bought trailer axles have no provision for toe in/out. They are dead straight. A big clue came when the OP said he could get one wheel to lift off the ground, just by pushing back and forth on the trailer, and get it rocking back and forth. Sway from toe in/out is not a problem here. Wider axle, and more weight on the axle, and less on the ball. That is what is needed. -- Jim in NC |
Article: America Has Grounded the Wright Brothers | Tom Sixkiller | Owning | 66 | January 3rd 04 05:55 PM |
Article: America Has Grounded the Wright Brothers | Tom Sixkiller | Piloting | 71 | January 3rd 04 05:55 PM |
NEXT ON NOVA: "Wright Brothers' Flying Machine" | Larry Dighera | Piloting | 0 | December 13th 03 02:32 AM |
